Question about General Electric JGBS23SELSS Gas Range
My GE gas oven Model JGBS23SEL1SS won't turn off unless I unplug the over. Once I plug it in the oven will turn right back on and heat up extremely hot
5 Suggested Answers
  • 126 Answers
SOURCE: GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Posted on Jan 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Posted on Feb 21, 2009
MNTECH
  • 1543 Answers
SOURCE: My GE PGS975 DEP1 (GAS
Power supply in Brazil is not universal over the entire country. Your range was built for 120 volt, 60 Hertz power supply. If you are in some areas, you may not have the proper voltage available. 127 V found in states of Bahia, Paran? (including Curitiba), Rio de Janeiro, S?o Paulo and Minas Gerais (though 220 V may be found in some hotels). Other areas are 220 V only, with the exception of Fortaleza (240 V).
Brazil does use 60 Hetz, but if you are in an area which only supplies 220 or 240 volts, you would need some type of adapter to convert that to 120 volts for your gas range. If you connected to the higher voltage, you may have irreversably damaged the electronic control, requiring control replacement, before connecting to the proper (120 volt) supply. I would expect 127 volts to operate your range, but if the voltage varied up from that, it could damage the control. Even in the US, voltage variations of 108 to 125 are rather common.
Posted on May 22, 2011
  • 9 Answers
SOURCE: We own a GE oven Model JGBP85WEJ3WW - THE OVEN
SOUNDS LIKE THE IGNITER IS BAD IF IT DOESN'T PULL 3.2-3.5 AMPS IT WILL NOT OPEN VALVE TO LET ENOUGH GAS TO LIGHT
Posted on Jul 22, 2011
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
Ge gas oven ran self clean door won't unlock door locked flashing lock motor running continuously
if your motor is running continuously, the door is locking and unlocking. catch it when unlocked, and unplug the range. then disconnect the power wires from the lock motor. this will allow you to use the oven while you get a new lock assembly and replace the one you have. should be fine after that.
Feb 04, 2012 | GE 25 in. GSC3200GWW Free-standing...
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 03, 2011 | Microwave Ovens
Me GE Gas oven is not working, but broiler and range do ?
I am working with model JGBP26WEH1WW GE Gas range: You do not need to remove the back or even turn over, just remove the storage pan at the base of the unit and disconect the two plugs (unique plugs). You will need to splice your old conectors to your new igniter. Yes you have the correct igniter for that model.
Apr 06, 2010 | GE Profile JGBP79 Gas Kitchen Range
This toaster oven gets extremely hot
Definitely return it. It has a partial internal short which is appying full power to only part of the heating element causing th excessive heat. No properly working appliance should make the outlet hot.
Jan 18, 2018 | GE Toaster Ovens
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge oven codes
F2 means your oven temp got too high. At least, that's what the control boards thinks. More than likely you have a bad oven sensor or bad wire to it or a bad connection somewhere between the board and sensor.
Dec 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Dec 27, 2008 | GE JKS05 Electric Single Oven
JVM1850BH02 Microwave completely shut down, not working after...
The extreme heat has opened up one of the thermostats / thermal cutouts (TCOs) in the oven.
If it was the bottom TCO or magnetron TCO, you should be able to access them by just removing the control panel.
But if it's the one on top of the cavity, the oven will have to come out of the wall, then you need to pull of the outer cover..
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You should locate and look this over first.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
General Electric JGBS23SELSS Gas Range Logo
55 people viewed this question
Top General Electric Kitchen Ranges Experts
Craig Butler
Craig Butler
reliableservice
DROPNDEAL
DROPNDEAL
Are you a General Electric Kitchen Range Expert? Answer questions, earn points and help others
