Question about Whirlpool Duet GHW9150P Front Load Washer
F11 WHAT DOES F11 MEAN AND HOW DO I FIX IT?
    Scholar:
  • 97 Answers
Hiya
have you tried cleaning the pump filter?
it will be located behind the plastic kickplate on the front of the machine or behind a flap also on the front of the machine.
if the filter is clean then i would check the carbon brushes in the motor.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
Kenmore gas range F11 error code
The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
Dec 13, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have an E4 front loader it is flashing F11 what does that mean?
If you're handy, there's a guy on Ebay who seems to specialize in the F11 problem. Here's the web address:
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2
I know nothing about him, but he has great feedback.
Jan 16, 2011 | Kenmore Washing Machines
My front loader wirlpool washer is having problems it starts out fine then it flashes a F- symbol. And does not finish spin cycle. Why? And what does that. Mean?
The F is showing up saying there is a fault somewhere. Since you don't say what comes after the F code (F11, FdL, Etc) it's hard to say what the problem is. If you remove the lower panel below the door (3 screws at bottom of machine) ther should be a packet taped to the inside of the machine. This is the repair guide for the machine and it says what the different codes mean. Good luck.
Jan 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We are getting code F11. What does that mean?
Hello. the F11 trouble code means Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
These are circuit boards within the machine and one of them will have to be replaced. Most folks leave this job up to the service technicians.
Feb 02, 2010 | Kenmore 46462 Front Load Washer
What does F11 code mean?
F11 is a code that referes to communication error between the central control unit and the motor control unit. Disconnect power. Check wire harness connections to motor and control board. Check drive belt, visually inspect to see if belt is broke. Check drive motor, visually confirm motor operation. It is possible that if the belt broke it may have slung around in the cabinet and damaged or loosened the wire harness connection at the motor. Try unplugging wire harness at motor and then plug it back in securely. Hope this info has helped. Thanks, Tim.
Jul 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F11
these error codes are not specific FDL can mean door latch failure .it can also mean the ccu board has failed also F11 can mean mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor. if you do not know how to diagnose with out error code you may end up buying wrong part. sometimes doorlatch is not problem central control board CCU is
Feb 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does F11 mean?
it is a communiacation problem replace wire harness and both boards worst code to get because ther is no concrete fix.
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De
