Question about Maytag Washing Machines
I have a top loading Maytag Performa washing machine and the tub doesn't spin
    Genius:
  • 1,114 Answers
You will need to replace the belt on the machine. This is a fairly easy job, just go to an appliance repair shop, tell them the model number and they will get you a new belt. Then lay teh macine on its side and replace the belt. There should be a routing diagram on the washer, and if not you can get on online.
Posted on Mar 19, 2011
My maytag performa pav 2300 is making a loud noise while its spinning. Sounds like metal on metal. Its working fine. Its just that noise. We just got a new motor yesterday. What could be the problem ?...
Hello
On this model washer the noise is most likely caused by a worn washer tub seal assembly. remove agitator (nut on the top under cap), spin basket and tub assembly. remove seal and install new one.
Nov 03, 2011 | Maytag Performa PAV2200
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Maytag Performa agitates, but wont spin corectly.
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | Washing Machines
Maytag performa PAV2300AWW will not spin but sounds like it is.
I think you have guessed it right. There is probably something stuck between the tubs. I have seen this caused by a lot of things. You should look for things as small as coins, shirt buttons, cufflinks etc., Also I advice you not to turn on the machine until the blockage is removed.
Good Luck,
Sai.
Mar 15, 2009 | Maytag PAV2300 Top Load Washer
Burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
Jan 23, 2009 | Maytag SAV5710 Top Load Washer
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
Washing Machines Logo
54 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
