Question about Samsung RS2534 Side by Side Refrigerator
Ice maker is not working
My tray is turned almost upside down. I tried the reset button, and that did nothing. So it's stuck there. Any ideas? Thanks!
  • MilneMan Aug 02, 2008
    Some other info, it's a Samsung RS25335W.
  • 3 Answers
Make sure you remove the ice bucket when you press the reset button. if the ice level arm gets stuck it will not rotate. also if the rotating spindle at the back is jammed nothing will move.
Posted on Sep 10, 2008
Lg lfc 21770 ice maker
The defrost heater on your ice tray has failed, Replace the ice tray is only solution, sensors are having trouble as well due the heater problem. Does not know where it is in the cycle, also sounds like the gear on the ice maker is shot due to build up, replacing the ice maker should sort all issues out. If you cant find one, send me a email to WGHEAVEN@Yahoo.com.au and I'll send you one. Regards Russ
Jul 01, 2012 | LG LFC21770ST Stainless Steel Bottom...
Samsung ice maker tray won't reset
I had the same problem and would "temporarily" fix it by opening the front plastic cover (remove the 4 screws) and CAREFULLY remove the front - sometimes all the plastic gears will fly off but you can get them back because they only fit one way. Once the gears are off, you can reset the tray back to its fill position. Fit the gears back into place. Replace the front cover and it worked like a champ for a couple of weeks when I'd have to do it all over again. I finally got tired of it and ordered a new unit through ebay. Easy to replace BUT now the water won't come on to fill the tray!!!! UGH Hope this helps
Sep 21, 2009 | Samsung RB215LASH
Brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
Water won't pump to the ice maker.
No button to push. It sounds like the solenoid valve which opens to fill the ice tray is not working. Not getting power, stuck, faulty.
May 08, 2009 | Refrigerators
Whirlpool fridge icemaker stuck upside down (side by side fridge)
it seems the ice maker cam asm is broke it will have to be replaced
Dec 20, 2008 | Refrigerators
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Ice maker
there is a solenoid in the back of the machine that operates that lever on the bottom of the ice bin. make sure that the lever is properly engaged and not stuck jammed etc.
Apr 07, 2008 | Jenn-Air JCD2295HES Side by Side...
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
664 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
