How do we eject e reader ffrom computer prior to removing usb
    Scholar:
  • 62 Answers
On your taskbar, bottom right of the screen near the time.
You should see a Green circle with a check sign against a small USB icon. This is the "Safely remove hardware and eject media" button.
Right click this, select your E reader, and eject it!
Hope this helps!
Posted on Mar 19, 2011
After downloading photos to my laptop the playback screen does not function on the camera. The screen is fine while shooting but does not function in playback. Any solutions?
The memory card may not be storing your photos.
do you transfer photo direct from camera or use card reader?
If card reader the memory chip might not be fully seated back in camera ( not likely ) or you might have formatted the card incorrectly after transfer.
if direct from camera did you properly remove camera from computer? Remember, just removing device without ejecting device sometimes results in errors. Any device connected via cord to computer is using a USB port and on your task bar you should see indicator , right click select eject device.
if that might be the case reconnect camera then properly eject.
Sep 28, 2016 | Panasonic Lumix DMC-FZ70 Digital Camera
Tip
My eReader shows "DO NOT DISCONNECT"
This message it's normal operation for the Sony eReader. It appears whenever the Reader is connected to the computer and will not go away unless you click the "EJECT" button.
To safely disconnect the reader do the follwing:
1. Click the "EJECT" button next to the word "READER" on the Reader Library (This icon looks like a party hat or a triangle)
2. After you do this, the Reader icon will disappear from the Left Panel, and the screen of the Reader will change to "USB Connected"
3. now its time for you to disconnect it.
eBookBoy
on Jul 15, 2011 | Sony Reader Touch PRS-600
Mu computer is windows 7 professional
Marie, If your computer is not equipped with a SD/Micro SD card Reader you will have to purchase one to simplify looking at it and copying it on computer. You can also use appropriate cable possibly to hook your camera up to computer.
Step 1/ Insert a USB card reader into an available USB port on your PC.
Step 2/ Insert the micro SD card into the card reader. Some card readers will only accept standard SD cards. If that's the case, insert your micro SD card into an SD card adapter and insert the adapter into the card reader.
Step 3/ Click "Open Folder to View Files" in the Auto Play window to launch Windows Explorer in the appropriate drive letter. Alternatively, press "Windows-E" and click the card reader's drive letter.
Step 4/ Drag and drop files to or from the micro SD card's drive letter to copy files. Alternatively, right-click and drag files and then select "Move Here" to move the files without keeping the files in the original location.
Step 5/ Select a file, press "Delete" and select "Yes" to delete files from the micro SD Card.
Step 6/ Right-click the micro SD card's drive letter and select "Eject." Once ejected, you may safely remove the card.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Transfer Pictures From MicroSD Card to PC
How to use card reader
Card Readers Adapters
Memory Card Readers
Aug 20, 2016 | Cameras
I would like to transfer tunes from my IPOD to a sd card
Buy an SD card reader. Insert the SD card into the reader and plug the reader into a USB port on your computer. Plug the iPod into another USB port on your computer. Use iTunes or Windows Explorer to transfer the songs you want from the iPod to the SD card. When done, disconnect/eject the card reader from the computer, take the SD card out of the reader and take it to your car.
Oct 20, 2014 | Audio Players & Recorders
1TB Drive works fine; never had an icon associated with it though. What gives? And I assume it doesn't need to be "ejected" prior to removing it. No option for that when right clicked from...
click start click on computer to open then on your drive usually C: to expand you should see your usb drive right click on it you will see an array of options including send to desktop to make short cut also an eject and yes you should always eject it before removing it or use the remove hardware safely ability it's usually in the bottom toolbar you should see it once you connect your usb drive otherwise it wont be there
if you need more help with this post a reply
hope this will help you
Aug 10, 2011 | Western Digital Passport 320GB External...
How to I get a picture that's on my phone onto my pc?
You can get picture transferred to Your computer using the bluetooth of Your phone or through the USB connection or through the memory card of Your device.
