Question about Schwinn Exercise & Fitness
Mechanically my Schwinn V force continues to function. The problem is the programming. The problem is the programming. When I input various setting, though the monitor registers said commands, the programs will not implent the commands.
  • ramcbride6 Mar 21, 2011
    What a RIPOFF. "unplug the machine wIT 15 minutes and plug in the machine again." That's all you could come up with.
    YOU ARE PATHETIC.
    ED mc Bride
    Brigadier General:
  • 3,513 Answers
Hi
It is suggested to perform a reset program to your machine. Unplug the machine from the main socket and wait for 15-20 minutes then plug it back in, if nothing happens you need to take your machine to the dealer or contact the customer care before any further malfunction happens.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 19, 2011
Where is the body control module located on 2002 cadillac deville
The body control system consists of the following 3 modules:
• The Dash Integration Module (DIM)
• The Instrument Panel Module (IPM)
• The Rear Integration Module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each module is connected to the Class 2 serial data circuit, many of the control functions are implemented by Class 2 messages.
What system (S) are you having problems with ?
The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• Automatic level control
• CIGAR relay control
• Class 2 communication requiring RIM interaction
• Content theft deterrent
• Fuel door control
• Fuel level sensor input
• Heated seat control
• HVAC blower control
• LK/CYL relay control
• Park brake relay control
• Rear defog relay control
• Rear park assist chime control
• Retained accessory power (RAP) relay control
• Reverse relay control
• Transmission shift inhibit
• Trunk release relay control
• Various controls for the interior lamps
Instrument Panel Integration Module (IPM)
The various IPM input and output circuits are described in the corresponding areas as indicated on the IPM electrical schematics.
The IPM functions include the following:
• 54 volt VF display input
• Ambient light sensor input
• Class 2 communication requiring IPM interaction
• Fog lamp switch inputs
• Front HVAC air delivery controls
• Front HVAC sensor inputs
• Front HVAC temperature controls
• Fuel door and rear compartment lid release switch input
• Hazard switch input
• HUD active control
• Instrument panel lamps dimmer switch input
• Ignition switch headlight control
• Interior lamps switch input
• Key in ignition switch input
• Traction control switch input
• Twilight sentinel delay input
The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Class 2 communication requiring DIM interaction.
• Control of exterior lamps.
• Control of front fog lights.
• Control of the headlights.
• Headlamps on with wiper input.
• Hood ajar switch input w/export.
• Horn relay control.
• Interior lamps incandescent dimming.
• Low side temperature for HVAC compressor.
• Power moding control over Class 2 serial data circuit.
• Reverse lockout solenoid control.
• Steering wheel controls input.
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules.
Jun 19, 2017 | Cadillac Cars & Trucks
Lid closes to push down lever to let machine spin how do i fix that mechanisum ?
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
May 07, 2015 | Washing Machines
All the program working normal except agitator cycle
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Apr 06, 2015 | Hoover Washing Machines
I have a Casio fx 9750Gii.i cant write long program because i have already used all alpha key memories.how to continue writing the program
I believe you must rethink the design of your program
If you have several inputs that lead to a single result you want to keep for further calculations, enter the inputs, calculate your result and store in a variable. The intermediate variables can be set to zero (by precaution) and reused.
Use functions, and subroutines. Usually, in well designed programs, the scope of a variable defined inside a function or subroutine is local :It can't collide with the same name used globally (global scope). If a variable is no longer needed destroy it and reuse it.
Feb 23, 2014 | Casio FX-9750GPlus Calculator
Create a program that will input 10 grades (75:passing, 79-84:C, 85-89:B, 90-94:A, 95:A+). It will display the average grade.
This can be done in various of ways ,
a quick C implementation of this could be -
#define NUM_OF_GRADES 10
This function will average 10 grades and display their average .
short AverageGrade()
short sumOfGrades = 0; //Saves the sum of the grades .
short i = 0; //Iterator
for (i=0;i<NUM_OF_GRADES;i++)
printf("Please enter a grade:\t");
sumOfGrades += scanf("%hd",&sumOfGrades);
}//for
return sumOfGrades;
}//AverageGrade
You can either implement the printing of the average inside the function or from the calling function .
Hope this somehow helps ,
Have a great day !
-Danny
Oct 14, 2012 | Program Arts Software C-Free
3pc crank for schwinn z force
you can search it in near store or on ebay .
Aug 18, 2012 | Schwinn S2010WMB Z Force 20" Boy's BMX...
Looking for (perhaps a pdf) an online owner's manual for a Schwinn 13-function wireless bike computer. Thanks for any help.
Hi moparman2676...
I could not find a Schwinn 13 function wireless bike computer user manual, but I did find a Schwinn 12 function wireless bike computer user manual at this webpage:
Please take time to rate me thumbs up
http://www.k3pgp.org/schwinnmanual.htm
Sep 06, 2011 | Cycling
Forced Paging - how is it done and how can I stop it?
By programming. Handsfree Answerback set to "NO" will stop this.
Check with your system administrator or installer, someone with the system password as it's a programming function only.
Carl
Jul 15, 2009 | Nortel Meridian M7208 Corded Phone
BIOS DEFINATION
Basic Input Output Service....It is the chip on motherboard ,in which all instruction written for identifying the hardware
Dec 03, 2008 | Computers & Internet
Exercise & Fitness Logo
105 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
