Question about Microsoft Windows XP Professional
My xp computer will not recognize the dvdrw. under hardware devices it shows the driver but with a yellow tab. the device is a liteon dvdrw 160p6s. liteon says in docs that it uses pnp service and not drivers. i dont know what service would run as driver. under driver it uses microsoft driver ver 5.1.2535.0 under my computer it is not recognized. please give me a few clues. could some registry errors cause this? sincerely, alden
  • 9 Answers
There are 2 types of dvd-rw discs, dvd+rw and dvd-rw. Some drives, especially older ones (since you are using XP) only support certain types. I run XP as well and many DVD+RW discs do not work for me. If this is the case, drivers arent your issue, its simply a hardware flaw. I would try experimenting with a different format, whether its + or - (plus or minus)
Posted on Mar 19, 2011
I have a systemax syx-ms-7309 ser#106603641 i need to know the specs im having issues keyboard or mouse wont work and monitor yurns on says no signal and no picture but the toer has powe to it but th
first the monitor
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
if by now you gan get a screen
you might have to uninstall your keyboard restart your computer then reinstall it
make sure the lead connection is secure and dust free (if applicable)
make sure the usb device is inserted correctly into the Ps2 or usb port (if applicable)
click start control panel administration tools computer management device manager scroll to keyboards also mouse you might see a yellow exclamation or question mark ! ? or red x you will need to update driver right click to update driver
if your computer came with a motherboard disk the drivers could be on it
this will apply to your mouse
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
hope this helps
Jul 16, 2012 | Systemax Ascent PC Desktop
Tip
USB Printer does not recognize with XP Computer
In most cases, the driver for a printer is supplied when you purchase it. It is the responsibility of the manufacturer to provide the driver along with the device to make sure the working.
However, most of the Operating Systems come with native driver support for many known printers. This is the fact we have to take care while purchasing a printer. Even though we misplaced the driver disc, if we purchase a good manufacturer printer, there is a chance to get the native support from Operating System itself.
There are some scenarios where printer may not be recognized by the Operating System due to some conflict with other devices.
Please follow the troubleshooting steps and check the operation:
  • Ensure that the supplied USB cable is firmly connected to both the printer and computer side.
  • Ensure that the USB driver for the printer has been properly installed. Please follow the steps to ensure that:
  1. Turn ON the computer and then printer.
  2. The Add New Hardware Wizard window will appear on the Computer screen.
  3. Click the Next button
  4. Insert the installation CD in to the CD/DVD drive on the Computer.
  5. In the Add New Hardware Wizard window, click to select the CD-ROM drive.
  6. Click the Next button.
  7. In the Finish Setup dialog box, click the Finish button.
  • If the USB driver for the Printer has already been installed, uninstall and then reinstall the driver.
Follow this procedure to reinstall the device driver using the Device Manager utility.
IMPORTANT: This procedure must be performed while logged in as Administrator or to an account with Administrator rights.
  1. Click the Start button, and then click Control Panel.
  2. In the Control Panel window, under Pick a category , double-click the Performance and Maintenance icon.
  3. In the Performance and Maintenance window, under or pick a Control Panel icon, double-click the System icon.
  4. In the System Properties window, click the Hardware tab.
  5. On the Hardware tab, in the Device Manager box, click the Device Manager button.
  6. In the Device Manager window, double-click the category icon of the device to be removed.
  7. Under the Device Manager category, click to select the device to be removed.
  8. On the menu bar, click Action.
  9. On the Action menu, click Uninstall .
  10. In the Confirm Device Removal window, click the OK button.
  11. Restart the computer.
NOTE: For some devices the operating system will display a System Settings Change window. Click the Yes button to restart the computer. When the computer restarts, the operating system will find the device and install the driver. If the operating system is unable to automatically find the driver, have the installation wizard search the C:WINDOWSI386 folder.
  • Remove and reconnect the printer.
does not recognize printer XP computer does not recognize printer. HP printer computer connectivity how to troubleshoot if printer is not connecting to my computer. XP printer issues. how to troubleshoot printer conncting with XP Computer. XP does not recognize printer. Printer is not connecting to my computer. how to reinstall printer driver. how to install native driver for printer. CANON printer is not recognized by the Computer. Epson printer is not recognizing. Epson does not recognize XP. Canon Printer connectivity.
on Jan 27, 2011 | Office Equipment & Supplies
My mouse is not recognized by usb connection anymore
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port: (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope this helps:
Jul 09, 2011 | Audio Players & Recorders
I downloaded the driver for my Targus AWM25US mouse, but Windows 7 will not recognize the device. Is there a solution for this?
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
Jun 25, 2011 | Computers & Internet
Installing DVD-RW LiteOn iHAs124-04 b AL0L with Windows 7 64bit but getting "Device driver software was not successfully installed." General Device Properties show:" Windows cannot load...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 26, 2011 | Lite On LiteOn IHAS124-04 Black 24X SATA...
I HAVE A LIE ON DVDRW SOHW-1673S AN I CANT BURN DVD'S I CAN ONLY BURN CD'DS WHAT SHOULD I DO
1.control panel->system->hardware->DEVICE MANAGER 2.uninstall your driver 3.restart you computer 4.on tray icon a balloon come with a MSG of 'found new hardware' 5.click on it 6.select your driver from it .then select suitable option
if you still have problem buy a you op(win xp,vista,7..).using that disk repair you computer.
Feb 22, 2011 | Lite On DVD+/-RW LITEON SOHW-1673S BGE %...
I found my wireless mouse yesterday. A logitech M305. When I plug it into my laptop it either says that it is not recognized by windows, or that the device has malfunctioned.
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
also click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark !or question mark ? or a red x right you will have options to update driver software,disable,uninstall,scan for hardware changes and properties
in xp
hope this helps
don
Feb 13, 2011 | Logitech Cordless Mouse
Display adapter not working
Select CONTROL PANEL
Select SYSTEM
Select DEVICE MANAGER (under HARDWARE tab if windows xp)
(This will show you all your computer's hardware2_bing.gif and peripherals)
Locate your display adapter, than click the "+" to open the specific
Not listed?-Defective or no power.
Listed? right click it, select PROPERTIES
(Yellow triangle indicates error)
First tab GENERAL shows if it is working properly.
Then click on DRIVER tab to see if you just need to update the driver, or roll back to a previous driver.
Hope this helps
Mar 07, 2010 | HP Pavilion 735n PC Desktop
Sony Walkman not connecting to computer
I had a similar problem (my computer uses Windows XP) - Sony Walkman beeps a couple times when I insert the USB Cable that connects it, like it is connecting, but it does not charge or is not found by Windows Media Player. In my case, the way I fixed it was to:
1, Go into Control Panel
2. Double Click 'System' ICON
3. Select Hardware Tab
4. Select Device Manager
5. Select 'View' at the Top
6. 'Devices by Type' AND 'Show Hidden Devices' should be selected
7. 'Scroll down to 'Portable Devices' and open it up.
8. My Sony Walkman was there with and Exclamtion point ( ! ) in a yellow circle,
9. Right Click on this yellow exclamation point.
10, Select 'UNINSTALL'
11. Once the computer says 'Device has been Uninstalled, Disconnect your Walkman's USB cable then reconnect.
12. At this point, my Walkman was recognized by my computer, started charging, and was recognized by Windows Media Player
Hope this helps
Feb 16, 2009 | Sony Network Walkman NW-E005 MP3 Player
Microsoft Windows XP Professional Logo
136 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
