Question about AOC Computers & Internet
Hi, I am trying to connect a ps3 to aoc monitor e2343f2k but nothing happen when i plug in the hdmi cable, may I know how to connect my ps3 with it??
  • 105 Answers
SOURCE: hdmi to dvi
This message may occur if the signal from the video adapter exceeds the scan range of the monitor (monitor not HD enabled).
The video adapter setting on PS3 for updating the screen (the refresh rate) is incompatible with the monitor.
Posted on Mar 28, 2008
  • 151 Answers
SOURCE: Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
SOURCE: PS3 not working through HDMI cable
connect PS3 to TV select HDMI channel on TV press AND HOLD power button on PS3 until screen resolution selection page appears.
PS3 should now work.
had this problem, this solved it.
typical repairman looking for work :)
SOURCE: Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Posted on Aug 13, 2008
Nic61
  • 1073 Answers
SOURCE: ps3 hdmi to tvmonitor dmi
You mean HDMI to DVI right?
You need a cable hdmi----->dvi, there are a lots of them, you will find them in any good tv/audio store or on the net. Buy one of good quality, you wont regret it, the differens betwin a good quality and a cheap one is huge
Good luck
Posted on Dec 08, 2008
My monitor was working perfectly fine until I unplugged it to play on ps3 so when i did the ps3 wouldnt connect i tried holding down the ps3 button nothing so i plugged back into laptop no connection.
Have you used the HDMI cable with the PS3 before? it may be configured to use the AV connection. If so plug in an AV lead, then you would need to find in the settings to change the output to HDMI.
The HDMI cable may not work
Press windows key and P to switch between monitor modes
Try those and post back if you need more help.
Mar 30, 2015 | Hannspree HF199H 19 Flat Screen LCD...
Cannot get it to connect to monitor
Hi, What model Hannspree is it? you might have the resolution set too high for the monitor!
Sep 23, 2007 | Sony Playstation 3 (PS3) Console
Play anything ps3
Hold on. Have you plugged in the PS3 with HDMI before?
try plugging in with an AV cable, the one that came with the PS3. You would then locate in the settings to change modes see the video for help.
May 02, 2014 | HP Pavilion Computers & Internet
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
I have an AOC L19WH LCD monitor. I am trying to get sound out of the monitors speakers but am having problems.
I can't find the model number you posted from the AOC website, so its hard to help you.
The only way you can get sound from a monitor is if you plug in the HDMI cable, this means that you need a graphics card with HDMI, very few computers have onboard HDMI.
Monitors that have speakers use HDMI and they need to be plugged into a HDMI port.
If you are using the DVI port, you will NOT get any sound.
You need to post the correct model number or a link to your manual, you also need to post what computer and what graphics card you have.
If you post this info, then someone can help.
The posts above are funny, a PSU has nothing to do with sound.
ODIEBUGS
Apr 05, 2012 | Computers & Internet
I have a Vx2433WM and am using it as a tv for my PS3 through hdmi connection. The audio stopped working. I tried muting and un-muting but nothings happening. How do I get my audio back??
Welcome to Fixya. If the volume is not working on the monitor the next thing you need to check is the HDMI cable. If possible to replace the cable so that we can determine the problem if this is caused by the cable, the monitor or the PS3. You can also try to connect the PS3 to a different TV using the same cable and see if you will hear a sound. Please let me know what happen so that we can continue troubleshooting.
Thanks
Sep 28, 2011 | ViewSonic VX2433WM 23.6" Monitor
Does the AOC 931Swl 19 have a hdmi port to connect my ps3 to?
Hi there.
Unfortunately the AOC 931Swl does not have a HDMI port.
Slasher_X
Sep 22, 2011 | AOC 931SWL 19 inch Monitor
I have a 24" aoc 2436Vh display and a new 15"
I purchased the AOC 2436Vh display yesterday. To get my MacBook Pro to work with it I purchased Apple's Mini DisplayPort to VGA Adapter. Since the monitor comes with the VGA cable, all you need is the adapter to plug it into your MacBook Pro. It works beautifully and set up is easy if you know your way around the Mac. Although the HDMI works perfectly with my PS3, I strongly recommend the Apple Mini DisplayPort to VGA adapter. I hope this helps.
Nov 11, 2010 | Computers & Internet
PS3 HDMI - Sony Bravi KDL-40V2000 Problem
  • Have your ps32_bing.gif in standby mode (red light).
  • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 08, 2010 | Sony Playstation 3 (PS3) Console
How would i know if my HDMI ports are working or not?? Tried to connect a PS3 to it but nothing. Thought it may have been the cable so checked someones that i know is working and still nothing. Checked...
As you already checked PS3 and HDMI cable,
select HDMI input in TV and connect PS3 via HDMI cable. TV should show PS3 picture.
And if still no joy then HDMI input port in TV is bad and need to replace input board/ main board.
Jul 08, 2009 | LG M227WD-PZ LCD TV
Computers & Internet Logo
136 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
