Question about Dell UltraSharp 1907FP 19" LCD Monitor
No power to my Dell 1907fpc
Hi was wondering if any one knows if this is a common fault? and if there is any way i can fix it at home. Any assistance will be grateful. Thanks in advance Alex
Read a really good description of a repair to a similar model Seems the inverter boards go bad on the Dell LCD monitors quite frequently. This guy did a real hack job, but as he says in his description - it lives!
http://www.josepino.com/other_projects/index.php?howto-repair-dell.jpc
Posted on Oct 24, 2008
Pry the frame from the front of panel and you should see the circuit board for the buttons.  Unscrew that and you should be able to see the board itself and turn the monitor on from there.  I placed a small plastic piece between the button and the board and it works.  Hope this helps.
Posted on Aug 18, 2008
My Vauxhall mariva 2011 has loss power in the steering is this a common fault for age of car
It was a common fault on the earlier year cars with the electric power steering system and if you are having the same issue then GM UK still have not fixed the issues in later models. 2011 is not an old car and a vehicle of that age with a typical hydraulic power steering system would not be failing. You will probably find one or more critical sensors in the electric PS system you have has failed and in that event the whole power steering system has shut down. Once the electric motor that provides the steering assistance is shut down you have no power assistance whatsoever.
Vauxhall Meriva power steering
Jun 27, 2016 | Vauxhall Cars & Trucks
Hi my eps light is comming on and i lose power streering how do i fix it
It cannot be fixed until the problem with the Electronic Power Steering(EPS) is properly diagnosed.
The power assist system is comprised of...
  • EPS computer unit
  • Warning light on the dashboard
  • A connection to the OBD2 Diagnostic port in the car
  • A Vehicle speed sensor
  • A sensor which detects steering rotation on the input shaft of the steering rack
  • An electric motor, which provides the power steering assistance to the steering rack. Unless that motor runs you will have no power assistance to your steering.
  1. You will need to have the system scanned with the appropriate scan tool through the OBD port in the car. This will generate various fault codes which assist in diagnosing where the problem lies in the power steering system. It may be just a failed sensor that needs replacing or it might be a bigger problem.
  2. Once the fault codes have been pulled the mechanics can diagnose the cause and make whatever repairs or parts changes may be required.
  3. This is not a do it yourself exercise. You will need a mechanic who knows these Japanese electronic power steering systems and who understands the fault codes (and there are many of them on this EPS system) to diagnose the problem for you and fix whatever fault(s) has arisen.
Dec 30, 2015 | Daihatsu Cars & Trucks
I have Dell 1907fpc monitor. The image flickers and finally darkens. how to resolve the problem?
It sounds like your LCD Backlight/s are going out. To fix you will need to replace the LCD screen inside the Monitor. It may be more feasible to replace the Monitor.
Feb 24, 2011 | Dell UltraSharp 1907FP 19" LCD Monitor
I have a dell 1525 and myy laptop turns on on no display
Hi this is a very common problem with all flip and slide phones and even laptops and notebooks, the problem is to do with the data ribbon that connects the screen to the circuit board in the bottom of the laptop.
now inside this ribbon are several single strand copper wires and over time open and closing the laptop causes these to break and you then lose the connection with the screen.
as this is such a common fault it makes the part itself cheap to buy and cheap to get fitted. it isnt something you can do your self as you need specialist tools to take the phone apart and to fit the data ribbon.
if you want it repaired the cheapest place would be one of those small independent computer repair shops as the bigger one will have to send it off and you will be charged extra for this, the smaller repair shop should be able to fix it next day at the latest.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 10, 2010 | Dell Inspiron 6000 Notebook
I have an option to get the Dell W4201CHD Plasma tv for $100. However, They say that it will not power up. Does any one know how to go about fixing it or the price range it would cost to get it fixed at...
If the tv doesn't power up then the fault is big. Even if it's only in the power source if you don't have a  god experience in electronics it will cost you over $250 to call a repairman to fix it for you.
This was sold for parts, it's not for you.
Sep 07, 2010 | Dell W4201C 42 in. Plasma HDTV
Burning cds
hi thanks for using fixya!!
Yes, ofcourse, you may do burn CDs. If you want you may install NERO to your system.
If you need further assistance, let me know.
Apr 26, 2009 | Dell Latitude D600 Notebook
My TV keeps turning itself off
Try resoldering the flyback transformer. Thats a common fault if that doesnt help you may need a replacemeny flyback, as thats the number one fault with that model is the flyback wearing out. If you need more assistance let me know
Jun 17, 2008 | RCA HD52W59 HDTV Projection Television
Dell computers are hard to upgrade.
hi will
yes these cards uses a lot of power. Check to see if the power supply pushes enough power to run the video card. I think these card needs its own power source so make sure you use a sepearate cable from the powersupply to the video card and not share it with other components.
if you have less than 400w powersupply thne this is morelikely your problem
good luck
smeags.
Dec 12, 2007 | ATI All-In-Wonder® 2006 Edition RADEON®...
Dell UltraSharp 1907FP 19" LCD Monitor Logo
444 people viewed this question
Alun Cox
