Question about Acer X241Wsd Monitor
My X241w until recently required about 10 or more power ups before it would stay on without shutting itself off. As I was getting ready to replace it I tried setting the resolution to 1980x1080 in preparation for the max res. of the new monitor. The x241w wouldn't adjust. I consequently set my Acer AL2223W up as the primary monitor. After a shutdown and powerup of the whole system from the surgeprotector the problems with the x241w stopped. It is now working normally again. The way to fix an errant monitor is to show it it's replacement. This will work every time.
  • 11,361 Answers
It may have a lot of dying caps as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/ACER%20X241W/
More damage will be done if the caps get real bad.
The size of this monitor is big but I find the picture quality is not too good.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 19, 2011
2002 Hyundai Elantra that says my on board computer is not ready to be tested. Emission results are: readiness- fail, monitor comprehensive- not ready, monitor EVAP not ready,monitor O2 not ready.
Did you recently clear the trouble codes or disconnect the battery? Once all codes are cleared, the computer will not display systems 'ready' until they go through an evaluation cycle. Some of the systems require a certain number of drive cycles before they will display 'ready'. A drive cycle is usually starting the engine from a cold start (based on coolant temperature) and driving until certain conditions are met. I don't know what the requirements are for your car, but my 2003 pickup truck requires more than 10 drive cycles before it will make the O2 sensors and evaporative emissions 'ready'. Most states only require that a certain number of systems are showing 'ready' to pass emissions certification.
Oct 22, 2016 | Hyundai Motor 2002 Elantra
Samsung TV shutting off by itself and relays clicking
If you don't know what you're doing, don't open it up to fix it!
There are HAZARDOUS voltages on the power supply board EVEN WITH THE TV UNPLUGGED!!! The capacitors can hold a charge for several weeks!
Clicking noise can be coming from bad capacitors on the power supply board.
It's usually easier to just replace the power supply board.
Sep 09, 2016 | Samsung UN55B8500 TV
New phone that I've used for a week without problems. Yesterday it shut itself off and I tried to charge but it won't stay charging and I can't get it to stay on. It will say it is charging for about 30...
Battery of device been depleted completely of functionality requiring a new replacement. Refer with the device user for details with power malfunctions also recommending direction to resolvment
Apr 04, 2011 | Cell Phones
My A215 wont stay powered up. It shut down and
Try running the computer on the Battery power and check if the power sustains. If not, then disconnect the power cord and remove the battery and leave it for a few hours then try turning it on.
If the problem exists then the power supply unit is required to be replaced. You may contact service center to get the power supply unit replaced.
Oct 01, 2009 | Toshiba Satellite A215-S7422 Notebook
RICOH FT 7650 shuts itself off when not in use after 45 minutes
Enter in the user mode:
1.Press the Clear mode key.
2. Press the Clear/Stop key more 4 sec untill the user tool menu appears on the touch panel.
3.This copiers has more 12 user tools.You can see 5 user tools on the display at the same time.Use these keys to see the rest .
4.AUTO RESET: the copier return to the initial condition autommatically after your job is finished.(after 60 sec)
5.SCREEN SAVER :when the copier does not detect anyone operating it for selected time the display turns OFF.(60 sec).
6AUTO OFF:Whwn the machine is used after weekly timer has turned it OFF the copier will turn itself back OFF after the selected time.The auto OFF time can be set from 1 to 999 minute or the function can be turned.(I recomanded setting level OFF).
Aug 31, 2009 | Ricoh Aficio 450 Copier
Our tv made a loud high pitched noise for a few weeks and then the color went green to then shutting off. Now, when we try to turn on the tv, the light blinks and then it just shuts off and keeps repeating...
Hi, Symptom shows high pitch sound is of color wheel that is not spinning any more so TV stay in protection mode and does not power up. TV requires color wheel replacement.
Jun 15, 2009 | Samsung HLN5065W 50" Rear Projection...
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Emachines , shutting off on it's own?
While it is possible the power supply could be going bad, usually it would not work intermittently like this.
Most likely the motherboard is starting to go bad, I would do a quick visual inspection for any buldging or leaking capacitors, if you see any that is definatly what is causing the problem.
If you dont see any damage to the motherboard you can try replacing the power supply, if it still behaves this way then your motherboard is the problem (sometimes there are no visible signs of damage on e-machine motherboards even when they have completly fried)
Hope this helps :)
Jan 22, 2009 | E-Machines eMachines Desktop PC
Hitachi 50EX20B Bigscreen TV
You can download a PDF from here: http://www.servicemanuals.net/results.aspx?type=SM&brand=0&model=50EX20B Make sure that the coolant is not leaking out onto the printed circuit boards. i have had the remote sensor cause this problem before and also I have had bad capacitors in the sweep and the main power supplies. Good Luck
Jun 14, 2007 | Hitachi 50EX20B 50" Rear Projection...
Acer X241Wsd Monitor Logo
200 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
