Question about Rockford Fosgate Car Audio & Video
WILL THE REMOTE CONTROL FOR AN AUDIO AMP PRESET THE AMP WHERE THE GAIN ON THE AMP ITSELF DOES LITTLE GOOD
    Problem Solver:
  • 5 Answers
All the remote does is turn the amp on or off. the volts running through the RCA cables will have an effect on the gain control
Posted on Mar 19, 2011
My Yamaha HTR 6130 surround sound amp just froze up on me and won't turn off or on or control the volume ect. I'ts on but will not do anything, I can't control from remote or the unit itself at all.
HI
i think the unit needs to be set back to factory defaults
procedure is
Initializing the HTR 6130
1. Connect the power cable of this unit to the AC outlet.
2. Press the "STANDBY/ON" key while simultaneously pressing the "STRAIGHT" and "AUDIO SELECT" keys.
The self-diagnostic function is activated.
3. Select the main menu "13. FACTORY PRESET".
4. Select the "PRESET RSRV".
Hope this helps
Kind regards.
M.Mathis
Apr 14, 2016 | Yamaha Htr-6130bl 500 Watt 5.1-channel...
Amplifier has a phone jack for remote. Stereo has a blue wire for remote. Do these two need to connect to each other, or can I just run a phone cable from the amp to a remote switch mounted up front. ...
No. That port is for your gain(volume) control switch for the amp(it should have been included with the amp). Connect the stereo's blue remote wire to the amp's remote input that's next to the batt. input and ground input. Here's a link that showed me the pics plus a pic of the switch with the phone jack cable. Copy and paste. Good luck. http://www.sonicelectronix.com/item_2553_Volfenhag-ZX-8300.html
Jul 25, 2011 | Volfenhag ZX-8300 Car Audio Amplifier
KAC9103d been running great for a year, factory refurb. for a month been losing sub output. checked all connections again, everything good. Turned on went driving 15 minutes later lost bass ckd again red...
Could be that you have a partially roasted(blown) coil on one of your subs which will function- but will keep tripping your amp.You can check that out just by using a different set of subs to listen to and by the process of elimination if the problem goes away then you know where the problem is at.Also check your gains you might be riding the gain a little high which causes distortion which causes heat(FAST) which will cause the amp to shut down completely or some amps will decrease output in a programmed attempt to save itself.turn the bass boost down to half if you even use it at all- that too can cause massive distortion in the amp itself,meaning only that if you have the bass boost on your deck turned up and then you turn the boost up on your amp the sound signal is then WAYYY distorted which will cause a thermal shutdown too. Last thing is to make sure that your subs arent running below 2 ohms because i believe that particular amp is designed to put out about 900 watts at 2 ohms.good luck
Jan 22, 2010 | Kenwood KAC-9103D Car Audio Amplifier
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Gain conrol problems
relatively simple 2 leg pot. fix.
Under $50 to repair.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 03, 2009 | Jl Audio 500/1 Car Audio Amplifier
Gain control
I would check ebay i know i bought one from there before. Hope this helps
Jan 13, 2009 | MA Audio HK4000D Car Audio Amplifier
Tuning preset
You need following remote...on $12
147851911 RM-SC1 REMOTE CONTROL
It is avalable on Sony Accessories website
Regards,
Aug 27, 2008 | Sony CMT-NE3 CD Shelf System
Pioneer Amp
Hello Shaun123, Phase adjust the amount of lag or lead one signal has in reference to another. Frequency is an adjustment of the number of cycles pers second a signal will produce. Gain refers to the amplification factor of a signal. now in reference to you amplifier by changing phase you can set the delay of a signal (if used right you can make a wicked reverb effect), but setting phase normally will affect the tones Frequency will affect for bass and treble functionality Gain will both preset and provide amplitude adjustment (volume) Take into mind these are more then likely presets. I hope this helps
Sep 05, 2007 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
