Question about Kenmore Washing Machines
The catch doesn't activate when I close the lid, It looks like it's broken?
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
Based on the info in your post, it sounds like a common top load washer problem. Here`s how you can repair it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis top-load washer, not necessarily applicable to ALL...it should cover yours)
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find. If this is something you think is not within' your scope of expertise please call a pro.
I will try to help in any manner I can of course as well. Good luck.
Thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Posted on Mar 19, 2011
    Master:
  • 354 Answers
Its a switch just take it out and take to an appliance store and they will probably have one. Wont hurt you and if your worried about it just make sure the power is off when doing it.You dont want it starting while you are playing with it
WONT SPIN ?
There is a switch..(interlock) that activates when the lid is open or closed...not allowing the unit to go into spin if the lid is open. It may be that the machine thinks the lid is open. The switch could be dirty or broken or loose. There is a little leg sticking out from the underside of the lid, that goes into a slot on the machine when the lid is closed, that activates the switch. Make sure this all looks good, (no obstructions or debris in the slot) and the leg goes all the way into the slot (lid closes all the way).
You should see a little plastic lever in the slot that the leg on the lid will contact when you close it. If it is there and unobstructed, try gently pushing down on with your finger or the back of a pencil or something, until you hear a faint click (switch). It should spring back into position when you release. Its a quick and easy check. Good luck.
Feb 25, 2016 | Washing Machines
Washer wont spin
see this possibles cause:
It doesn't pump or spin
frozen pump pulley+drive pump belt broken replace
It pumps, but doesn't spin
lid switch open, or defective +motor coupler broken+belt broken+clutch worn+motor defective.+transmission not shifting properly+basket worn
It spins only with the lid closed
safety the machine will run with the lid door closed.
God bless you
Jun 28, 2012 | LG WM1814CW Front Load Washer
711 Lid lock issues
see this causes:
frozen puller, or broken belt, lid switch defective or open replace
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, basket worn,
for security reason, only spin with the lid closed
Jun 19, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Washer will not spin dry
see the causes:
frozen pulley or broken belt replace+lid switch open or defective replace
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, the basket is worn.
for safety, only sping with the lid closed.
Jun 19, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My Vaio doesn't go to sleep/hibernate when closing the lid
Maybe the little sensor or pin that sticks up and is pushed in when you close the lid is broken and the software doesn't realize the lid has been closed.
May 02, 2012 | Sony Computers & Internet
My washing machine drains,but when on a cycle the drum doesn't move at all and it doesn't go into spin mode?
Check the actuator for the lid switch to make sure it isn't bent or broken. To find the lid switch, look for a pin on the lid that goes through a hole in the top of the machine when the lid is closed. The lid switch actuator is under this hole. If you can't see the actuator lever through the hole, it's probably bent off to the side or broken off. It's also possible to see it, but it's bent down to far to be actuated by the pin. If the lid is bent or the pin is broken off, that would have the same effect.
Apr 04, 2012 | Washing Machines
I know it takes 2 minutes to start, but my washer doesn't catch when you close the door, it takes about one hundred times for me to open and close the door until it actually catches and goes into...
I suspect a lid switch. Go here for your model and help
http://appliancehelponline.com/index.html
Please rate me thumbs up and testimonial, if this helps
Thanks
Leo Ponder
imufo2
Aug 16, 2011 | Whirlpool LTG6234D Front Load Stacked...
Kenmore heavy duty 70 series model 82763110
set the load size to small, fill with water.
now after it fills with water do you hear anything? motor noise?
If you hear motor noise, it probably has a broken motor coupler.
if it doesnt do anything I would look at the lid switch and activator, the lid has to close and the switch has to know it closed. did the tab on the lid break off?
May 03, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
49 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
