Question about SanDisk 2GB microSD Memory Card
So i put the microsd card into my sd adapter, and then put it in my sd card slot in my computer,, and nothing happens, i go to the My computer file and the computer hasnt recognized the sd card adapter with the microsd card in it.. How do i get my computer to recognize my adapter with the micro sd card in it??
  • 449 Answers
If this is an SDHC card, you need an SDHC capable reader.
Posted on Mar 19, 2011
  • michellem107 Jun 27, 2011
    Sometimes it's the simple solutions that are most effective. I had the same thing happen. I accidentally dropped my phone and all my photos went away. I spent an hour on the phone with my tech support people to find out how to recover photos. I followed a variety of suggestions to no avail. I was even told that I might have to do a master re-set. Instead I pulled the battery out and noticed that the SD card was simply not seated properly in it's compartment. I pushed it in so that it was making complete contact and all the photos came back without any problems.
Makes sure your microsd card is genuine.. Did you buy this card in the US? Sometimes cards bought in other countries are compatible in phones and cameras but no on PC's...
Posted on Mar 20, 2011
My Sansung laptop does not recognize the memory card for my camera.
A microSD device is a digital storage device used in many Mobile Phones Cameras and MP3 players. It is a smaller version of the standard SD memory card, about one-quarter its , and has a storage capacity that ranges from 128MB to 4GB. In order for you to read files inside the microSD card using your computer, you need either a microSD card reader or a microSD card adapter. Insert the microSD card into the microSD card reader and make sure that the card is properly connected to the device. Plug the microSD card reader into a USB port in your computer and wait for the computer to recognize the device. Use a microSD card adapter to read your microSD card if you do not have a microSD card reader. A microSD adapter basically looks like a standard SD card but is designed to accommodate a microSD card to fit the SD card slot. Simply insert the microSD card into the microSD adapter and then plug the adapter into the SD slot in your computer. Plug the SD card adapter into an SD card reader if the computer you are using does not have an SD slot. Consequently, plug the SD card reader into a USB port in your computer. Use your phone to read your microSD card. Plug one end of the USB cable that comes with your camera or phone to the mini USB port in your device and plug the other end to a USB port in your computer. When you are prompted that the device is recognized, install syncing software (if applicable). Many cameras phones and MP3 players can be connected to the computer without using any software. Navigate to the location of the removable drive.
Open the folder to see if you can browse the files in the microSD card.
Jan 14, 2013 | Samsung Computers & Internet
Where do I insert my microSD memory card or does my computer have a slot for it?
Here are the ways for you to insert your microSD to your computer
1. Use "memory card reader" (this is probably the best way)
find the slot that says "micro sd" that's where youre going to insert the microSD
2. Use the internal memory card reader of your pc ( if your computer has it)
it is located in front of your desktop. The find the slot that says "micro sd" and insert it.
Sep 13, 2011 | SanDisk 2GB microSD Memory Card
How do you transfer a photo from computer to sanDisk
Please keep the sandisk in to the USB port of system/laptop,
select the files what you want to send to sandisk, then rightclick on the selection. Then goto "Send to" option. In that you will find your sandisk. Select the drive of sandisk.
System will send the fiels to memory card.
Jun 08, 2011 | SanDisk 4GB microSDHC Memory Card
Micro sd card is locked how can i unlock this ?
For the microSD card you'll need the large adapter (picture left side)
to unlock.
Insert the microSD card into the Adapter with the arrow upwards:
put the microSD card directly into the Adapter on the left.
(The Adapter on the right below is miniSD, used for other size cardreader slots)
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to put data onto the SD card (Adapter) with the microSD card in,
on the SD card reader slot of your computer
or
Pull out the microSD card and put it in your previous used device, to
see if transferring files will work.
Jul 15, 2010 | SanDisk 2GB microSD Memory Card
I put my SD card in but nothing happens. I've double checked that the card contains picture files using a 24 in 1 USB Card Reader. I'm using a Kingston microSD with adapter. When I take the SD card out of...
Check the way the SD card was formatted. FAT16 or FAT32. Save the images out to the computer, Reformat the SD card to FAT32, add the images. If that doesn't work, do the same with FAT16.
Dec 17, 2017 | Matsunichi 8 digital picture frame
Can I use a micro sd card from my nokia on my acer extensa 5235?
If your acer has an microSD card slot, you may use that provided that you have a microSD card adapter slot wherein you will insert the microSD card to the adapter. Then check if the adapter will fit the microSD card slot. IF it is not , then your acer has the SD card slot , not the microSD card...
May 16, 2010 | Computers & Internet
My PC will not recognize my 2GB Micro SD Card
Does the PC recognize the adapter when you place onto the USB port? If not, try another USB port. It should atleast say it has detected hardware, see if it's finding and installing the drivers correctly.
If it's not the adapter, could you reformat the microsd card? Perhaps, it is corrupted? Is this SDHC or SD (what capacity). Older Blackberries do not support SDHC (I believe this is 4gb or above), perhaps this has something to do with it.
I hope this helps,
Bill
Sep 04, 2009 | SanDisk 2GB microSD Memory Card
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
May 19, 2009 | SanDisk 2GB microSD Memory Card
I dont know where to put this
Hi, First insert the micro SD into its adapter which resembles a SD card itself but has a small opening at the bottom to insert the micro SD. The adapter should not b locked while inserting or removin the micro SD. Now insert the adapter in the card readers slot which should be connected to a PC via a USB. If its a card reader then insert the adapter with microSD in the right side top corner of the card reader with the adapters copper pins facing down. OR if u already have slots in ur CPU to insert the SD card install it there, Now transfer files to ur card happily. NOTE: Rename ur device so that next time when u plug it in the adpter n connect it to PC, u wont get confused. Just right Click on the drive icon in ur PC n select rename n just giv any name as u lik. Rate he soln dude Bye..........!
Jan 25, 2009 | PNY 2GB microSD Memory Card
Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Jul 02, 2008 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD Memory Card Logo
333 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
