Question about Kenmore Refrigerators
My bottom mount kenmore model 596.7605*701 had a massive ice buildup in the freezer which prevented the refrigerator compartment from working. The freezer was cold, the fridge not cold. I am currently defrosting the freezer. What would cause this from happening? What should I do?
dididsaythat
  • 291 Answers
SOURCE: freezer works fine but no cold air in refrigerator...
Check make sure evapurator fan is blowing and nothing blocking any return vents in refrigeratro side prevent air from recirclating
Posted on Dec 01, 2007
SOURCE: Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
your drain is blocked and it causes blockage and then ice forms..turn of for 24 hoyrs and it should be alright
Posted on May 25, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
SOURCE: My Beaumark Bottom Freezer Refrigerator Doesn't Work
problem is probably that the evaporator is frozen up preventing circulation of air and the fan is jammed with ice.
remove the back panel inside the freezer. melt off the ice with a hairdryer taking care not to heat up any stats mounted on the pipework.
appliance will now work but this is a temporary repair. you must find out the cause of the ice build-up ie why not defrosting.
for starters, check the defrost heater and the thermal cut-out inseries with it.
let me know how you get on and what you find. make sure the fan is free to rotate.
tresilla
Posted on Nov 06, 2008
  • 163 Answers
SOURCE: Evaporator fan stops working due to ice buildup around fan.
you need a drain tube heater.it is like a chain fence tie made from alluminum,you can actually use the fence ties,wrap one side around defrost heater and stick the other side in drain.that will prevent it from happening again
Posted on Mar 07, 2009
Help please - my Kenmore Elite Bottom Freezer not cold - top refrigerator getting warm.
Have pressure taps installed, & check the refrigerant... these refrigerators have a critical charge (meaning not a lot of refrigerant to make them work) So whoever puts gauges on it, make sure they purge their hose while screwing the hose on to the new pressure tap so there is no loss of refrigerant & no air gets into the system. It sounds to me like it is low on refrigerant.
Dec 10, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Buildup of ice on bottom of freezer compartment. Ice then melts and leaks out the bottom
sounds like you have a stopped up drain line where water drains out when freezer is in defrost mode. My Amana freezer does it quiet often.
Jul 15, 2012 | Amana ABB2224WES Refrigeration :...
Ice buildup Model 795-78402-802 Kenmore SN:
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 29, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer has massive ice build up, refrigerator not cooling , no cold air thru chute
Possible that the auto defrost timer is not working and so the massive frost build up. This prevents the air to flow from vent to the fridge.
The auto frost must work on a determined setting of the timer cycle as the frost must clear so that the whole fridge is efficient.
So check the timerr which is normally placed in the rear bottom and is connected to the heater and is also inline with the thermostat.
Sep 26, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
My freezer is working but the refrigerator is not cool at all. we had a black out and it came back on then the lights went out again. since then the refrigerator is not cooling. Thank you
Good day,
If the fresh food section was O.K. then after the power failed off and on, the first thing to check is the fan motor in the freezer section. It was probably burned out. Open the freezer compartment when the machine is running, you should hear the fan running, if not, remove the back panel, and check the motor, and replace if needed.
If the fan motor is running, remove the rear panel and look for ice/frost buildup on freezer coil.
If Iced, then the defrost system has failed.
The defrost system is made up of 3 parts. The main heater, mounted across the bottom of the coil, the defrost thermostat, a small 1'' round disk mounted to the top of the coil.
Both can be tested with an ohm meter, but must be done before the coil reaches 32 degrees, or the test won't work. Both should read zero ohms
Lastly the timer or adaptive defrost control, mounted in the fresh food compartment.
Below is an excellant tutorial on defrost systems.
http://www.appliance411.com/faq/howdefrostworks.shtml
Thank you for using FixYa
Jan 15, 2010 | Kenmore 64802 Top Freezer Refrigerator
Whirpool fridge is warm, freezer is working
Check the back wall of the freezer compartment for ice buildup. Sounds like you have a defrost issue.
Feb 22, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Refrigerator is freezing at the bottom and 60 degrees at the top
probably the fan is not running
take the fan housing off and you may find a buildup of ice preventing the fan from running
Nov 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
91 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
