Question about Whirlpool Dishwashers
Dishes have an odor after being washed - Whirlpool Dishwashers
    Sniper:
  • 68 Answers
Check the drain line under the kitchen sink. The drain line is supposed to run from the bottom of the cabinet, and run as high in the cabinet as you can get, (up to the bottom of the counter top) then connect the drain. This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.
Please rate this solution.
Posted on Aug 04, 2008
Dishwasher model FDB740RCS0. Has a unpleasant odor when door is opened. Dishes also have this smell.
There is usually a filter in the bottom of the machine where the perforations are.
Ofter you twist the cylinder around or turn a lever.
Try a full hot wash with detergent and nothing in it to see if it helps flush it out.
Is the drain hose into the sink, pipe or waste under the sink clear.
You may need to get down and dirty with the waste pipes to makes certain everything is flowing OUT easliy.
Nov 22, 2016 | Dishwashers
Dishes have bad odor after being washed. Changed dishes and detergent. What's wrong?
Bonjour mon ami,
Your dishwasher has a build up of bacteria that would be causing the smell. I would sugsuggest purchasing a rinse-aid from your local supermarket. This is a pack you place in your dishwasher and run on a full cycle without any dishes.
It should disinfect your device and clear up the issue for you.
Also at the bottom on the inside there will be a small drain be sure to empty this regularly.
kind regards,
Geoff
Nov 13, 2014 | Dishwashers
My LG LDF6920St has not been cleaning very well recently and there was an odor and grease left in the bottom after a wash. I pulled it out and found the Float Assembly pretty clogged and dirty, which I...
1 Scrape and rinse dishes before putting them in your appliance. Small food particles, grease, sauces and bones clog up the system, keeping the dishwasher from properly rinsing your dishes. You don't need to prewash the dishes but be sure to rinse off any solids.
2 Use a toothbrush to clean around the dishwasher door.
Clean around the seal and hinges of the dishwasher. This area often is forgotten and holds a good deal of bacteria and food splash. A tooth- or bottlebrush is the best way to get into the crevices.
3 Clean chunks of food out of the screen and drain at the bottom of your dishwasher, recommended The Family Handyman. If the drain is plugged, the dirty water can't be washed away and ends up back on your dishes. Nut, bean and seafood shells, bits of plastic and small dishes can lodge against the drain, keeping it from doing its job.
4 Unclog the holes in the sprayer arms. If the holes are blocked by food or soap, water cannot freely spray inside the dishwasher to thoroughly clean the dishes. Leftover food on the dishes can make the dishwasher smell.
5 Keep space around your dishes. Overloading a dishwasher keeps it from running efficiently, allowing gunk to build up around the drain and the spray arms.
6 Run your dishwasher as hot as possible to break down food and grease. The recommended temperature is 120 F.
7 Run the dishwasher with vinegar added to neutralize odor. Empty the dishwasher, place a dishwasher-safe cup filled with white vinegar on the top rack, and run a cycle at the hottest setting. If you prefer, use unsweetened lemonade powder or baking soda in place of vinegar.
Jun 21, 2011 | LG LDF6920ST Stainless Steel 24 in....
My kitchen aid dishwasher has an off odor and is leaving a residue on the dishes. what should I do?
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Apr 03, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I do not leave dirty dishes in my Bosch dishwasher more than a few hours and do a load every other day. However there is always a 'rotten' odor in it. I've tried washing it with baking soda but that...
Clean out the pump filter (located above the pump) then run the machine with a large measuring cup full of vinegar first then, dishwashing soap nothing else no other dishes for the two loads.
Jun 22, 2010 | Dishwashers
Dishwasher always has a nasty odor when you open the door
check the drain hose connection from the dishwasher to the main drain under the sink , it should be connected above the trap . hope this was helpful
Jul 11, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Stong odor comimg from inside unit after wash cycle. Is there a filter that can be cleaned??
doyou have a garbage disposer hooked in with the dishwasher? sometimes that a problem. run your unit with some vinegar with a hot cycle with no dishes in unit. if you still have odor chech your drain line make sure the water is not backing up in to the lines.let me know if this was helpful with a 4 thumbs post
Feb 27, 2010 | Dishwashers
Dishes are still damp after cycle is complete. This causes a bad odor in the dishwasher.
Bad odor is caused by something besides wet dishes.
When the water finishes it's part and is exhausted, does a fan come on and run for a long time? If not, the drying fan is bad, usually mounted on the side and runs after all the water is removed. Also, after the water stops, are the dishes and inside HOT? You have to have HOT water to make a dishwasher function properly, will also take care of some of that odor. When a dishwasher cycles, it washes and then heats the inside of the washer, then it runs a fan to remove the water and dry the dishes.
Make sure your dishwasher is hooked to the HOT water line and also check to be sure it can heat it's own water, put it on pot's and pans and it should heat the water quite hot, even if it has hot water coming in, it will heat it up some more.
Sep 08, 2009 | Bosch Integra® 500 SHX55M05UC Built-in...
Odor, poor drying, cold water
Can you confirm that you own an LG LDF7810 dishwasher?
The symptom you describe is a classic symptom of a failed heating element but the LG dishwasher ~should~ report an error code.
Apr 07, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
Dishwashers Logo
91 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
