Question about RCA Televison & Video
Rca tv F27191DG - we've been losing picture temporarily. each time it happens there is a red asterix next to the channel(s) - what is happening and how can be stop it.
  • 367 Answers
SOURCE: Sound no picture brand new tv
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Posted on Feb 02, 2008
SOURCE: TV losing its channel memory
Call Acer.
I had he same problem, Acer sent to me a technician who uploaded new firmware to the TV and in about 10 minutes the problem was solved.
Uploading the new firmware goes through a specific interface so unfortunately you can't do it yourself
Posted on Feb 16, 2008
scottyfixit
  • 186 Answers
SOURCE: LG 37 inch Flat Panel Loses picture
Take a camcorder and capture it, that should be enough proof that it's failing often enough to be repair right. When the picture goes out, can you see it dimly if you take a flash light to the screen? It might be a bad inverter.
Posted on Apr 25, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
hi there, have the same kind of problem twice so far after was bought for me as x-mas present (although my viera isnt plasma, its an LCD TX-32LMD70A)..
I Pulled out the mains plug for about 10-20 seconds and then plugged back in (power button at top was pushed in, in the on position, so when the power was on, the tv just goes straight on). It then worked.
i would however like to know why this happens ( i really hope this isnt a hardware problem, as like many others... its only months old!!)
hope this helps
Posted on Apr 27, 2008
I had the same problem. I replaced the EEPROM marked U33 (it's a 24C32 in a smd package) and the TV worked fine.
BEFORE replacing the EEPROM you have to go into the Service Menu (hold down VOL- and CH+ on the local command) and take a note of all the values, specially the R,G,B gain and R,G,B bias, in the "standard" picture mode as well as in the "Cold" picture as well as in the "Warm" picture mode.
(if you forgot to do this, here are my default values:
R gain: 434
G gain: 482
B gain: 484
R bias: 270
G bias: 270
B bias: 264
then you put the "Cold" image mode and set again those values, increasing the G bias to about 300 and the B bias to about 310.
then put the "Warm" image mode and set again those values, increasing the R bias to about 300 and the G bias to about 280)
The other values such as brightness, contrast etc, have to be left at 50.
I hope this solution will FixYa!
Posted on Aug 06, 2008
Why does my RCA tv lose voices for approx 2 seconds on certain channels?
it takes a few seconds to lock on to channel. Happens on all set but some are faster and some slower. This does not indicate a problem.
Jan 04, 2017 | RCA Televison & Video
RCA 27R411T 30" TV - purchased 2004
yes i think the tv is on its way out
could be in the jasks the main board
your picture tube could be on the way out also its most cheaper on you to purchase a new set
Jul 29, 2008 | RCA 27R411T 27" TV
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
I am having issues with my RCA L46wd22yx5. First cable is on channel 3. that channel keeps saying unusable signal. Video 1 is the DVD player. Same thing..Video 2 is the Xbox 360 same thing and the HDMI1 is...
Check to make sure that the individual cables are connected to the corresponding channel. For example, DVD player is connected to the "Video 1" output on TV. On the back of your DVD, the cable is plugged in the "out" output, going to your TV the cable is plugged in the "in" output(red, white, yellow) Are you using an RCA cable(red, white, yellow) for the units?
May 13, 2010 | RCA L46WD22 Television
The tv has sound but no picture
Are you connected with RCA cables or possible component cables (Red, White, Yellow, Or Red, White, Yellow, Green...etc)
Make sure the cables are in the correct holes. This has happened to me on numerous occasion. On an RCA setup, you can easily install one of the audio cables correctly and switch the other audio and video and this will yield partial audio (one channel) and no video.
Oct 13, 2009 | Olevia LT32HVM 32 in. LCD Television
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
Losing picture on tv!
The ITC008 chassis is commonly riddled with poor solder connections. Good soldering station, patience and some good light and magnification and you might be able to fix it... Or you could spend a few dollars and run it into the shop and have a tech do it! It's not an expensive repair.
Bill
Apr 10, 2008 | RCA 32V550T 32" TV
LG LCD HDTV 'NO SIGNAL'
To fix the problem, try turning off the TV and unplugging it from the outlet. Once unplugged, push the power button and hold it down for 1 minute. Then turn the TV back on and rescan for channels.
If the problem persists, contact LG customer service immediately as there is a problem with the memory card. The device is unable to retain scanned channels for immediate feedback.
All LG LCD automatically comes with a 1 year manufacturing warranty. You would have to provide proof of purchase to show when it was purchased. Hope this helps. The Guru
LG customer service: http://www.lg.com/us/support/index.jsp
Dec 07, 2007 | LG 42LC2D 42 in. LCD HDTV
Losing picture
Six blinks error code could be the Thermal Fuse part# 1-910-006-44
Sep 28, 2007 | Sony KDF-E55A20 55 in. LCD Television
Black and white lines
Good afternoon your tv could have some lose solder have a tech look at it.the problem is in the video circuit and related circuit.checkd should be made in the IF circuit.good luck.
Apr 05, 2007 | RCA 27V530T 27" TV
Televison & Video Logo
26 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
