Question about Encore PrintMaster 17 Gold for PC
Can't install PrintMaster Platinum 16 on my Windows 7 PC
  • 65 Answers
This version of print master is not compatible with windows 7.
see the compatibility criteria of Printmaster on the link given below!
http://www.microsoft.com/Windows/compatibility/windows-7/en-us/Details.aspx?type=Software&p=PrintMaster%20Platinum&v=Encore&uid=18&l=en&pf=0&pi=9&c=Graphics%20%26%20Printing&sc=Image%20Editing&os=64-bit
You can try if this works in compatibility mode in your pc - Try running in compatibility mode. Right click the program icon, click Troubleshoot Compatibility, wait while the problem is detected. Click Troubleshoot program > select an appropriate version of Windows the program is known to run in, try Windows Vista SP2 > start the program to see if it runs. If it runs, click next to proceed with saving the settings for it.
Posted on Mar 19, 2011
Printmaster install set up won't load completely. Windows 7.
This problem sometimes occurs due to corrupt installation file or due windows errors. WebRepOverall ratingThis site has no rating(not enough votes)
First of all apply following troubleshooting steps to PC:
Fix registry errors
Remove un-necessary programs
Scan PC with Anti-Virus
If installation problem still occurs then use system utility tool Reginout.
Dec 03, 2012 | Broderbund PrintMaster Platinum 16
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I cannot install PrintMaster Platinum 2011 on my Windows 7 computer. Is there a way to do it? It says it is compatible with windows 7.
Administrator privileges are required to properly install the program on Windows® XP, Windows Vista®, Windows® 7 and Mac OS X for PrintMaster Platinum 2011 .
Using mouse, right click on the "setup" and Run as "Administrator"
Hope it helps.
Apr 28, 2011 | Encore PrintMaster 17 Gold for PC
How do you make Printmaster Platinum 16 work with windows vista
Printmaster Platinum 16 is not compatible with Vista or windows 7. You can try to use Vista compatibility mode to run older programs in Vista. There is not guarantee that it will work!!! Please take note:- **The installation of an older program to run in a newer OS may also crash your PC too.
Link to How to "Use windows vista compatibility mode" - Use at your own risk!
Good luck
Dec 20, 2010 | Broderbund PrintMaster Platinum 16
Will Printmaster Platinum 16 run on windows 7 I
Oct 24, 2010 | Broderbund PrintMaster Platinum 16
Need a patch for printmaster platinum 10 for windows 7
my wife has a dell computer with window 7 professional operation sistom and i have printmaster platinum 10 only for Windows 95/98/200 NT 4 how i cann install this program in the new computer?
May 31, 2010 | Broderbund PrintMaster Platinum 16
IS THERE A PATCH TO MAKE PRINTMASTER PLATINUM 16 COMPATIBLE WITH WINDOWS 7
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Mar 14, 2010 | Broderbund PrintMaster Platinum 16
Can i install the print master platinum 16 on my new computer with windows 7
ypu cannot use print master platinum 16 with windows 7 or for that matter vista
Mar 05, 2010 | Broderbund PrintMaster Platinum 16
Can I load Printmaster 16 on Windows 7?
Printmaster 16 will work with Vista and Windows 7, you need to run setup.exe as administrator.
Jan 10, 2010 | Broderbund PrintMaster Platinum 16
Encore PrintMaster 17 Gold for PC Logo
449 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