To use the bluetooth of Your phone please follow the steps below:
  1. Ensure the computer has a bluetooth device or You connect a bluetooth dongle to the computer,
  2. Turn on the bluetooth of Your phone,
  3. Select the picture You want to send to Your computer one by one,
  4. Then You select receive a file from the bluetooth option from Your computer,
  5. It will search for the phones bluetooth device, then You accept it from the computer, do not use the pass key mode on the bluetooth settings,
  6. It will load and send the file to the phone.
To send picture through the memory card, please follow the steps below:
  1. Turn off the phone,
  2. Remove the memory card of the phone,
  3. Get a memory card reader and insert Your memory card into it,
  4. Then You connect the memory card reader to the computer,
  5. It will read like a USB drive and install its drivers,
  6. Open the file to view folders, or You go to the phone and open it from its position i.e Removable drive E:,
  7. Go to the picture You want to send to Your computer and copy then to the document of the computer,
  8. Safely remove the device by ejecting it from Your computer(to eject right click on the position and select eject),
To transfer picture to the computer using the USB cable, please follow the steps below:
  1. Connect the USB cable to the phone,
  2. Connect it to the computer,
  3. The computer will install the drivers of the phone,
  4. Then You open file to view folder,
  5. If the phone does not connect to the computer, it might require the software disc that came with the phone, insert it into the computer and allow it install,
  6. Once the computer recognizes the phone,
  7. Click on open files to view folder,
  8. Then You select the pictures You want to transfer to the computer and send them to Your computers picture folder.
Hope this helped. Thank You for using FixYa!!!
Jan 21, 2011 | Samsung Lands Phones
How can i put music from my computer to my sanyo scp-2700?
You can get music transferred to Your phone using the bluetooth of Your phone or through the USB connection or through the memory card of Your device.
  3. Select the songs You want to send to Your phone one by one,
  4. Then You select send a file from the bluetooth option from Your computer,
  5. It will search for the phones bluetooth device, then You accept it from the phone, do not use the pass key mode on the bluetooth settings,
To send music through the memory card, please follow the steps below:
  6. Open the file to view folders, or You go to the computer and open it from its position i.e Removable drive E:,
  7. Go to the music You want to send to Your phone and copy then to the memory card,
  9. Insert it into the phone and browse out the music from the phone.
To transfer music to the phone using the USB cable, please follow the steps below:
  8. Then You follow the step 7 and 8 in the process to install using a memory card reader.
Jan 18, 2011 | Sanyo SCP-2700 Cell Phone
Kids Discovery Camera. Put new batteries in. Won't power on. Can't find the manual for trouble shooting. When I plug in to USB it shows that connection.
Install the driver and plug it into your computer. Then eject it from your computer using safely remove hardware.... I did this a few times and it worked.... I coulnd't power it on or off prior.
Sep 03, 2010 | Sears Discovery Kids Digital Kids Camera
Camera will not upload photos to computer
Depending on the method you're using, this can usually be remedied in one of two ways:
  1. USB Cable: make sure your camera is turned off before connecting to the computer, and that the drivers for your camera have been loaded prior to connecting.
  2. Memory Card: SD or MMC card readers are becoming more std. on computers, or inexpensive card readers are available to connect via USB.
If you are experiencing difficulties with either of these, this may involve a problem with your USB port or the drivers your computer is using. Sometimes it's as simple as removing the driver which isn't working properly and re-installing it again. In most cases, you will need to install the driver without the USB device connected, so that after you have successfully loaded the driver, the computer will recognize your USB device properly.
Once again, make sure your camera is turned OFF when you connect it to your computer with the USB cable (of course, your computer needs to be turned on). Then, turn the camera on, and you should see the computer recognize the device.
Apr 01, 2010 | Kodak EasyShare Z760 Digital Camera
Camera not reading SD card after being removed from my reader
Put the SD card back into the card reader. Are you files still there when the computer tries to read them?
If they are not, then it is very likely the card is corrupt. This happens when the card is removed before the computer is done reading/writing to the card.
There is also a SLIM chance the card is just bad.
Nov 06, 2008 | SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card...
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
