Question about IBM ThinkPad A31 Notebook
Where is the wireless switch please i cant connect to any networks and cant find any networks im not sure if my switch is off cause i cant find it can u help?
  • IBM Master
  • 32,281 Answers
There isn't a wireless switch on the A31.
When you install the wireless card driver it will automatically turn on.
On my A31 the this card is IBM High Rate Wireless LAN MiniPCI Combo card.
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows XP or Vista devicedrivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
Posted on Mar 19, 2011
    Genius:
  • 1,114 Answers
Go to the start menu, control panel, network/internet and then you can select wireless/ turn on/off
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
Im having trouble i cant get on the internet unless im pluged in
IT seems that the wireless connection might not be connected.
if you facing trouble connecting to the wireless network using the wireless adapter utility then you can switch over to windows utility .
Sounds difficult !
It is very simple Click Here for more info about wireless connection problem
Oct 17, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys Wireless NIC PCMCIA card
From what you described, and it sounds like you were thorough and know what you are doing, I would try another card in your laptop. If it is enabled and there is no green light then the USB port(or card slot) has failed or the unit is bad. The LED will be on regardless of detectable networks. I hope it is under warranty or you can find another cheaply. I think you have done the best job anyone could do to troubleshoot the system. Again, my best advice is to try another known working card. This is the final step of your root cause analysis. I am sure you already know this so please don't give me a bad rating.
Aug 24, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Wireless connection using livebox and belkin usb adaptor
You most likely need to reconfigure the livebox settings. The Livebox lost the settings because it was unplugged too long. Most router settings can be accessed by typing in 192.168.1.1 or 192.168.0.1 in the URL address bar of any web browser. From there, make sure that all other switches and devices on the network are on the same network. Meaning if your Livebox default gateway is 192.168.1.1 make that the switch that other devices are connecting to the network through are assigned the IP address 192.168.1.x where x is any number other than 1. I hope this help, I know its not comprehensive enough but once I'm a 'Guide' you will be able to chat with. Then we can have conversation via IM Chat. This is my area of expertise.
Jun 17, 2009 | IBM (34L1209) Network Adapter
Wireless router
device manager and if you see ethernet right click and disable
don't disable the wireless network then right click the wireless and if you see enable click otherwise click and update
restart--- then control panel and network connections
then view available networks if a network shows highlight and then click connect
if there are no networks then on left side of page click refresh network list do this until you see a network then again high light and connect
please let me know if you are connected now
Feb 01, 2009 | Acer Aspire One PC Notebook
Please help
re-installed the driver after then it not working then download the driver the driver in zyxel.com
Dec 02, 2008 | Zyxel ZyAIR B-100 802.11b (AM5009004)...
Setting up wireless connection
First check to see if your windows can see the wireless router. Does it see the router? Click view wirelss networks to see a list of available networks. If you cant see any make sure your wireless network is switched on.
Also which manage s your wireless network, the windows or the wireless cards own software?
Aug 14, 2008 | Computers & Internet
Wireless router
First make sure wireless is turned ON or enabled on the computer, then use the View Available Networks to connect to the your SSID or network name. IF you can connect to router then you should be able to surf Internet.
Jun 26, 2008 | NetGear WGR614/WG511 (wgr614nawg511nakit)...
Wireless network connection 2. not connected.
Check your firewall settings. Also what brand of wireless router/switch are you using?
Jun 09, 2008 | Computers & Internet
IBM ThinkPad A31 Notebook Logo
573 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
