Question about Samsung RS2530BWP (25 cu ft) Side by Side Refrigerator
Why do i have to press the reset botton to get the ice to fall, on my Samsung RS2530BWP refrigerator? Also the side panels only on the freezer side are HOT to the touch and im worried it might become a FIRE HAZARD.
Verify that the compressor fan is working. The fan is located behind the unit at the bottom. You need to remove tha back panel and observe that the fan is working while the compressor is running.
Posted on Jan 19, 2012
  • 8 Answers
SOURCE: possible fire hazard
we have same one ours gets warm but not hot enough to discolor you better call for service immediatly definate fire danger good luck
Posted on Mar 15, 2009
techman
  • 3130 Answers
SOURCE: Bottom freezer
There is an small bar or arm that hangs down into the hopper where the ice collects. Sometimes the manufacturer will tape this bar down and it is not free to move. Or see if the arm is bent. Also I had a new side by side last year, did the same thing. They sent some kid out and he told me it is a design flaw. Did not have a clue. I called GE and they sent out a repair man who knew what the problem was. It was a new bailing arm that had to be installed in place of the old one. If the arm is swinging freely, call the warranty company. Maybe yours needs to be modified as well? Good Luck
Posted on Feb 19, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Refrigerator Compressor smoke hot to touch
Yes this is a sign of a burn out or start relay or start capacitor defect you made the correct choice. If you need assistance let me know, Sea Breeze
Posted on Jul 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: WATER LEAKING OUT OF FREEZER DOOR
The defrost drain hole in the bottom of the freezer has frozen over. Turn off the fridge. Remove the shelves and bins. Remove the rear panel of the freezer. You will see ice on the bottom rear of the freezer. Use a hair dryer to melt the ice,especially in the drain hole once you get through the surface ice. Once the drain hole is clear,pour a cup of hot water through the drain hole followed by 1/4 cup bleach. Re-install your parts and turn the fridge back on.
Posted on Sep 21, 2009
imufo2
  • 3773 Answers
SOURCE: samsung rs2530bwp refrigerator will not start
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Sep 16, 2011
1 month old Samsung RF28HFEDTSR. No ice in upper ice compartment. All Ice drops to bucket in freezer section. I press reset button it dings and soon one group of ice falls in upper bucket.
I believe something's wrong with your new ice maker. Are you sure that the ice maker is not turned off on the display? And take a little bit of time and go through your user manual if you don't have the user manual let me know I will send you one
http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1509233L.pdf
Appliance 911 Sea Breeze
Sep 02, 2016 | Samsung Refrigerators
What part Samsung RS2530BWP uses, Sensor or Bar
either the heating element used to defrost is bad
or there is usualty a small inline thermal fuse
replace it
test the elements resistance is aok
look on ebay for a new inline fuse and also element save the grief of testing
Dec 08, 2014 | Samsung RS2530BWP (25 cu ft) Side by Side...
Samsung model rs2530BWP cubed ice icon is blinking what does that mean
mine was doing this, i replaced the main board and power supply, it was still doing. i checked all the sensors and still didnt fix the problem, i then looked at the ice maker, there is a sensor on the ice maker that has two white wires off it, i used a jumper wire and touched them together at the plug in the freezer and it started working like it should, now i have to order a new sensor from what i can tell. part number DA97-00258E to replace the ice maker.
Oct 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
SAMSUNG MODEL RS2533SW/CUR ICEMAKER MAKING ICE BUT NOT DUMPING
This sometimes happens with my KitchenAid ice maker.
Usually there is a piece of ice stuck on the side where the sensor is that causes the ice to drop. I usually carefully chip away at any ice that is stuck. Once the stuck ice is removed, the ice maker works fine.
Sep 18, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
Aug 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
I need to order compresor fan for my refrigerator
Hi please find some link for you below.. these will assist you.
http://www.partstore.com/Model/Samsung/Samsung/RS2530BWP.aspx
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=RS2530BWP
http://www.samsungparts.com/Products/Parts_and_Accessories/RS2530BWP/XAA/Default.aspx
Right, these days in our global market, anywhere is as good as anywhere as long as you are aware of what you are getting. Always try to obtain original parts, but if not possible, then make sure you have a warranty.
Jul 04, 2011 | Samsung RS2530BWP (25 cu ft) Side by Side...
Ice Maker: water freezes in tray, but no ice is dumped to the bin. Unit is NOT trying to add water to full tray.
Check the freezer temperature. It must be below 10F in order for the Icemaker to operate. If you find that the temperature is above that, your problem is not the icemaker, but something else in your cooling system.
Apr 01, 2011 | Samsung RS2530BWP (25 cu ft) Side by Side...
My Samsung side-by-side two door RS2530BWP refregertor is not cooling enough. In side the Freezer, there is lots of snow like ice deposite at the back wall. IT is not making ice. Refrigertor side, it is...
you will need to use a blow dryer and defrost the back wall.Once that is defrosted then you will need to remove the back panel and defrost the evaporator coil.
There are several things that can go wrong the temp thermostat,defrost thermostat,defrost heater,or control board.you will also need to check the evap fan and make sure it is working.
Dec 19, 2010 | Samsung RS2530BWP (25 cu ft) Side by Side...
Refrigerator side not cooling freezer works fine
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ghjghd
Jun 28, 2010 | Samsung RS2530BWP (25 cu ft) Side by Side...
Samsung RS2530BWP (25 cu ft) Side by Side Refrigerator Logo
414 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
