Question about Dynex DX-ESATAP 2-Port eSATA II PCI Express Adapter (600603116117) Storage Controller
What are the external power ports used for on the DX-ESATAP 2-Port eSATA II PCI Express?
  • 902 Answers
They provide dc power for esata devices should have Included a 4-pin internal connector and 2 DC power cables let me know if that solves your problem
Posted on Mar 19, 2011
Pci ide controller drivers
Probably need new motherboard + win 7 or 8
Dec 12, 2013 | SIIG 2 Port eSATA II PCIe Pro - 2 x 7-pin...
Tip
USB device on a eSATA port
A nice and mostly undiscovered feature which most of the newer Laptops and Desktops offer, is that you can connect an USB device to your eSATA port.<br /> <br /> eSATA/USB is a type of serial port in which eSATAp (Power over eSATA), eSATA or a USB device can be plugged into the same port.<br /> <br /> SERIAL ATA INTERNATIONAL ORGANIZATION acknowledges eSATAp as the actual name for the new eSATA/USB combo port. This is to differentiate and to prevent confusion with the original eSATA port.<br /> <br /> Only one type of device can be plugged in at any one time.
on Mar 02, 2011 | Computers & Internet
Bought DX-ESATAP but does not come up on new 8 core Mac tower; reseated a couple times and tested via firewire with G-Drive and it works; esata does not... ideas? thanks...
If you are looking to add eSata ports to your Mac Pro, the Dynex card is not compatible. I recommend a simple SATA extender cable connected to a bracket. NewerTechnology offers such an option; I have used it myself, and it retails for a very affordable $20.
Jun 16, 2011 | Dynex DX-ESATAP 2-Port eSATA II PCI...
Will NOT accept POWER. I have replaced the power supply and still does not power up. Lacie said thet can change it out, but would not guarentee no data loss. ALL I need is a mother board for the d2...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 21, 2011 | LaCie (130742) Serial ATA Controller
How do i find out what are all the plugins are for om my acer 1100 desktop
1) Outside the computer case;
Front:
A) 4 USB ports (Using USB 2.0 technology)
B) 1 Headphone Jack
C) 1 Microphone Jack
D) 1 Memory Card Reader;
"Multi-in-one Card Reader supporting CompactFlash® (Type I and II), IBM Microdrive, xD-Picture Card™ (xD), Secure Digital (SD), SmartMedia™, MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO™ (MS PRO) (selected models)"
Rear:
A) 1 PS/2 Mouse port
B) 1 PS/2 Keyboard port
http://en.wikipedia.org/wiki/File:Ps-2-ports.jpg
C) 1 Parallel port
http://en.wikipedia.org/wiki/Parallel_port
D) 4 USB ports (Using USB 2.0 technology)
E) 1 VGA port. (For an external VGA monitor )
http://en.wikipedia.org/wiki/VGA_connector
F) 1 IEEE 1394a port (Firewire port)
http://en.wikipedia.org/wiki/Firewire_port
G) 6 Audio ports
2) Inside the computer on the motherboard,
A) 1 PCI Express x1 expansion slot
B) 1 PCI Express x16 expansion slot used for a graphics card. (Uses the PCI Express 2.0 technology)
{250 Watt ATX power supply}
C) 2 PCI slots
Acer Support > Acer Aspire M1100 series of desktop computers > User Guide,
http://www.acersupport.com/us/en/product_support.aspx?tab=1
Go to the bold heading > User Manual
Click on the blue >
ASMx100_EXE210_VTMx10_UG_EN.zip
After you click on the above file name a small window will come up.
If there isn't a Green dot in the circle to the left of Save File, click on the circle.
Make sure there is a green dot in it.
Now go below, and click on OK.
Another small window will come up, that has a download progress bar in it.
Write down what is in the top heading of the window.
This is where the Zip file will download to.
It may have Desktop, or My Documents, or Downloads in the info at the top of the window.
Desktop: The file will be on your desktop screen.
My Documents: Click on Start > My Documents
Downloads: Click on Start > My Documents > Then double-click on Downloads
When you see the file name double-click on it
( ASMx100_EXE210_VTMx10_UG_EN.zip )
Another window will open up.
Click on > Unzip
On the top left click on Extract All Files.
Click on Next, Next, and Finish.
Now double-click on the file name next to the red PDF icon.
There's your user manual.
If I have left something out, or the above is not what you had in mind, or you have questions,
post in a Comment.
Would like to hear back from you.
Regards,
joecoolvette
Dec 10, 2010 | Acer Aspire M1100-U1402A Refurbished AMD...
I'm new to SATA technology. Need simple cable description help.
To resolve this behavior, follow these steps: Start > Run > type > regedit Locate the UpperFilters value under the following key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK. Locate the LowerFilters value under the same key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK. Quit Registry Editor.NOTE: After you remove the Upperfilters value and the Lowerfilters value, if you notice lost functionality in a particular program, such as CD recording software, you may need to reinstall that software. If the problem recurs, consult with the software vendor for assistance.
Dec 03, 2009 | BYTECC BT-PESAPA / 2-External SATA,...
Does my w3507 have an agp port
No it does not have an agp port. IT has a PCI Express Port for video cards. Its much better and faster.
Details on your machine and what it has can be found at this link. Hope it helps.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2912877&CatId=2643
Nov 10, 2009 | eMachines W3507 PC Desktop
Connecting a esata port to a sate external hard drive
I don't think there is a converter from USB to ESATA, but you could buy a new Hard Drive enclosure that has those options, but I am not sure if you are willing to take out the HD from the existing one.
Sep 09, 2009 | Iomega HDD External Desktop (32660) 80 GB...
Jumper settings for the Masscool XWT-PCIE10
Do you remember the default jumper settings? they're set to external ports' usage.
Have a good day.
Mar 17, 2009 | Fanner Masscool XWT-PCIE10 4-Port SATA PCI...
Dynex DX-ESATAP 2-Port eSATA II PCI Express Adapter (600603116117) Storage Controller Logo
168 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
