Question about Sherwood Audio Players & Recorders
SHERWOOD CDC-2000C ?D6376 starts skipping it was sent to be repair played about 2 discs when I got it back and started skipping again
  • Sherwood Master
  • 6,771 Answers
Unfortunately the laser pickup assembly needs to be replaced, overtime the laser becomes weaker until it can not track properly and will end up skipping or won't read the disc. It is far cheaper to replace the CD player than have the assembly replaced.
Posted on Mar 19, 2011
Testimonial: "Thanks for the quick response, will now look for as capatable unit"
  • John Cunningham Mar 19, 2011
    Thank you! glad I could help.
Sherwood CDC-5506 5-Disc CD Player - does it need Amp ?
Yes you need and amp Look at the disc player there is no volume control or speaker outputs.
Nov 21, 2013 | Audio Players & Recorders
Yamaha CDC-645 not playing
The lazer is shot. Could cost $150 to $280, to have it (repaired)
Oct 22, 2012 | Yamaha CDC-685 5-Disc CD Changer
I have a sherwood cdc-5090/c/r multiple cd player - it goes on error when using open/close, disc selector, disc skip. have tried troubleshing guide but doesn't seem to work.
The problem is in the CD loading bays, quite often the gears will ware over a period of time causing error messages because it is unable to complete the cycle. The second issue is the timing gears go out of sink because one of the CD'S gets jammed against the other causing it go out. The repairs are tricky because of the timing issue, however if gears are stripped the whole CD bay must be replaced.
Mar 10, 2012 | Audio Players & Recorders
Sherwood 5 Disc Player CDC 5030R Error Message Discs will not play Should I just pitch it or is it something that can be fixed easily? Thanks
I have an Sherwood Model CDC 5030R Multiple Compact Disc player the is showing a disc error? The disc sat in a garage for quite a period of time so the may be a lot of dust inside the unit?
May 28, 2011 | Audio Players & Recorders
Yamaha CDC-765: sometimes skips when playing CDs
The problem is in the laser for sure. Try cleaning with a cd cleaning tool. It's the easiest solution because changing the laser is not always available solution.
Stelios.
Feb 21, 2010 | Yamaha CDC-765 5-Disc CD Changer
Does it only play dts, my sherwood cdc 5090r player. it cant seem to play mp3. can it play WAV?
Yes, wav is what a regular audio cd format is made up of. That is what i would burn if you want to listen to them on the player.
Thank you,
Lee
Jan 02, 2010 | Sherwood CDC-5090R 5-Disc CD Changer
Is there a way of connecting my ipod to my sherwood cd player?
The answer isn't with the CD player, it's with the amp.
Does the amp have selectable inputs, or does it just have one input for each channel?
If it's a simple power amp, then you'll have to unplug the CD player and connect your iPod to the amp inputs. I'm guessing that the CD player connects to the amp with RCA (phono) connectors like these ones.
If that's the case, you can get a cable (like this one at Radio Shack, but any office supply store will have one too) to connect your iPod to the amp.
Jul 31, 2009 | Sherwood CDC-5090R 5-Disc CD Changer
CD Player Skipping And Spinning Backwards!
Clean laser first. Near the laser there will 2 / 3 adjustable pots. Mark location on them all first. Pick one (then another) move a little left or right and see if you can get it working. If all fails return them to original positions nothing but time lost.
Apr 01, 2017 | Yamaha CDC-502 5-Disc CD Changer
Skipping yamaha 765
I have a very similar type unit, a Nakamichi CDC-3 that had the same problem. I found this link....
http://repairfaq.ece.drexel.edu/REPAIR/F_cdfaq6.html#CDFAQ_001
I spent about two hours fixing mine. The sled mechanism was binding somehow, causing random skipping. The first 10 minutes was getting it apart and figuring what was wrong, the remainder was spent getting all those tiny parts back in the proper place.
Look up the exact symptom before going at it (probably long skips). Set aside a long slow lazy day with nothing to do. DO NOT drink too much coffee, you will be handling tiny parts that go in tedious locations, so you don't need caffeine jitters adding to your misery. Take your time and be careful. It's well worth it. Mine plays like a new one.
Nov 26, 2007 | Yamaha CDC-585 5-Disc CD Changer
132 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
