Question about Sansui Audio Players & Recorders
Looking for a stylus for old sansui turntable model FR-D25??? Any suggestions
  • Sansui Master
  • 6,771 Answers
It is next to impossible to find a replacement stylus, I suggest replacing the cartridge which will include the stylus giving you the flexibility to make a choice on what you prefer.
Posted on Mar 19, 2011
Sansui sr 333ere can I get a stylist for my sansui sr 333
If you look at the Cartridge it should have a make and model number on it. Put that into Google and it should find a replacement stylus.
Oct 31, 2013 | Audio Players & Recorders
I have a sansui FR-D25 automatic pll dc servo turntable. it hasnt been used in a couple of years due to a broken stylus. i have purchased a new one but now the metal plate sounds like its grating on the...
You will have to remove the bottom cover and pull the center post off. There is a set screw that holds it in place. Once removed you will need to clean the hole out of dirty grease and oil with a q-tip and alcohol. Then put some new oil in the hole. Just a small amount. Sewing machine or turntable oil or similar. Not motor oil! When put back together that will cause the platter to rise up and away from the base. You may also check the plastic gears under platter attached to the post to see if the are broken or cracked. If it is you have a major problem and it will need to be replaced with a donor part.
Aug 22, 2013 | Audio Players & Recorders
I have a linear tracking Akai AP M313 turntable without a stylus connected. I have bought the correct part number stylus for it but can't see how it fits. Can you help?
You need to define the cartridge make and model for us to be specific; and read the manual(s) or sheet that came with the stylus. They typically slide in the direction opposite that which the old one came out. I'm sure if you look at the inner surface of the stylus it will have guides suggesting the way it is inserted.
Apr 09, 2011 | Akai Stylus Needle Apx1c M313w M452 (cd)...
I am looking for a Sansui turntable cartridge, stylus and needle for model SR-222
You can use any standard 1/2-inch mount cartridge, not just the original. So you can shop around and get whichever one fits your budget. Here's one place I have purchased cartridges from. You can find many other sources online, and there may be a stereo shop or musician's supply store in your area that has cartridges in stock.
If you need a copy of the manual which shows how to install and adjust the cartridge, you can download it from Vinyl Engine. You need to register to download, but it's free.
The needle and the stylus are the same thing, and the cartridge is what holds the stylus, by the way.
Jan 11, 2011 | Audio Players & Recorders
I have a problem with a Sansui turntable
Linear tracking tonearms probably don't move much under manual control. It would still help if we knew the model number.
May 17, 2010 | Audio Players & Recorders
STR8-60 stylus
I suggest you contact the MUSONIC web site. They specialise in cartridges and styli.
Dec 20, 2008 | Stanton STR8-60 Turntable
Looking for stylus and drive belt for FR-1080....old
The drive belt I can look up by the model number. I'llpost that when I get it. The stylus, however, you'll nee dto provide some info first. Are there any markings on either the cartridge or needle? Please post those markings. That will geive me an idea of what brand of cartridge and the possible needle that is used.
Thanks,
Dan
Aug 29, 2008 | Sansui Audio Players & Recorders
Magnavox Stylus
We need to know the model number of the CARTRIDGE itself. Doesn't matter what turntable you have. All that matters is what cartridge is mounted on the turntable, so that we can match the correct stylus. The stylus/needle connects to the Cartridge:
As the diagram shows, the stylus mounts to the cartridge, which then mounts to the headshell. This headshell is then connected to the tonearm (tube).
So, if you look at the cartridge you should be able to see the model number. If not, there is no way to match up the stylus, as ther are literally THOUSANDS of styli on the market. I would suggest purchasing a NEW cartridge/stylus combination. The following should fit your model:
UNIVERSAL MOUNT CARTRIDGES
- Davis
DJ Pro Audio
www.djproaudio.com
Aug 10, 2008 | Philips Audio Players & Recorders
Replacement stylus
I Can Go On Ebay ANd Search
Jul 24, 2008 | Audio Players & Recorders
189 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
