Question about Acer Aspire X1300 (PV.SCC0X.002) PC Desktop
The monitor keeps saying no signal - Acer Aspire X1300 (PV.SCC0X.002) PC Desktop
  • Brian Manuel Mar 19, 2011
    have you tried looking at the connections ,the cable
  • 3,799 Answers
Turn power off to the tower and the monitor before making any connection changes.Make sure that the Blue connector from your monitor is connected to the Blue connector on the back of the computer tower. If this doesn't work you should try the monitor with another computer, just to check that the monitor is working. If the monitor works on another computer you may need to buy a Graphics Card. Next, try another monitor with your tower- If the problem still exists it is likely you need a Graphics Card.
Posted on Mar 19, 2011
Why does it keep "saying" out of range?
if camera and base are within a few feet of one another does it have a problem obtaining a signal (syncing ) ?? as if it works ok then there might be a object that is getting in the way of the signal , radio waves move from its transmitter (camera) towards its receiver (monitor) in a straight line , if there is too large a mass in the way then the radio wave can't penetrate it and will be "lost" also ck both the camera's and bases battery levels (if they have one) for proper peak power level , as it takes energy to drive the radio signal towards its receiver .
Feb 09, 2016 | Summer Infant Secure Sight Handheld Color...
Acer ASpire M1100 shows No Signal on monitor
Any time a monitor says "no signal" that message is originating from the monitor itself, and not from the computer. A monitor in a room by itself with no computer will say "no signal" for a brief time, if it is turned on. So, if you have tried other monitors also with no luck, then the problem is either the video adapter of the computer, or something that is keeping the computer from booting in the first place (power supply, hard drive, memory, motherboard). A power supply can be tested with an inexpensive tool. Everything else needs either a swap out with a known good stand-in, or else an expensive tool to know if it works.Does the fan come on when you turn the computer on? If so, maybe more likely to be the motherboard, hard disk, or memory. If not, more likely to be the power supply.
Feb 02, 2012 | Computers & Internet
My monitor keeps saying "no signal". I confirmed
No Signal on your monitor says it is not receiving a signal from your computer... this could be:
1) the cable is bad
2) the cable is not plugged in firmly
3) your monitor is set to a different source (such as VGA or HDMI) and simply needs to have the option set.
4) the video card or onboard video electronics have failed.
Suggestion: If none of the above seem to be the problem, and if your computer AND the monitor have a VGA connector AND you have a VGA cable. Try that. If that works, its a strong indication that the DVI circuits have failed either in your monitor or in the computer's video electronics.
Aug 28, 2017 | Envision 19" Widescreen Flat Panel TFT LCD...
I installed 17" LCD Acer
If you have a graphics card make sure that the 'signal' cable is attached to it rather than your motherboard's built-in graphics port. other than that, make sure you have the drivers for the monitor.
Aug 25, 2011 | Computers & Internet
Keeps saying "no signal -
I'm not sure what you are plugging this into, or through what type of connection; but if it is plugged into VGA make sure none of the pins are bent on either side of the cord, also make sure it is set to pick up the signal from the right input. If you need anymore assistance with this please let me know.
Apr 11, 2011 | Planar PX191 19" Flat Panel LCD Monitor
Says No Signal but I clearly just pluggd it in and turned it on, and yes my computer is on
The "no signal" message is telling you there is no output from the computer. The output signal switches on the monitor, so if not there, check your cables and connections. If you have another monitor, try connecting it instead, and see if it works.This is an unusual problem, so keep trying. Connect the monitor to another computer, such as a laptop, and see if it works. If the monitor on another computer works, obviously it the first computer. If the first computer works with the second monitor, it's the first monitor.
Mar 31, 2010 | ViewSonic VA903B Monitor
AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
Sep 20, 2009 | AOC LM729 17" LCD Monitor
Check signal cable
Turn off the monitor first.
Hold down Function button and click F8 key to tell the laptop to send signal to the monitor.
Apr 20, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Monitor saying no signal
check the Pins in the monitors serial port and make sure all are straight 15 of em
Jun 03, 2008 | Computers & Internet
Acer Aspire X1300 (PV.SCC0X.002) PC Desktop Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
