Question about HP Lc4276n 42 in. LCD Television
My HP LC4276N TV is 27 months old. A few days ago, the sound just ceased working. Of course, I checked the settings to ensure that "mute" was not activated and that the setting for speakers was "on". I then also tried connecting auxiliary speakers, but to no avail. Could this have been caused by a blown fuse? A bad capacitor? Or is there another likely cause? I would love any detail on how to check any of these potential problems, or any suggestions for repair. (I have no experience in this sort of thing, but I know to be careful regarding the stored powerful current in the back of the unit.)
  • 6 more comments
  • snixter Mar 19, 2011
    Thank you for your response. However, my issue is not one of it not turning on -- it turns on easily every time. The problem is only the sound. While the TV was on and functioning properly, I was using the DVR to rewind, and after resuming "play" (live TV), there was no longer any sound. Changing channels, turning it on and off overnight -- nothing I do will bring back any sound whatsoever.
    Unfortunately, the resetting and re-powering did not recover the audio. Any other ideas?
  • snixter Mar 20, 2011
    Hi. Thanks for your response. I connected a set of external speakers, but I only heard a thump sound from them when I first plugged them in. There is no audio whatsoever with the TV. Picture is fine, everything else functions as usual. (There was not even a faint thump sound from the TV speakers.)
    Thank you. I will check for fuse issues tomorrow evening. (I will be tied up until then.) I'll report back to you late Sunday.
    I tried adjusting the volume control on the external speakers, but that only adjusts the thump sound that comes out of the sub woofer when I turn it on. No audio comes out from any speakers.
    I did all that previously (check the speaker "on" from the OSD menu). That was one of the first things I checked. And I have double checked it.
  • snixter Mar 21, 2011
    OK. Thanks!
  • snixter Mar 28, 2011
    The problem turned out to be a bad connection between the coaxial cable from the street going into the Cablevision box. (The communication between the box and the TV is via HDMI.) I tried connecting the TV to a different cable connection in a different room, and, lo and behold, the audio worked. I don't know why the only the sound malfunctioned (while the picture was fine), but that connection at the box turned out to be the problem. Thanks for all your help -- it may very well be useful in the future.
    Top Expert:
  • HP Master
  • 75,591 Answers
Hello
You haven't specified anything about its picture condition. Anyway, picture is correct, and only sound has probelm I assumes and answers. If picture is OK and oly sthere is no sound at all, check the speakers first. You can chek it without opening the TV. Place your ears very near to the speaker side of the TV, and switch it ON. if you can a "Thumb" sound [may be very small in amplitude]; speakers are OK; either the sound output section or sound detecting section inside the circuit bard is faulty. To confim which amoung this two is faulty, connect its audio output RCA sockets to any external audio equipment like amplifier or so, and check whether sound comes from it or not. If there is sound output through external amp and not with TV speakers, surely Audio Output Ic has the trouble and should be replaced with an identical type and number. If there is no sound from the amp also, that means the sound detection side circuits has got damaged. You must have experience and more skill to detect fault in this section. As you indicated that you have not much experience, leave it to any experienced technician to do. OK.
Posted on Mar 19, 2011
  • 5 more comments
  • The Knight
    The Knight Mar 19, 2011
    Hello
    As far as picture is OK, there must be sound. You just check the process I described you early, and give me details by Fixya. OK.
  • The Knight
    The Knight Mar 20, 2011
    Hello
    I've placed a comment to you about 12 hours ago. You did't give me any information about it. I can't see anything about it in my window. whout checking it, and without post anything, what answer should I give to you? Please clarify the results of the thests which I've adviced you to do and what was the effect. OK.
  • The Knight
    Hello
    I thinks that the comments you posts to me won't reach to me. Just do one thing. Send a mail to me and check whether your service providers server distributes it to worldwide or not. Send a mil to me at the folloing mail address of mine , and make confirm about the delivery. If you have any to report me, you can do it by mail also. OK.
  • The Knight
    Hello
    Where do you post your comments? I can get its alerts, but nothing can be seen in my window. If you perists this fault, report it to Fixya. There may be some trouble with your site. Report it to them. Their engineers will rectify it. OK.
  • The Knight
    I got one now. Check it connected with external speaker,a nd increase the volume of your external device you have connected with your TV and find whether it works fine or not. If it works fine, and there is no "Thumb' from TVs internal speakers, make sure that either the speakers of audio output IC inside your TV, or both of the are defective and shoul be replaced. OK.
  • The Knight
    Hello
    Do one thing more.
    Are the TV speakers turned off in the onscreen display (OSD) menu?
    Press the Menu button to open the OSD. Press the down arrow button
    to select Audio, and then press the OK button; press the down
    arrow button to select Speaker, and press OK; press the down
    arrow to select On, and then press OK. Press the Menu button to
    close the OSD.
  • The Knight
    Hello
    Audio detection section inside your HP tv has damaged. It should be replaced as card basis. Eventhough your TV is Branded as "HP", the actual circit board and other things inside are of "Sharp". Only brand name and appearance have been changed. You informed me that you haven't enough knowledge in electroncis, and havent got experience in repair. So it is best for you to leave this work to any experienced technician nearby you. It is a skilled work, and and some critical service adjustments should be done after service. Never attempt to repair it by yoursef, as it may damage more components. Audio detection cards are of may types, and you have to determine which type has to be used, and which type is used in your TV. OK
  • HP Master
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
  • 1 more comment
  • Norman Skinner
    Norman Skinner Mar 19, 2011
    Sorry, I must have been in a bit of a hurry at that moment but the idea was to show how to identify and replace bad capacitors.
