Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
My Hayward H Series 400k BTU heater comes on, tries to heat, the heat light comes on for a moment, then goes off, then tries again, and then shows error code IF. I went through the modes to reset it and it does it all over again and errors out again.
  • 2,382 Answers
Hi, "IF" or" Ignition failure", simply means your heater didn't fire. Be sure your gas is on and if on propane be sure there is at least 30% in the tank (and the valve is open). Also check whether your "Glow plug" ignitor Glows, or your spark ignitor sparks (depending on which kind you have).
Posted on Mar 19, 2011
New Hayward Heater H series 400 BTU won`t light error IF
check gas pressure again meter could be too small if furnace goes on while heater is on it will run out of gas and turn off giving you that error
May 13, 2012 | Hayward H Series Pool & Spa Heater 400k...
Heater problem
the pressure switch had some debris in it. flushed it out and heater heated to temperature
Oct 02, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool heater won't light
it is possible to light a pool heater with an ignition device,however it is not advisable.since your unit is calling for heat and the gas valve is opening,i suspect you have a faulty ignitor
Jul 21, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Jul 03, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hi I have an Hayward H Series pool heater and the pilot doesn't stay lit when I depress the control to turn it on. Any quick solution for that ?
Check the thermocouple that the pilot light heats up. If it is not working then the gas to the pilot will not stay on.
Jul 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
I have a Hayward pool heater. It's about 5 years
would not suggest trying to manually light,its an electronic ign model so you may damage some wires with an open flame.try powering off then turning back on and see if display retuns to normal
Jun 19, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward Pool Heater is not working. Fan turns on, but that is it.
I had the exact same problem. The propane guy had to come back and put the regulator right by the heater instead of being on the tanks. Did this and boom heat. This was after 6 days of calling and calling hayward tech and service guy. Hopefully it will continue to work :/
Jun 07, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
42 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
