Question about Porter Cable Garden
Yesterday I purchased a Porter Cable Jointer PC160JT from Home-Depot, Fairbanks. It was a floor model and as such DID NOT COME WITH ANY PAPERWORK. Is there any way I can obtain the owner's manual and or the warranty? Doug Woolley psiaak@gmail.com 270 Topside Road Fairbanks, AK 99712 907 322-7448
    Novelist:
  • 144 Answers
Hi psiaak,
You should have gotten all that when you purchased that equipment. If I were you I would go back and demand that paperwork, just because it is a floor model (demonstrator) you should still be able to get those papers. You should be able to go to the Porter Cable web site and get that. Hope this helps. All the best and good luck. Denis.
Posted on Mar 19, 2011
Instructions manual for the Ryobi jointer planer 1500 watt
check with ryobi or even home depot . they may be able to order you one
Feb 12, 2016 | Ryobi Masonry Tools
Manual for Porter Cable wood working tools
You can get manuals for many porter cable tools by going to this link and using the model number to search parts. There is frequently an option to download a pdf instruction manual below the exploded parts diagram(s)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 26, 2011 | Sears Masonry Tools
Where can I get a manual?
I don't know where you live so I can't tell you expressily where to go, but try this. Call your local hardware store, or other type store (big box, like Lowes, Home Depot and ask them if they sell the Porter Cable brand of compressor. Also you might try the internet to locate a dealer near you and/or contact one of them by email or phone and ask them for the manual.
Mar 22, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I am thinking of getting a compressor for my husband for christmas...looking at Bostitch and Porter Cable..both 6 gal portable...cost is comparable, in stock at both Lowes and Home Depot. We are going to...
Eighter one of these will work good for nail guns personaly i have the porter cable and i like it i do a lot of construction work. And i think the porter cable comes a finish nail gun for small nails and staples mind did. But there not for running tools that require a large volume of air like air sanders air rachats or air cutters.
Dec 20, 2010 | Porter Cable C2002 150 Psi 6 Gal...
The drain plug on my Porter Cable pancake compressor leaks so badly that it no longer build pressure. The compressor is just a little over 1 year old and I have always drained the compressor after each...
Yes...the drain valve on the bottom of the tank is just a standard 1/4 Drain Pedcock that you can purchase at most hardware store.
You can also find these in the hardware section of Lowes or Home Depot where they sell the Air Compressors.
Oct 24, 2010 | Porter Cable C2002 150 Psi 6 Gal...
I have 3 compressors, all of them refuse to stop compressing until i manually shut them down,husky 26 gallon upright 5 yrs old, porter cable pancake 2 yrs old. and a master elite? came from home depot as...
the regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
Nov 13, 2009 | Porter Cable Air Tools & Compressors
I have a 12 5/16'' ryobi planer and need a place to get a set of knives and books.
go to home depot and purchase DELTA 12 1/2 inch blades. make sure they are centered so they don't rub the sides of the housing or grind off a little bit off each end.
Oct 18, 2009 | Ryobi Thickness Planer Blades
PIN100 leaves about a 1/8" of pin exposed every time.
I have seen many Porter Cable pin nailers with a bent or broken driver. Easy to check. With breakdown in hand (http://images.toolpartsdirect.com/schematics/portercable/pin100.big.pdf) remove head nut and other parts to gain access to piston/driver. (parts # 60084) Most drivers have the tip missing or driver is bent. Replace as needed. If driver looks good replace driver into cylinder and push all the way down. The driver should extend about 1/8" past nose. Check for obstruction around lower bumper. Parts are not expensice and are available at WWW.toolpartsdirect.com. Please email if you have any questions. Good luck.
Feb 16, 2009 | Porter Cable 23GA Pin Nailer Kit
Wobble in disk
if this is disk type grinder make sure you did not knock the disk out of alignment when it fell off table if so remove and re-align or replace disk seen it before make sure
Nov 24, 2008 | Porter Cable Porter-Cable Variable Speed...
How do I disassemble a porter cable 1002 router? I am trying to get to the motor in order to clean out pieces of broken brushes.
How do I hold the armature still on a Porter Cable Model 1002 Router to take the nut off to change the inner bearing
Oct 14, 2008 | Porter Cable Tools & Hardware - Others
Garden Logo
130 people viewed this question
Top Porter Cable Garden Experts
Jim Goldsmith
Jim Goldsmith
Jim Parker
Jim Parker
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