    Lets do a reset on the unit
    Press menu
    Go to DEFAULT SETTINGS and press OK.
    Unplug and replug the unit into power
    See if audio has returned.
  • Norman Skinner
    Well, you already checked the mute and speakers on and we did the reset, so that should have taken care of SAP or anything like that...
    I'd take a look at the source itself. IE - if it's a sattelite receiver, is there sound coming OUT of the receiver INTO the TV...try a few different sources.
    If you still have no sound, then it's time to start looking for surface mount fuses. They can be white rectangular boxes, flat green tiny fuses or 0 ohm resistors.
    They may be in the power supply section of the TV or the audio section of the main board.
  • Norman Skinner
    Norman Skinner Mar 28, 2011
    Hope you had a chance to check on those fuses...you said you'd report back late Sunday, and it's now early Monday, so I was concerned that maybe you didn't have time to get to it.
Broksonic 19 inch CCVG 1935 - no sound, no picture, just a blue screen
Blue screen means either no signal (if unit has rear connections hook a DVD etc to one and go to that input and see if it works) Or the blue may mean set is in shutdown----5 months old and it should still have a warranty?
Apr 23, 2012 | Broksonic CCVG1935 19 in. LCD TV
I'm not getting verbal directions from my Garmin nuvi 260W. How can I fix this problem. A day ago it was working properly.
If you are not receiving any sound on your N?vi 2xx thefirst thing to check is that the sound is not muted. To ensure that your unitssound is not muted please perform the following: Turn the device on Press the Volume button on the 'Where To?', 'View Map'screen Ensure the Mute box is not 'checked' If the mute button is not 'ticked', you will need to changethe voice to ensure that the preset voice is not faulty: Turn the device on Touch the Tool icon Touch Settings Touch Language Touch the language voice next to Voice Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you arerunning the latest software which can be done by installing a program calledWebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the softwaresuccessfully installs.
Jan 21, 2011 | Garmin nuvi 260W GPS Receiver
Hello, I have a pair of JBL Platinum Series speakers linked to my PC, which are just a few months old. They were working well, but they have stopped working. Although the green light comes on when I turn...
Hi Lauren This is the process of elimination which i would follow in a similar situation: -check cable going from computer to speakers, make sure both ends are plugged in correctly; -ensure sounds are not muted on your computer;
-try to play a song using another program such as windows media player. If this works, it's most likely the iplayer program which has been muted. -If none of this has helped, try plugging the speakers into a different device, such as a stereo headphones jack, ipod headphones jack, even a TV headphones jack. If the speakers still do not work, they are probably no good.
Hope this helps, Benji
Oct 02, 2010 | HP JBL Platinum Computer Speakers
My volume is not working
go to start>run
type services.msc
go to services.msc
check sound service if its is enabled or not
if its not enabled then right click on service
select properties and start the service
still if its not working download sound drivers again.
May 07, 2010 | HP Compaq 6720s Notebook
It is an analog Zenith TV, model #A27B33W. Initially, both the display and the remote worked. It was a gift from a relative and was functioning normally, with and without cable input--though was not...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 10, 2017 | Zenith A27B33W 27" TV
A month ago our house was struck by lightning and The Insurance company wants to know what the price of the Television. Or what it is worth today. He purcheased the TV about 4or5 years ago. the tv was...
$150 usd- $177usd. SEE HERE
$200 SEE HERE
Quote from the link...
" My Bottom Line
Considering the price, I am pleased as punch with this purchase. Expecting to receive only basic features, the Orion shouldn't disappoint. Audio buffs should look elsewhere, but at a purchase price of approximately $150 for a 27" TV, one isn't looking to the STV2763A as a high tech set. I'm sure I'm forgetting certain specs here, but this my low tech review of a low tech set. I'm happy with the Orion, a nice balance of value and price."
Amount Paid (US$): 177.00
Since it is 4-5 years old look to get less than half from the insurance co.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 07, 2009 | Orion STV2763 27" TV
Turned off spontaneously -- won't turn back on.
It sounds like a bad power supply or inverter or possibly a bad circuit/power control board. If there is no juice at all to the unit, U might want to check the power supply before suspecting a bad board.
May 01, 2009 | HP Lc4276n 42 in. LCD Television
No sound dell 32in tv
These are the answers straight from the dell manual. Ensure that the audio cables are firmly connected to both the audio input connectors on your LCD TV and audio output connectors on your PC or Video player. If on certain TV channels you receive a picture but no sound, this means that you do not have the correct TV system. Modify the SYSTEM setting. Check if TV volume is turn off of muted Connect the audio cable securely Audio cable is connected incorrectly Verify that the audio source is selected correctly in the OSD
Jul 31, 2007 | Dell W1700 17 in. HD-Ready LCD Television
TV wont turn on?
this product has a bunch of exotic semiconductors that only a tech could replace in my parleyance its called NECO
Dec 08, 2006 | RCA 27R410T 27" TV
HP Lc4276n 42 in. LCD Television Logo
102 people viewed this question
Top HP Televison & Video Experts
Computer Links
vbalag
Level 1 Expert
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
