Question about Linksys WRT300N Wireless Router
My Linksys WRT300N router will not show up on my network. Also the power light will not stop blinking no mattter what reset trick , option, whatever I try to do.
    Problem Solver:
  • 12 Answers
When the power light keeps blinking that means your firmware may be corrupt. Follow the directions on this link and it should solve your problem hopefully.
http://www6.nohold.net/Cisco2/GetArticle.aspx?docid=bdb4a0a3a85e49efb91cedc21241e779_3735.xml&pid=80&converted=0
Posted on Mar 19, 2011
Power light is dim and the 4 ethernet connection lights are bright green - even without a cab. Linksys WRT300N
First try unplugging it for about 45 seconds. Then plug it back in.
If this does not fix the problem try to reset it via the reset button on the back and see if that fixes the problem. This will make your network un-secure and you will have to add a new pass phrase.
Let me know if this solves the problem.
Mar 27, 2011 | Linksys WRT300N Wireless Router
My linksys WRT300N router is Not working. The lights are all solid and it wont reset. Please help
Hi, we can hard reset the router for about a minute, powerlight should be blinking the moment we reset the router, if case still all lights are lit but powerlight is solid. We can do these steps:
> Connect computer to router
> Open control panel - network connections - right click local are connection
> Click status and go to support
> Check for IP address, if we have IP: 192.168.1.x IP address on the computer
> Please open command prompt
- (for WinXP) go to start and click run, type cmd
- (for win7 and winVISTA) click start and type on start search cmd
> On the black screen, there is a blinking cursor type ping(space)192.168.1.1
> If we are getting Request timed out - that means router is defective
- if we are getting Reply from responses... then there is a need to upgrade the router...
Let me know if you still need help...
Dec 22, 2010 | Linksys WRT300N Wireless Router
The power light keeps blinking.
My friend,
Try resetting the router for 30 seconds .
Still if shows the light .
Then dispose this.
Dec 17, 2010 | Linksys WRT300N Wireless Router
Cannot connect to wireless Linksys WRT300N router. Power off/on, but only the internet indicator ON, wireless indicator OFF... Router is diagnosed as hardware failure, just want to see if there is...
Hi Friend,
You need to try hard reset of your router. Please follow the steps:
1. Power on the router.
2. Push and hold the reset button for 10 seconds (watch whether the power light blinks or not)
3. Turn off the router for 10 seconds and switch it on.
4.Once the power light is steady then perform the steps 1-3 for 2 more times.
5.If the wireless light still shows off, then kindly get in touch with the Linksys technical support centre.
If the wireless light turns to be good and steady then follow the steps to configure the wireless settings:
* Type 192.168.1.1 in the address bar of the web browser and hit enter.
* Type admin as password and leave the username blank
* Click Wireless and fill the sections as mntioned:
Network Mode: Mixed
Netwrok name: As per your choice
Radio Band: Wide-40mhz
Wide Channel- 6
Standard Channel:1-2.412GHZ
SSID Broadcast: Enabled and click save settings.
* Click Wireless Security and fill the sections as mentioned:
Security Mode: WPA Personal
Encryption: TKIP
Pre-shared key: Any ten digit number and click save settings.
turn the router off for 30 seconds and swithc it on. use the pre-shared key to connect your wireless devices.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 08, 2010 | Linksys WRT300N Wireless Router
My WRT300N Linksys router shows all lights, I've hit the reset button onece, but I can not get online without plugging the cable directly into my computer.
Since you hit the reset button on the router, it will go back to default settings.
By default, the SSID is linksys and the wireless security is disabled.
So on the wireless network connections on your computer, you should see linksys and then just connect to it.
However, it is advisable to change the default SSID and to enable the wireless security.
Follow this link to change the SSID.
Follow this link to enable wireless security.
Dec 30, 2009 | Linksys WRT300N Wireless Router
I just rewired all my network connections, my wrt300n wireless indicator is not lit. The network is set up on a linksys broadband router on a cable modem and wrt300n was functioning properly when it was...
Try first resetting the router by pressing the reset button of the router fro 10 seconds while power is ON and then after that reconfigure the router.....
Dec 07, 2009 | Linksys WRT300N Wireless Router
Linksys wrt300N wireless light not blinking
the wireless connections says limited or no connectivity when it does not get IP address from the router.
There might be problem with the wireless settings of the router.
if your network is a secured network then you will need to check the network key.
You can try to upgrade the firmware of the router. that will be a good option.
Click Here for step by step solution
Oct 29, 2009 | Linksys WRT300N Wireless Router
My wrt300n power led is blinking and the rest of
Hi Friend
Please follow the steps to reset the router in a different way
1) Press the reset button for 10 secs and after that unplug the power cable from the router and wait for 10 secs
2) Plug the power cable back and press the reset button again for 10 secs and after that unplug the power cable from the router and wait for 10 secs
3) Plug the power cable back and press the power button for 10 secs again and unplug the power cable from the router for 10 secs
After trying these steps if you see the power light still blinking then you need to replace the router. Please call the customer care of linksys 1800 546 5797,they will let you know how to replace the router
warm regards
Chiranjeet Mitra
Oct 06, 2009 | Linksys WRT300N Wireless Router
Wireless light does not come on or work.
hi
first of all you need to remove dlink from the network
once you do that attach linksys and in your laptop type cmd in run box and then click ok once you do that it will give you a command promt then in command prompt type ipconfig and hot enter,,once you do this it will give you a ipaddress and default gate way for the linksys and then go to internet explorer or any browser and type the default gate way number on the address bar ,,once you do that it will open up the router page for linksys and you can do the desire setting change on the router ,,,,,,,if not you can contact me on fixya
Aug 07, 2009 | Linksys WRT300N Wireless Router
WRT300N dosnt connect
if your connection (isp) is CABLE you will need to clone the mac of the main computer.
For cable connection verify what computer can go online with your modem, once you know the main pc connect it to port one, access the routers setup page by typing 192.169.1.1 then locate MAC ADDRESS CLONE in line with basic setup. enable it click the macclone button then save settings.
connect your modem to the internet port on the router, do a power cycle on the modem and router.
then check the status tab on the linksys setup page if you have numbers on the dns it should be online.
Sep 12, 2008 | Linksys WRT300N Wireless Router
Linksys WRT300N Wireless Router Logo
500 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
