Question about Amana RFS12MPS Microwave Oven
Amana rfs12sw2a....1200watt The soft touch buttons don't respond except for number 6....
    Scholar:
  • 75 Answers
Sounds like a bad control board. First just check and make sure all of your connectors are in tight. Part numbers for the control board is 53001806 you could have a bad touch panel. rare and not typical but can happen part number for that is 53002019. I would probably buy both of those parts plug in the new panel into the existing control board and see of everything works. if so replace the touch panel and send the control board back. If it still does not work then swap the control board and send the touch panel back. hope that helps
Posted on Jul 18, 2013
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Amana microwave rfs12sw2a Put in new magatron
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Mar 29, 2011
Control panel not responding to touch -- NOT in locked mode!
Sounds like you have a shorting membrane keypad, or there any be moisture or grease in the controls.
To remove the controller to check for grease and moisture, see the video here.
We would need your full model number from the tag in the cooking cavity or elsewhere on the oven to help you further, and our advice is free.
Please post a new help request with the full model number.
Jun 09, 2013 | GE Appliances 30" Trivection Built-in...
FFCM1134LS
The "6" pad on the microwave's membrane keypad is shorted.
If this is under warranty, refer to your owner's manual to contact Frigidaire customer service about finding a local servicer to fix it under warranty.
If it's out of warranty, looking at the retail price of this model, it may not be economical to have it repaired.
If you or a friend can get a new keypad from Frigidaire at a decent price, you can refer to a handy guide with pictures showing you what's typically involved.
Jan 30, 2013 | Frigidaire FFCM1134LS Microwave Ovens
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
ser Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
How do I fix the programmed buttons 1 - 5, they stopped working? We can only use the 6 and above numbers.
You must dismantle the circuit board and check if some grease vapours between touch buttons and the the circuit film. Clean with some wet soft cloth.
Nov 13, 2017 | Whirlpool MH3184XP Microwave Oven
I have an 2009 Amana wall oven model number AEW4530DDB. We had a power hit a few days ago and now the #3 7 and 8 buttons on the control panel do not work.
Hello, Thank You for using FixYa. I will be helping you today.You would have to replace the touch membrane.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Amana Microwave Ovens
Amana microwave rfs12sw2a Put in new magatron worked for 3weeks Now will not heat
heatman101
Mar 29, 2011 | Amana Microwave Ovens
How do I get it out of lock mode
If the model number you have listed is correct, you turn the Child Lock feature on/off by pressing and holding the "Clear/Off" button for three seconds. The instructions are on page 28 of the Owner/Operator Manual.
If your model number is different from the one you have this question posted under, please post back with your correct information so that I may be able to provide you with better assistance.
I hope this helps you.
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
We have an older Radarange over-stove microwave oven with touch pad controls. Whenever I boil something without a lid for a longer period, some of the buttons stop working. Usually, they begin working...
Call Amana customer service. Microwave ovens should be able to handle the high humidity you are talking about.
Here's the contact information:
Have your complete model number ready. You can find your model number and serial number on the label located on the upper or lower
front facing of the microwave oven opening, behind the door.
For assistance or service, call 1-800-843-0304.
If you need further assistance, you can write to Amana with any questions or concerns at:
Amana Brand Home Appliances
Customer eXperience Center
553 Benson Road
Benton Harbor, MI 49022-2692
Aug 05, 2009 | Amana Radarange Microwave Oven
Amana RFS12MPS Microwave Oven Logo
291 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
foster_mommy
Level 1 Expert
Jim Thurston
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
