Question about Refrigerators
No ice being made. The water is not eing supplied to the ice tray. The water dispenser in the door is working fine.
  • 3,018 Answers
Well since water is making it to your door the line itself is functioning. You might want to check and see if the fill tube to the ice maker is frozen. Also try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. If it does then the ice maker is at fault.
Posted on Mar 19, 2011
Ice maker isn't working. Water is not filling the tray but the water dispenser in the door works fine.
could be frozen water fill tube to Icemaker. or solenoid water valve is not opening when ice maker calls for ice. there are 2 separate solenoid valves : one for dispenser another one for ice maker.
Mar 28, 2015 | Refrigerators
Ice maker inop
Water valve for ice maker may be bad. there are two valves with one supply line, one valve controls the water dispenser and one for the ice maker. you can ohm out the solenoids, it'll ohm if its good and won't if its bad
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Maytag Refrigerators
Kenmore model# 106.9547651 ice maker has stopped working; water dispenser works.
A valve controls water flow into the ice trays. It is a common source of the trouble you describe. You may be able to get an overhaul kit for just the valve
Dec 26, 2012 | Kenmore Side by Side Refrigerator
Hi, I have a GE pcf23ngtd side by side. It makes ice fine, but it doesn't dispense any ice and intermittently dispenses water. Any thought of what the problem is?
you have a pinched water supply line -
not sure on why it would not dispense ice unless there is some blockage or other -
did you remove all the ice tray and fully inspect the dispenser at both sides of the door -
Feb 13, 2011 | GE Profile CustomStyle PCF23NGT Side by...
How do i access the ice dispencer door in the door? The door is stuck open and freezes up the dispencer.
1. Disconnect the unit from the electrical
supply and wait for 3 to 4 hrs to get ice melted.
2. Pull out and unclip the drip tray on the ice
and water dispenser compartment.
3. Remove the screws from the ice and water
dispenser compartment front panel and
turn it over. The selector switch pack and
dispenser switches are now accessible for
testing.
Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker no longer works. It has been working for years and all of the sudden the ice tray does not fill up with water, however the water dispenser dispenses water just fine....
The unit uses a dual water and possibly the side which supplies the ice maker has become defective. Also check to see if the fill tube has frozen.
Apr 30, 2010 | Thermador KBUIT4260A Stainless Steel
KitchenAid KSRG25FKSS16 Side by Side will not make ice
First I would check for obstructions in the line from the water inlet valve to the tray assembly. If thats good check the valve it self. This is a double valve, it supplies water to the door and it supplies water to the ice maker. Check and compare both coils. They should be around 300 Ohms. If not, replace it. Try Partselect.com
Oct 10, 2009 | KitchenAid Refrigerators
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
248 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
