I NEED INSTUCTIONS
HOW TO CHANGE A BALLAST ASSEMBLY FOR A TOSHIBA 62HM14 PROJECTION TV
Http://www.avsforum.com/avs-vb/showthread.php?t=1071492
Posted on Oct 10, 2008
The lights indicated that I needed to replace my lamp. After doing so, the TV still doesn't have picture. What do I have to do to get it to work?
It is possible that the Ballast is not turning on the lamp. In past years it had been difficult to get the Ballast separate from the Optical Block but they seemed have them available. In order to replace it you will need to remove the Optical Block which is in the center. The ballast assembly is mounted on the right side of the OpticaL Block. Once the Optical Block assembly is removed, it is not difficult to replace. To order a Ballast, call 1800-631-3811. You will need the model number.
I hope this helps,
Skyassoc
Dec 10, 2010 | Toshiba 62HM95 62" DLP HDTV
THE TV IS MAKING NOISE AROUND THE LAMP OF MY TOSHIBA TV 46HM95 THE PROBLEM OCCURS UPON SWITCHING ON BOUGHT A NEW LAMP AND A NEW FUN STILL NO CHANGE AFTER INSTALLING.
U hearing alot of clickings,when the tv turn on?Yes,the board call the Ballast board is dead also.This Ballast board,job is to help, to ignite the projection lamp.Tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.
Oct 14, 2010 | Toshiba 46HM95 46" HDTV
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Do I need to remove the rear cover on a 52HM84 Toshiba TV to change the ballast unit?
Click here to download the service manual. The rear cover will need to be remove to gain access to the ballast.
Jan 05, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
I have a 55" Toshiba Rear Projection TV and it works great for 30 minutes or so and then it just turns off. The picture is prefect as is the color...Then will not turn back on again, just flashes a red...
As your instincts have told you this MR.Techie is trying to rip you off. I think what you have is a faulty ballast. A ballast is a part in the projection tv that supplies power to the lamp. If the lamp is drawing more power than normal, then the ballast turns off and resets itself after a while. That's why the set works for a while before turning itself off again. A faulty ballast may reset even though the the lamp assembly is drawing normal power. You may also need to replace the lamp if it doesn't resolve the issue.It is a relatively inexpensive part but you will need the techie's assistance to replace it. Should cost you around 100-150$ for the repair.
Feel free to post back if you need more info.
Sai.
Oct 24, 2009 | Toshiba 55H70 55" Rear Projection...
Reset timer toshiba 62hm116
I do not think failing to reset the Lamp Timer would cause the Lamp not to light. You need to get into the Factory Menu while the picture is on in order reset the Timer. I believe you have a Ballast issue either because the Power Supply is not powering the Ballast or the Ballast not Powering the Lamp. In either case, the only way to know is to have a professional to check it out and give a estimate for repair.
I hope this helps,
Skyassoc
Aug 28, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
Electro Med Services...
