Question about Toro 51585 Power Sweep 7 Amp 2speed Electric Blower ()
It looks like the plug on the blower melted slightly now the blower doesn't work can it be repaired
    President:
  • Toro Master
  • 1,545 Answers
Parts are few for these machines (all I found was the blower tube). That being said, you can carefully cut off and remove the faulty male plug and replace it with a repair piece like you would add onto a damaged extension cord (outdoor type). They are made of plastic, but are fairly sturdy. Just carefully cut away the old male connector (the shrod isn't really necessary and remove the wiring from it. After purchasing the male-type plug replacement, rewire it and you will be set to go. To eliminate the male cord and the female end of the extension cord you will use from pulling apart when in operation, just loop the female end cord around the cord of the blower and it will hold in place.
Posted on Mar 20, 2011
My GMC Sierra 1500 2004 blower motor only works on high speed
Very common issue with those! Most likely will need a blower motor resistor at the least and possible resistor pig tail. They get hot and melt the ends causing a bad connection. If not going to dealer be sure to take bad resistor with you because there are two different styles that look similar until you go to bolt it back up. If replacing the pig tail replace one wire at a time so you do not cross wire it.
Nov 01, 2017 | GMC Cars & Trucks
Where can I get blower motor circuit diagram?
you don't need a diagram . you system is so simple you only have 3 things in it and one never fails.
you have a resistor that if it fails it never works again , so that's out
the motor can be failing and then work again .
but fords most common is a blower switch ,it melts .
so remove the switch and then remove the plug(if you can it might be melted to the switch) and look inside there to see if it's deformed , the plug might be deformed as well as the wires burnt.
start there first.
Feb 01, 2016 | 1996 Ford Contour
Heater fan not working
try wiring it so it is key on hot
Mar 08, 2014 | GMC Safari Cars & Trucks
Mechanic took a look at my A/C in my 2005 Isuzu Ascender. Told me it was the blower and thats why there is no sound at all. Installed a new Blower and it still doesn't work? Attempting to put R
Mathew, more than likely it's your blower motor resistor. These will tend to melt and or the connections will melt, making your switch useless. Suggest also replacing the pigtails, these will melt also. Next to the low beam headlight problem, this is 2nd most popular thing to go wrong.
Aug 20, 2017 | 2005 Isuzu Ascender
1996 chevy tahoe 4 w d 5.7l. recently replaced fan speed switch, resisitor and blower motor. worked fine for a few days and now nothing. all fuses are good. replaced resistor relay today. all ground...
Take a good look at all the connectors, especially at the blower motor switch and speed resistor. I find many of these connectors will be slightly deformed or melted from overheating and will not work even when plugged into a new switch or resistor...or may work for a bit then quit. If you find a bad connector the best thing to do is to replace the connector with a new one [they have to be spliced in] . Hope this helps and good luck!
Mar 18, 2011 | Chevrolet Tahoe Cars & Trucks
Trouble shooting climate control intermitting blower problem # 5 speed has not been working for about 3 months # 1 2 3 4 speed is now working intermittingly
GMC has an ongiong problem with the blower motor resistor, look under the dash on the passenger side and you will see the blower housing, unplug the wireing harness that feeds it and look at the plug carefully you will see that the third pin from the left has been over heated and is melted a little. the repair is quick and easy go to your local parts store and purchase a new resistor and a replacement wireing plug, you will have to cut the old plug off and splice the new one in, replace the resistor and your done. I would recomend that the wires be and spliced cut one at a time so as to insure that they are put in the right location.
Sep 10, 2010 | 2005 GMC Envoy
My Heater Blower motor stopped working on my 2007 Chevy Suburban
you will need to check 3 places for this. 1 check the plug going to the blower motor for being hot and melting.2 check the plug going to the blower motor resistor for being hot and melting. 3 check behind the heater control head itself for being hot or melting.chevrolets are bad about these three places not making good contact and melting the connectors.
Dec 27, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Blower stopped working
Bad blower motor resistor.Remove plug & look to see if the plug is burnt/melted on any contacts.Also check the pigtail that plugs into blower motor.I only had to replace my resistor.
Jan 03, 2009 | 1999 Chevrolet C2500
Toro 51585 Power Sweep 7 Amp 2speed Electric Blower () Logo
416 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
