Question about PfaFF Tiptronic 2040
Have a Pfaff 6270 tiptronic sewing machine. When I turn on the power switch the light goes on but the display remains off.
  • dodger03 Mar 19, 2011
    Is this something I can do myself? I have a multimeter. There are four screws at the base. Do I take those out to lift the housing and then would I have access to the fusible links. Would I also be able to gain access to a faulty fuse?
  • dodger03 Mar 22, 2011
    I took the machine to an authorized dealer for repair.
  • 12,061 Answers
Hi, well most often when this happens, it is either the Power Supply, or the Controller. However, it also maybe any one of a myriad of "Other" faults, that unfortunately display the same symptoms, ie: lights on, No go, No display..
The very best thing you can do is take it into a Pfaff authorsied servicing center, contact either a local or head office, and ask for a referral to a local service center.
now when there, ask them for a "Quote"as to the repair, and if the "Quote" seems acceptable to you then you have the option of repairing or replacing depending on costings.
Posted on Mar 20, 2011
  • 17,130 Answers
Possible failure of the power supply - sub supply - to the main board - display board.
Possible failure of the processor or the display unit if nothing works. You might need to check individually the power to all the sections of the controller board to confirm. Unless a voltage check is taken these factors can only be speculated.
So use a multimeter to confirm , if power is faulty or a fusible link is faulty you can replace with the same rating.
Posted on Mar 19, 2011
  • Donald DCruz
    Donald DCruz Mar 21, 2011
    Yes , it is worth a try to have this first observation but take care that you are insulated and keep away from live circuits.
My Pfaff Tiptronic 6270 does not sew.
Try unplugging the power cord from the machine, let it set for a few minutes and try plugging in again. Sometimes this will reset the machine.
Here are other postings on Fixya that sound similar to your problem:
Pfaff Tiptronic 6270 just stopped working
The memory board went out on my 2000 tiptronic 6270 couple years ago now...
Sep 05, 2015 | Sewing Machines
2040 tiptronic board replaced
I would take the machine to someone else and see what they say.
Mar 16, 2014 | PfaFF Tiptronic 2030
I was just gifted a Pfaff Tiptronic 6270 for my charity quilting.I have no manual,and cant figure it out.How do I use it? How do I thread it? I just want to sew a basic chain stitch,nothing fancy..help!...
there a bunch of sites selling this manual but i'd suggest you try the manufacturer first
ContactSVP Worldwide
C/O Husqvarna Viking
P.O. Box 7017
LaVergne, TN 37086-7017
Toll free assistance - 1-800-446-2333
Monday-Friday 8:00 am - 4:00 pm CST
Email:
info@pfaff.com
(Please allow 72 hours for response
Mar 24, 2011 | PfaFF Sewing Machines
The memory board went out on my 2000 tiptronic 6270 a couple years ago. now the machine won't sew at all. the sewing light comes on, but not the lighted digital readout area. so , no sew. how do i...
There is a fuse in the the base plate
that has probably blown. It is soldered in and needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff). Sorry for the inconvenience, hope you are back to enjoying your Pfaff machine real soon.
Aug 01, 2010 | PfaFF Tiptronic 2030
Pfaff Tiptronic model 2030 LCD display panel went dark, no display. Now lamp burns hot. Told by local service shop that panel needed to be replace to correct lamp issue. Need replacement lcd panel.
very common prob . with pfath . panel failure . display failure . no easy sol . but to repl pc control panel .. / how ever after repair ( and they never tell us .. use a surge power controler on the line . to your machine .. .. **** .. hope this ansewered your Q " mm feed back pls .. mm
Jan 15, 2010 | PfaFF Tiptronic 2030
Pfaff Tiptronic 6270 just stopped working!
There is a fuse in the the base plate that has blown. It is soldered in and is special fuse you won't find at Radio Shack. Unfortunatly it needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff).
Sorry for the bad news and best of luck.
Jan 15, 2009 | PfaFF Tiptronic 2040
Frozen Sewing Machine Arm/Pfaff Tiptronic 6270
Good morning,
A question to help determine what's happening with your machine(s).
Open the bobbin case so you can see the bobbin area. Begin by trying to turn the handwheel towards you and watch as the needle attempts to go up/down. If you cannot turn the handwheel towards you, turn it slightly backwards then forwards. Does the needle hit the bobbin case as it comes down?
If yes, your machine is out of time and will require a professional technician to repair.
If the above is not the case, there may be thread jammed behind the bobbin case or wrapped around the inner parts of the take-up lever.
Either case - a Pfaff authorized technician would be your best bet for a proper repair.
Best of luck with your machines - it's just awful to not have the at the ready for all our projects!
Happy sewing,
Kim & Linnette
Jul 30, 2008 | PfaFF Tiptronic 2040
Sewing machine repair
I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. You can learn how to repair different brands of sewing machine as well.
Feb 07, 2008 | PfaFF Tiptronic 2030
Sewing Machines Logo
243 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
