Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
I have SMEG 60 cm Single electric oven model SA398X which refuses to start. It has a single A which I understand stands for automatic. I have turned the power off and on and have tried a reset of the clock by pressing the far right hand button on the clock and + button together all to no avail. I have also tried pressing the far right hand button on its own but it doesn't seem to transfer back to manual. We have had similiar issues in the past where it won't work for several days then clicks and is operational. Any assistance would be appreciated
  • 1,998 Answers
Hello sandcmcc,
you would need to be able to take a multimeter and test from the control to the switch and then from the switch to the element sometimes u can have power going to the control and not leaving the control in this instance you would have to replace the control if on the other hand it leaves the control and goes to the switch sometimes a switch may either arc on the inside of the switch making the switch stay opened in which when this happens the power would not go off or arc closed in which you would not be able to turn on the unit no matter which setting you set the switch to lastly you would assure that power is going to the element and you could also do a continuity test to assure that the element has no breaks in it. personally this sounds like a switch issue that you are having if you are unfamiliar with performing electrical tests i would suggest you call for a techncian. It is always better when it comes to electricity to be safe then sorry. if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Posted on Mar 19, 2011
  • Rick Ead
    Rick Ead Mar 19, 2011
    also i just reread your comment if the power does not leave the board this could also be due to either a fault in the control board or the touch pad itself. all in all it sounds like either the switch or touchpad or control issue if one side of the control works yet the other doesnt this most likely points to the touch pad or the control being the problem also you may want to check for any loose connections this sometimes does happen due to vibration and it is also possible that maybe one of the controls connectors is starting to unseat from the connected postion that it should be in once again if you are able to do the tests conduct your tests and message me back your finds I await your reply Thanks Rick
  • Rick Ead
    also if you have had any other conversations with any other techs on this matter I am also not able to see these Thanks Rick
The house I've just bought has a Smeg 60 cm wall oven installed. Possibly 4-5 yrs old. I can't get it to work. An orange light comes on on the door panel when the temp control is turned on. Light goes...
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
Feb 07, 2011 | Smeg SE399X/5 Stainless Steel Electric...
Smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Apr 10, 2008 | Smeg SE280X Stainless Steel Electric...
Dials of our smeg oven have rubbed off
You need to disclose the model for any help.
Mar 06, 2017 | Smeg Ovens
My smeg oven is turning on automatically and we don't know how to stop this
The contacts have welded close on the switch that controls whatever element that comes on automatically. Replace switch
Jun 27, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Noisy fan in Smeg oven SA398X
Does the fan sound like a squeling or rumbling?Is the fan blade itself scraping on something?
Apr 18, 2009 | GE JGRP17 Gas Single Oven
Smeg SA995XR Oven
Hello, I know this was a while ago when it was posted. But do you still need a manual? I can email you one if so!
Sep 08, 2007 | Smeg S1100MFX5 Electric Single Oven
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
140 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Smeg Oven Expert? Answer questions, earn points and help others
