Question about Fujitsu Siemens AMILO Pro V2000 Notebook
No Power Laptop Siemens Amilo Pro V2035D is completely dead ! The Power Adapter is working ok and delivering 19v as per spec. but there is no power when the on/off button is operated !
  • 1 more comment
  • Anonymous Aug 10, 2008
    I have exactly the same problem, one day the laptop just stopped working, no power, no lights at all nothing. Charger is delivering the requisite 19V also.
  • t0pc4t
    t0pc4t Aug 13, 2008
    As additional - - I have tried this with no success....
    However - It may be worth you guys giving it a shot.
    Remove Battery and mains lead.
    Press and hold the power button for 15-20 seconds (This will discharge / remove any residual power)
    Re-insert the mains lead only . . now try and power up.
    If this does not work - Its hardware failure . . ~£100 to return and investigate by fujitsu... then repair cost on top ... likely motherboard as its all SMT
  • bijoutroniqu Aug 17, 2008
    Thanks to t0pc4t... tried suggested solution, but no luck...
    guess as suggested it must to back to Fujitsu for investigation
    John Bolton (bijoutronique)...
  • 132 Answers
Same here - mine has died in the last hour . . all of a sudden the battery light comes on 'as if to charge' - then goes out.
any help would be appreciated..
Posted on Aug 13, 2008
Laptop failure
never leave a system running unattended for long period of time without a battery back up (UPS), as low and high current spikes will cause damage to the circuitry of the computers mainboard.
Have you tried using the AC adapter to power up the computer ? if that works and the battery is dead, simply replace the battery. if the system is not powering up at all, then the issue is bad AC adapter or the mainboard is damaged from overload of current.
Feb 05, 2012 | Fujitsu Siemens AMILO Pro V7010 Notebook
Hi i have a siemens amilo pro v2035 laptop its not powerong on i opened the laptop and saw something burned next to the dc port i soldered it but it still deosnt work
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.
May 01, 2011 | Fujitsu Siemens AMILO Pro V2010 Notebook
I wonto mother boad softwhere
on this page
select your model and on next page select your operating system.
Feb 27, 2011 | Fujitsu Siemens Amilo Pro V3405 Laptop Ac...
Where i can buy, power socket for my amilo pro v2010?
Just one example,
The power socket in the laptop that the AC adapter (Charger) plugs into is a DC Power Jack.
Type Amilio Pro V2010 DC Power Jack in your browser search bar, press the Enter key.
To add:
Nov 07, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Four keys as g,h, backspace and windows key is not working of my fujitsu siemens amilo pro v 1000 keyboard.
SOLUTION FOR Four keys as g,h, backspace and windows key...:-
I read this on a website and it worked wonders for me. TRY THIS:-
1. Just remove the adapter so that your laptop does not get any power.
2. Let the battery go completely empty and let the laptop get shut down with low battery automatically.
3. After laptop gets shut down, remove the battery and clean it with some cloth. Also clean the battery panel.
4. Press and hold the power button for kind of 30 seconds or so (laptop will not get ON).
5. Plug in the adapter to the laptop and start the laptop normally.
This process will fix it for you.
If the above does not work:-
1. Start the computer in safe mode with the last best configuration. It may also work for you.
- Naveen
Aug 24, 2010 | Fujitsu Siemens AMILO Pro V1000 Notebook
Connection to wireless
There is any wireless adapter showing in the control panel.
According to the laptop specs, this laptop did not come with wireless capability. You need to purchase a wireless notebook adapter for it or us it with a network cable.
See the specs on this link:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 07, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Amilo Por 2055 DEAD
Try powering from the mains and see if your battery is being fully charged.
Aug 13, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu-Siemens - Batteries won't charge
Whats the spec of your power supply (approx 19v dc @ 3 - 4 Amps...)
Voltage 'OFF LOAD' is irrelevant - its the power consumption (A) that you need to validate (Do not measure directly)
Does the Laptop power up under mains feed ?
Is your concern mainly the fact that the battery(s) are not charging ?
Mar 30, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
330 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
