Question about Zebex Z-3080 Handheld
I have a zebex z-3000 bar code scanner that cannot run on windows 7, it always say device not functioning code 10 error. i think its compatibility issue, is there any solution for this?
How do I install colorpage-vivid3x on windows7
Assuming that you have the driver but not for windows 7 ..there is a possibility for this to work ,,if you copy the driver into the hard disk ...and change its properties..I never looked if there is a driver for windows 7 released by the manufacturer..but usually there are no drivers for older products..so the thing to try is like I said ..First insert the disk ..and copy its content on a location on the computer ..After that ..open the folder ..and look for the executable (install ) icon ...and click right on it ..and choose properties..and in that windows. choose compatibility ..and inside ..choose to run in compatibility with windows xp (if the driver is built for windows xp ) ..and afer that click apply ..and ok ..and run the driver..
It may give you a error ..and say it is not compatible ...and after that give you the choice to run it in compatible mode..so choose this version ..and always select to run it anyway no matter what the windows says about it ..when you finish ..just restart after you connect the device too ..(you may connect the device before installation ..but the restart may be critical for functionality ..
let me know if it makes issues and do not want to work ..
http://downloads.kappa.ro/drivers/scaner/genius-colorpage-vivid-3x-xe.html
this is supposed to be the driver for it ..but like I said I dont think it was made for windows 7
so ..try like I said
Have a good day !
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Genius ColorPage Office Equipment &...
Please help me i need driver scaner Astra 3400 for win 7 32 bit
Your device is not fit to run under Windows 7 .
Try installing a virtual version of XP on your system : http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html
or purchase a W7 compatible replacement device ( starting from 100 $ ) .
Best regards ,
fanaudi .
Sep 13, 2011 | Umax Astra 3400 Flatbed Scanner
Driver for windows seven (7)
Hi prof_el7ob ,
The latest to be found is for XP . It won't work under 7 . Try installing a Virtual version of XP on your system : http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html
Or purchase a W 7 compatible replacement device .
best regards ,
fanaudi .
Sep 12, 2011 | AcerScan 620P Flatbed Scanner
How can I get Canon CanoScan N640P ex Flatbed Scanner to work in Windows 7?
Hi Nubi ,
There is no direct solution since Canon doesn't support your device under Windows 7 .
You can install a virtual version of Xp on your machine with http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html or via Microsoft if you are using Ultimate or Professional .
Otherwise , you will need to purchase a replacement device compatible with Windows 7 .
Best regards ,
fanaudi .
Aug 27, 2011 | Canon CanoScan N640P Flatbed Scanner
I have a Canon 4200F scanner and recently purchased a new computer with Windows 7 that is 64 Bit. When I try to use the scanner get a message that I need a WIA driver to use this device. Can you please...
Hi bjgestel !
This means there is no more support from HP for your unit under Windows 7 but Windows has a compatible driver included in it's system ( WIA ) .
The scanner should run smooth but with some restrictive functions . Normaly , it should run without having installed the HP XP driver/ sofware . If this not your case , there is a workaround after you installed the XP driver and made sure installation was successfull . The scanner will need to run with a third party application . Download FreeKapture from
http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Launch Freekapture , clic on Scan , select WIA-Hewlett-Packard . Your scanner will run . If you choose HP's software, program will hang .
Note : no slides or negatives scans possible in WIA mode but the rest works .
Good luck !
fanaudi .
Feb 22, 2011 | Office Equipment & Supplies
Error code 0x24050010 Canon scan N640P in windows 7. please please help me...
What you need to do is run the driver setup in windows XP compatibility mode.
Right click on the setup icon, select properties, compatibilities tab then select Windows XP SP3 (or some older version of Windows.
Then left click on the "Change settings for all users" button and from the new window select again XP service pack 3 compatibility and check the "Run this program as an administrator". Click OK and then run the setup application.
It worked for me on Windows 7 ultimate.
Sep 16, 2010 | Canon CanoScan N640P Flatbed Scanner
I have MP250 all in one I installed the drivers on windows 7 the printer and copier are working well but when I scan a paper the following error appears [ can't communicate with scanner cable may be...
More recently Canon updated drivers and firmware for printers. With the modernization of Windows OS to Win 10 (2017-18) all reference code is now Win 10 and not always backward compatible. You would be best served to update the operating system, update the printer drivers and firmware. Once you do this, everything will speed up, go smoothly, and you will be more secure.
Jan 12, 2018 | Canon Office Equipment & Supplies
Is the ds6707 compatable with windows 7?
If connected with a CBA-U01-S07ZAR and programmed as the default HID keyboard USB host type, yes it should be compatible. The device uses the same drivers the host uses for a USB keyboard.
Jun 22, 2010 | Zebra DS6707 Bar Code Reader Barcode...
I am running windows 7 (upgraded from Vista which came on the machine at purchase). My dvd drive stopped working suddenly and it won't allow me to reinstall the driver. (hl-dt-st dvdram gsa-t20n ata device...
The Code 10 error code is generated when Device Manager has insufficient information or the error that is bubbled up by the device drivers is not recognized by Device Manager. Additionally, this error may occur when one of the drivers that the device needs does not start.
The Code 10 error pertains mainly to hardware and device driver issues or to compatibility issues.
Did you try Windows Update? You need to configure it so it looks for drivers as well.(is not by default).
It's strange since most drivers for Vista will work for Windows 7.
Another thing you can do is update and uninstall the driver, and restarting... that should take of it. I hope this helps. Please let us know if you solved the problem and do not forget to rate and provide positive feedback for our fast-free support today. Thank you :D
May 03, 2010 | Microsoft Computers & Internet
Stopped scanning
I seldom do this ...but I will comment on the Zebex scanner. This is ...errr ... not the best choice for future scanner needs. I will never forget commercial Zebex experience. They should have stuck to anti freeze (just kidding).
However if it did work and now doesn't there is one problem that is so obvious no one thinks of it ... check the clear plastic protector on teh front and see if it need cleaned. Greasy environments usually fog it over time.
I have the Zebex default codes somewhere in the shop ... but you can replace that scanner with a nice PSC, Mot, or Intermec for about 120.00 why not do that?
Jan 07, 2008 | Zebex Alpha-70 Handheld
Zebex Z-3080 Handheld Logo
303 people viewed this question
Top Zebex Computers & Internet Experts
David Payne
David Payne
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
