Question about Garden
Need an owner manual for self propelled mower model #12AVA29Q711
  • 147 Answers
SOURCE: toro self propelled mower will not move
This is a very simple solution, When you pull the lever it simply pushes a pulley into the belt to make it tight. Most of the time the belt has come off or maybe the cable broke. Turn the mower over and you will see the belt. My money is on the belt off.
Posted on Nov 06, 2008
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
  • 77 Answers
SOURCE: my toro self propelled isn't self propelling
It may just be a matter of adjusting the cable. Sometimes they dont get them adjusted just right from the factory,heres what you do. Locate the plastic shroud in front of the push mower that covers the drive unit.Determine which screwdriver or torx bit is needed to remove shroud and remove it. After removal you will see a pulley with belt around it, as you pull the handle back to engage self propel you should see the pulley move into the belt to put tension on the belt. You can do this with it running to see if enough tension is being put on the belt,if not, locate the cable end where the small bracket holds the cable in place. Loosen the cable bracket and move cable until you have correct tension again,hope this helps.
Posted on Aug 09, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
SOURCE: need owner's and service manuals for John Deere Model 317/
First off, Mowerman's response was incorrect about the age of a JD 317.  They were made from 1979 to 1982.
You can only get manuals either through here:  http://techpubs.deere.com/deere/Default.aspx  or from a dealer.  They're expensive.  You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
Posted on Oct 27, 2009
Looking for repair manual for husqvarna 175cc 22 in self propelled rear wheel
Search by engine model #. If not engine problem search by mower model #+parts.
Jun 12, 2016 | Husqvarna Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
I have just aquired a Briggs and Stratton 450 series self propelled mower but need an owners manual.
The Briggs and Stratton 450 series is the engine (4.5 Hp). Is there a model number on the mower deck anywhere? I can probably find you a manual but need that model number. Unless you just want an engine manual.
Murray makes a 20 inch MX450 that has the Briggs and Stratton 450 engine on it but there are numerous makes and models (self propelled) that use this engine.
MX450 parts manual is here:
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=lminvFXBnfBhU7y
If you can come up with a good model number I will search avidly for a manual.
Thanks for choosing FixYa,
Kelly
Jun 09, 2011 | Garden
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
How would I get an owner's manual for a Toro
go to www.troybuilt.com u can request one on line or can be advised where to pick one up
Mar 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I am trying to find an owners manual for my troybilt mower model#12A1869F011. They didnt have any more at the store where it was purchased
try this site, enter your model and serial number, and you should be able to download manual.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Jan 03, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Manual for 6hp Troy Bilt self propelled lawn mower
Go to www.troybilt.com and on the top of the home page click on FAQ (frequently asked questions) and on that page click on "owners manuals". You will need your model number of the mower. I hope this helps!
Sep 08, 2009 | Troy Garden
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
