Question about GE Superadio III AM/FM
Looking for the 3 POTS for my GESR I think the part numbers are 2 each of: R53 49A20177 1 each of: R64 EA49X881 my email is radioace318@gmail.com Thanks Guys Rick
My ford focus wont go into gesr
Clutch is worn out or needs to be adjusted . What year is it ? Some clutch's have a cable that engages an disengages it and they stretch an need to be adjusted or replaced. Now most have a hydraulic slave cylinder like brakes an need brake fluid ,could have a leak , bad slave cylinder ! I could tell you which you have.
Jan 20, 2015 | Ford Cars & Trucks
I have one of the ceramic pots broken on a TRU BS-315R. Where can I find replacement?
Kathy, did you ever find a replacement pot ? I just broke 2 of mine and was also looking for replacement pots. Jan
Nov 16, 2012 | Tru Bs-315r 3-crock Buffet Slowcooker
Hello. I am looking for the firing order &/or wiring diagram for 2000 chevy s-10 bazer, V6 4.3 vortex. Can you help?
Will try to explain because i don't know how to paste a picture. From the front of the vehicle looking at the engine. Your # 2 4 6 cylinders are on the passenger side and # 1 3 5 are on the drivers side. 2 is front and 1 is front. On your "cap" as your looking from the front of the vehicle the passenger side of it starting from the front going back, here are the numbers 2 4 6 and on the drivers side is 3 1 5. The firing order is 1 6 5 4 3 2. I hope you understand what I am saying if not I can email you a picture. Just reply with your email address and I will be happy to send it to you. I hope this helps and i was detailed enough for you and good luck.
Feb 13, 2011 | 1997 Chevrolet Cavalier
Looking for an owners manual for hamilton beach slow cooker #33956
(http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man) Here is a link to your manual just scroll down type number for your download to start click save to folder open and read after download...you don't have to put an email address if you don't want to....
Jun 07, 2009 | Hamilton Beach 33956 5-Quart Slow Cooker
Cover for rival crock pot chipped and unusable
Try this website, they seem to have a good selection of replacement parts that are pretty cheap.
The size crock pot you have is the most common I think. if you aren't sure which lid to buy, email them and ask.
Hope this helps!
Jan 04, 2009 | Rival 38601 Smart Pot 6-Quart
Crockpot manual
I buy thi crockpot 3 years ago, never use losta manual plese help bessy alvarado from california
moms_11@yahoo.com
Oct 31, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
Ultrex pressure cooker model innova 14240
Pressure cookers are only slightly more complicated than crock pots. In fact, you can think of them as the opposite of Crock pots. Where a crock pot needs 2-3 times as long to cook something, the pressure cooker needs only 1/2 to 1/3 of the time.
These are not that complicated and haven't changed in the last 50 years. The only real hard part is being sure is doesn't explode; not that hard: don't cook things that would foam, like pasta or potatoes. Just read some recipes on the internet or get a recipe book at a bookstore, used book store (super-cheap)or the library. My best advice is to make sure you use the lowest possible heat that still allows steam to escape at a whisper. That will keep things from burning (or scorching) on the bottom, which can give a harsh taste and make clean-up more work. Just do it.
Jul 20, 2008 | Ultrex 2-in-1 (9qt) 8-Quart
31/2 Quart older model crock pot
I just recently got a crock Pot # 3100 in the almond color that someone had left at work many years ago and never picked up. They were going to throw it out. All 3 of the little plastic feet were broken off. I went to a local thrift store and found the same crock pot without the stoneware liner. The case was in perfect shape and still had all 3 plastic feet attached. I paid $2.00 for it and just recycled the old one that I had. I see these at thrift stores pretty frequently and have even seen the lids (glass and plastic) by themselves. If you are looking for replacement parts, Rival does not carry many parts for these older Crock Pots and your local thrift store is an excellent source.
Jan 01, 2008 | Rival 3100 3.5-Quart
GE Superadio III AM/FM Logo
48 people viewed this question
Top GE Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jim Goldsmith
Jim Goldsmith
john1959ny
john1959ny
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
