Question about ViewSonic VA550 15" Flat Panel LCD Monitor
My viewsonic va 550 monitor does not any image.instead, it displays a message read out of range. how do i fix that?
  • 11,361 Answers
Your PC video resolution is too high for this monitor to display, you need to set it to the native resolution of the monitor, 1024 x 768 @60Hz
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 19, 2011
Shuts off to a dark grey, turn VS power off>baon to display image
You may have failing DC filter caps in the power supply just like Viewsonic monitors you can see in my albums, you is about the same as 2235.
If you are not going to DIY you will be better off putting the money toward new monitor, estimate repair up to $100.
http://s807.photobucket.com/home/budm/allalbums
Jun 24, 2010 | ViewSonic VX2035WM LCD Monitor
Out of range message seen after installed new software and reboot
Native resolution of this VIEWSONIC is1280x 1024 @60Hz.
http://www.viewsonic.com/assets/019/7092.pdf
You will get that message because the PC is putting out higher resolution than it can display.
May 14, 2010 | ViewSonic VA703B LCD Monitor
The monitor will display out of range message because the PC video resolution is too high for the monitor to display, the new software may have changed or corrupt the video seting, try booting up in safe mode (hit f8 while computer booting up) and set the video resolution to 640 x 480, then reboot in regular mode, then reset the resolution to the native resolution of this monitor which is 1280x1024@60Hz.
Mar 24, 2010 | ViewSonic VA703B LCD Monitor
Attention out of range monitor H:95.1KHZ V:59.8HZ
You can solve this by choosing "Last known good configuration that worked" instead of going into safe mode. This will take your old display settings that worked.
Jan 09, 2010 | Computers & Internet
Monitor displays then shuts off
Have you verified the video card in the computer with a different monitor? Does the going to sleep message come up prior th the monitor going dark? The bulbs are ok since you do see a picture for a short time. The voltage swing you see on the power supply is too large. It should always be 12 v + or- 10%.
Mar 28, 2017 | ViewSonic VG900b 19" LCD Monitor
My ViewSonic computer monitor keeps displaying a Vga Not Support Message upon booting then the message Out Of Range comes up on a completely dark screen. Need Help
It sounds like the computer is trying to use a resolution that the monitor cannot handle. Boot into safe mode by pressing the f8 key during boot up and select safe mode. Once booted, right click on the desktop and select properties. In settings lower the resolution by moving the bar to the left and reboot.
I would move it all the way down, you can then move it up a step at a time once you are in normal mode again.
Hope this helps
May 02, 2009 | ViewSonic VA721 17" LCD Monitor
I have got a problem with my 17 inch viewsonic monitor. as i open the monitor it shows osd locked. pls get me the solution.
Assuming this is a E70fB monitor
OSD Unlock : Press and hold the [1] and [▼] buttons again for 5 seconds. The message “OSD UNLOCK” will then display briefly, indicating that the OSD image settings are now unlocked.
Userguide available at http://www.viewsonic.com/assets/027/7929.pdf
Mar 02, 2009 | ViewSonic E70f 17" CRT Monitor
About a problem in my viewsonic monitor
Hi
Actually the common problem of viewsonic LCD monitor is bad electrolytic capacitor at primary, secondary & inverter area, if your lcd using power adaptor test the voltage out, use analog or digital tester range 50v dc, if the voltage out is accurate dont be sure to your adaptor working good, open it and find bad electrolytic capacitor inside. That is common problem of viewsonic LCD monitor could cause of display flashing then back to black after few seconds. Suspect inverter area lastly mainboard.
Gud Luck!
Oct 06, 2008 | ViewSonic VE710s  (Black, Metallic...
ViewSonic VA550 15" Flat Panel LCD Monitor Logo
63 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
