Question about Nintendo Wii Console
Hand control I have 2 hand controls, both won't work. I have changed the batteries, pressed the red sync botton lights flash but nothing happens, please find problem.
    Problem Solver:
  • 5 Answers
Is your sensor bar hooked up? is it visible where the remotes can sense the remotes?
Posted on Aug 02, 2008
I have tried programming my wii remote but it won't work. I pressed both the sync buttons, but all it does is flash on all 4 dots and then quits. I've changed the batteries in both remotes, as...
Here's what to do. I've had this happen many times.
1. Open up the SD Card compartment on the Wii.
2. Open up the battery cover on the remotes.
3. Press the red Sync button on the Wii, and then on one of the remotes.
4. Repeat for whatever remotes need synced.
This will make every remote act like the P1 remote. For temporary syncing, just go into the Home Menu and click Wii Remote Settings. Click on another option(it'll say to press 1 and 2) and follow the instructions.
Jul 19, 2011 | Nintendo Wii Remote Controller
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
Have not used for bout a year, i have no lights on the hand set, i have put in new batteries and still nothing
hi, try the following.
1 turn the wii on and wait for it to come on
2 open the flap where the sd card goes
3 take the back off the control where the batteries go
4 press the red button on back of control
5 press the red button on the wii next to the sd card slot
that should then sync them together and get them working.
if when you press the red button on the back of the control where the batteres nothing happens then change the batteries and if it still dont work then their is a fault with the control
let me know how you get on or if you need further assistance ok
please rate this solution and leave a testimonial as i have a whole page of unrated posts as people dont rate them, thanks
Dec 08, 2010 | Nintendo Wii Console
On my wii remote at the bottom of the remote belong 1&2 them lights all flashing and it will not pick up we change the batties still not working can you help me..
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
Nov 29, 2010 | Nintendo Wii Console
When I turn on WII it says ''press A to continue''ut nothing happens. I have changed the batteries in the remotes but they do not respond. I have checked the sensor is plugged in.
If you have more than one remote, you may have to "sync" the remotes to your Wii system.
1. Open the battery cover on your remote and press the red "SYNC" button. The lights on the remote should begin flashing.
2. Open the cover on SD Card slot on the console and press the "SYNC" button.
3. The lights on the remote should stop flashing after a few seconds. Your remote is now ready for use.
This process must be repeated for each new remote.
Feb 09, 2010 | Nintendo Wii Console
If you have multiple wii remotes, make sure the remote you are using is synced to your system. In case you are not sure how to do this:
1. Open the battery cover on the remote and press the red "SYNC" button. The lights on the remote should begin flashing.
2. Open the SD slot on the Wii system and press the "SYNC" button.
3. Once the lights on the remote stop flashing, the process is complete and you should be able to use your remote.
Remember, you have to go through this process with each new remote in order for it to work.
Feb 09, 2010 | Video Game Consoles & Games
Wii is comming on but when it says press a button nothing happens new controls aren't working or sensor bar isn't picking it up what to do
You probably need to synchronize your Wii-Motes to your system. When you press buttons on your controllers do the four LED lights flash at the bottom? This is a clear indication. Your Wii needs to be turned on. You need to open the little door on the front of your Wii where the SD card slot is. Under the slot there is a little red SYNC button. Then open the battery compartment on the backs of your remotes. There is another little red SYNC button here. Press the button on the remotes and then while they're flashing on the Wii and it should sync. If it doesn't work the first time try again.
Dec 22, 2009 | Nintendo Wii Console
Cannot get the remote to turn on. Get four continuous blinking lights then nothing. Replaced batteries and tried "slapping it" on my hand...still NOTHING!
did you try to sync it? Thier is a red botton on the back of the controller, also one on the middle of the wii were the sd card goes in press that and press or hold the red botton on the controller.
Aug 08, 2009 | Nintendo Wii Console
Setting up 2nd wii remote
Greetings mlsaenz7,
You need to resynch the second remote to the Wii console. To accomplish this you need to hit the sync button under the battery cover on the remote, and then when the lights are flashing on the remote, you hit the sync button on the Wii. The synch button is located under the small cover to the left of the cd/dvd slot.
Thank you,
Dort
Go Ahead. Use Us.
Apr 19, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
32 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
