Question about Sharp PG-A20X Multimedia Projector
How do you cool down the system after a presentation?
  • Sharp Master
  • 6,694 Answers
To cool down the projector after use just press the Standby button and leave it in standby mode. The projector itself will cool down and will shut down itself. Only after this remove the power.
ok
Posted on Mar 19, 2011
Heat issue
Chances are your coolant level is low or an air pocket is present in the cooling system.
If you need further help, reach me via phone at https://www.6ya.com/expert/chris_b82b45c59bcf133d
Nov 08, 2015 | 2000 Jeep Grand Cherokee
Heater not blowing hot air changed thermostat and now car overheats
did u bleed the air out of the cooling system? if not dop this procedure and recheck for problems.
The generic method of bleeding air from the cooling system is to use a floor jack and raise the front of the car as high as poss, then fill the coolant recovery tank full and run the engine until it just starts to overheat, high end of normal zone on gauge, then shut the engine down and run cold water over the radiator core, this will self bleed the system and the coolant will be pulled from the recovery tank, repeat as necessary, never let the recovery tank run dry or more air will be pulled into the cooling systeml , if it still overheats then you need to have the head gaskets checked with a gas analyzer for hydrocarbons present in the radiator or recovery tank
Jan 11, 2010 | 2000 Dodge Neon
Heater blowing cold air after radiator flush
you have air trapped in the cooling system, do the following procedure to purge the air out.
Jan 03, 2010 | 2002 Chevrolet Blazer
93 acura continues to run hot, the bottom hose isnt getting hot. i have changed the thermostat.
this is caused by a leaking cylinder head gasket or air in the sytem, if u did not bleed the cooling system follow this procedure, it is generic for all cars.
Dec 10, 2009 | 1993 Acura Legend
How to bleed the air out of the cooling system
Dec 08, 2009 | 1994 Ford Taurus
Howto fix airlock in radiator
The generic method of bleeding air from the cooling system is to use a floor jack and raise the front of the car as high as poss, then fill the coolant recovery tank full and run the engine until it just starts to overheat, high end of normal zone on gauge, then shut the engine down and run cold water over the radiator core, this will self bleed the system and the coolant will be pulled from the recovery tank, repeat as necessary, never let the recovery tank run dry or more air will be pulled into the cooling system l , if it still overheats then you need to have the head gaskets checked with a gas analyzer for hydrocarbons present in the radiator or recovery tank
Nov 10, 2009 | 2003 GMC Envoy
The fan speed controller box is not working,that mean the radiator cooling fan is not working to .
does the fan work when connected directly to power? is there power present at the fan connector, what about at the fan speed controller?
Oct 31, 2009 | Gigabyte 3D Galaxy II CPU Water Cooling...
Back firing lose of power when hot
There are 3 likely causes for this problem.
  1. A Fuel Line is to close to the cylinder and is pre heating the fuel causing Vapor Lock. This Then results in the motor dying.
  2. A Faulty Coil will present as you describe. The motor will continue to run poorly but the problem will resolve if you shut down the bike and let it cool down.
  3. A Faulty Ignition Module will present as you describe. The motor will continue to run poorly but the problem will resolve if you shut down the bike and let it cool down.
I think your problem will be found in #2 or #3.
Jun 28, 2009 | 2003 Harley Davidson FLSTF Fat boy
Motor
the evidence presented indicates that the head gasket probably was blown or head/cylinder interface was not flat enough to hold compression and a gasket failure caused the cooling system to drain down into the crankcase.
Nov 10, 2008 | 2007 HM CR 125R
Motor
Nov 10, 2008 | 2005 Hartford HD-150S
Sharp PG-A20X Multimedia Projector Logo
60 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
