Question about Toshiba SD-3980 DVD Player
My sd3980 dvd player wont turn on - Toshiba SD-3980 DVD Player
  • Brian Manuel Mar 19, 2011
    have you checked the outlet or the cord?
Some new dvd/vcr combo (or just dvd players) NEED to be plugged through either the HDMI or component cables (blue/green/red cables) in order to view the DVDs.
Try one of those to see if it fixes your problem.
P.S. don't forget to change the input of your TV to either the connection you are using for the DVD (HDMI or components)
Posted on Mar 22, 2011
How unlock a Toshiba sdv398kc dvd?
Toshiba SD1200 / SD1600 / SD1700 / SD210E / SD2109 / SD2150 / SD220E / SD2800 / SD3750
  1. Insert DVD with foreign region code
  2. Wait for the error message to appear
  3. Press M (Memory)
  4. Press 1
  5. Press PLAY
Toshiba SD120E / SD125E / SD220E
  1. Get the multi-region update disc for the SD220E (http://www.geocities.com/its_yahell/toshiba_sd220e.html)
  2. Write it in DAO mode
  3. Switch on DVD Player
  4. Press SETUP
  5. Under the Picture option change Pal/Auto setting to Auto
  6. Press SETUP
  7. Insert the update CD
  8. The following images are displayed: ?'Nabe the Wiz?' and then ?'FIN?'
  9. Remove CD
  10. Switch DVD Player On/Off
Toshiba SD240 / SD350E / SD3960 / SD3980
  1. Open the disc tray
  2. Press 2, 4, 0, 3, 9, 6, 0
  3. Select region using ENTER (9 = multi-region)
  4. Close the disc tray
  5. Power off
Toshiba SD3109
  2. Insert foreign DVD
  3. Close the disc tray
  4. Press STOP before the error message is displayed
  5. Press "T" twice
  6. Enter a time of one second
  7. Press PLAY
Toshiba SD43HK
  1. Turn on the player (without a disc inserted)
  2. Press ENTER
  3. Press 8, 4, 2, 6, 9
  4. Press ENTER
  5. If the player doesn't turn off automatically, turn it off
Toshiba 23HLV84 / SD-24 VLSL / D-KR2 / D-R1 / D-R2 / D-R255 / D-R4 / D-VR30 / D-VR4 / MD13N1 / MD13N3 / MD13P3 / MD14FN1 / MD20FM1 / MD20FN1 / MD20FP1 / MD20P1 / MD9DM1 / MD9DP1 / MW20FM1 / MW20FN1 / MW20FP1 / MW20FP3 / MW24FM1 / MW24FN3 / MW24FP3 / RD-X2 / RD-XS34 / RDXS30 / RDXS32 / RDXS52 / RSTX20 / RSTX60 / SD1008 / SD100X / SD106E / SD114E / SD1209 / SD1209 / SD114E / SD1209 / SD1300 / SD130E / SD1402 / SD140E / SD145E / SD1850 / SD1900 / SD2006 / SD2008 / SD2108 / SD214E / SD22VE / SD22VL / SD245 / SD248E / SD24VB / SD250E / SD2600 / SD2650 / SD2710 / SD2715 / SD2805 / SD2810 / SD2815 / SD2850 / SD320V / SD324ES / SD34VL / SD35VF / SD36VESE / SD3860 / SD400V / SD412V / SD4205 / SD44HK / SD4960 / SD500E / SD5205T / SD5907 / SD5915 / SD5980 / SD6915 / SD9100 / SDH400 / SDK200 / SDK220 / SDK330 / SDK350 / SDK530 / SDK730 / SDK740 / SDK750 / SDP1000 / SDP1400 / SDP1500 / SDP1600 / SDP2500 / SDP2600 / SDV290 / SDV291 / SDV390 / SDV391 / SDV395 / SDV396 / SDV593 / SDV65HT / VTD1420 / VTD1431 / VTW2185
Dec 17, 2016 | Toshiba Televison & Video
Mp95 wont turn on. The battery pack wont charge and player also wont turn on while power source is hooked directly up to dvd player without battery pack. Please help?!?!
The battery it is dead,even u plug the dvd player power in directly into the power source.Must have the battery inside and the must have some juiced left before for the dvd player to work.Tries websites like Partstore.com,Amazon.com,Ebay.com to buy a new battery or a compatible one.
May 09, 2011 | Mustek MP95 Portable DVD Player
Dvd player wont turn on..
No brand/no model number= only general reply.
If the fuse blew, it is indicative of a failed power supply.
Always include needed information since no one can help yo unless you help us.
Dec 29, 2009 | Televison & Video
Toshiba DVD player SD3980 Keep getting an incorrect disc or bad message. Have turned it off & tried other discs.
check spindle motor,flexible wire, if this two is ok then your laser is at fault, note; be aware on installing flexible wire if its incorrect it may impair the operation of sled motor , clean clogs and dirts on sled gears
Oct 13, 2009 | Toshiba SD-3980 DVD Player
Wont turn off
Acually there is a setting by which you can activate " Auto Power Off" in your DVD player. You can make that setting and it will be automatically off after DVD finishes.
May 13, 2009 | TruTech TT320
I cant open the dvd tray on my SamsungDVD-P241
turn off unplug ...turn upside down...this may dislodge it disk...gently shake...this may take a few tries
Dec 10, 2008 | Samsung DVD-P241 DVD Player
Toshiba SD3980 is displaying "incorrect disk"
it usually means that you either have the disk in upside down or its rejecting the disk for a number of reasons such as the disk is scratched or it has something stuck to the bottom. Hope this helped.=)
Feb 25, 2008 | Televison & Video
My Daewoo dvg-9200 dvd player wont turn on
take it to a tech the problem is in the power supply.good luck.
May 18, 2007 | Daewoo DVG-9200N DVD Player
Toshiba SD-3980 DVD Player Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
