Question about Sony PlayStation3 HDMI Cable PS398089
Have a plasma tv hooked to my ps3 with hdmi but plasma is down for the count.. hooked up the old a/v cables to play on old tv but can't get any picture... what do i do
treborswindl
  • 212 Answers
SOURCE: My PS3 only works on my Plasma TV's HDMI channel.
When you have the ps3 hooked up through av cables on crt tv not hdmi. Continue to hold power until the console beeps again and this will reset which audio video output resolution back down so it can be seen and heard. Hope this helpes.
Posted on Jul 13, 2008
leme
  • 25 Answers
SOURCE: PS3 will not display on TV
WHEN YOU START YOUR PS 3, KEEP YOUR FINGER ON THE START BUTTON UNTIL YOU EAR A SECOND BEEP ( BETWEEN 5 & 10 SECONDS); THIS WILL RESET AND SELECT THE RIGHT CONNECTION . I HAD TO FIND THIS PROBLEM WHEN WE WERE SWITCHING FROM THE LIVING ROOM TO MY KID'S ROOM.
LET ME KNOW, HAPPY NEW YEAR.
PIERRE ( MONTREAL)
Posted on Jan 02, 2009
  • 7 Answers
SOURCE: My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
Posted on Jul 06, 2009
A14MED
  • 30 Answers
SOURCE: My ps3 wont work with my lg lcd tv
when the ps3 turns on hold the on/off button untill you hear two beeps. this will make the ps3 look for the new cables and the tv
Posted on Oct 17, 2009
SOURCE: PS3 not working thru HDMI cable
i am having the same problem, so i called the mfg. of the tv and they told me to set the PlayStation to out put 1080i and not 1080p i don't think this is possible. my tv is a Hitachi and they are sending me an update card for the tv, hopefully this will fix the problem. Apparently its a problem with the tv not being able to receive a 1080p signal
Posted on Oct 31, 2009
When I hook up my LG plasma to PS3 and Cable box, I don't get any sound or colour on the PS3. The TV /cable box works fine. Any ideas on the wiring?
What type of connections are you using? HDMI? Component? Composite? What audio? HDMI? Optical Digital? Analog audio?
Are you saying you get video from the PS3, but it is in Black&White only? Is there an NTSC/PAL selector on the PS3? If so, it may be set wrong. Set to NTSC if you're in the United States.
Feb 01, 2013 | LG 50PC3D 50 in. Plasma Television
Iplugge in my PS3 using an HDMI cable and i get no feedback
ps3's are a pain in the _ss..
you need to connect it through your standard cables as well.. use the component cables that came with the ps3 and connect it to your tv's coloured inputs..
change the tv to that source and then go to the video settings on the ps3, and then choose the hdmi option..
now.. once the option is chosen, you have about 30 secs to change the source on your tv to the hdmi source to see the picture while the timer counts down (making sure both the hdmi and the component cables are connected to the tv at the same time)..
now that you are on your hdmi source on the tv, choose accept (X) on the ps3 menu and you should have your hdmi setup
if you run out of time, no problem, just go back to your component source input and repeat the process faster
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
How do i hook up my ps3 to my tv
Buy a cable call an HDMI cable.Just connect one side of the HDMI cable to the PS3 HDMI port and the other side of the HDMI cable to the tv HDMI port.Than use the remote,push the button said INPUT goes into modes 1,2,3... so on to find out which one the PS3 game system is on.
Nov 20, 2010 | Zenith Z50P3 50 in. Plasma TV
I have no sound through my surround sound when playing ps3
The optical audio out from the TV only works for the TV's tuner, probably. Hook-up optical from Cable/SAT and from PS3 boxes to DVD/Receiver.
Apr 20, 2010 | Pioneer PDP-LX508A 50 in. Plasma TV
Hookup problems
The video settings will have to be reset back to the basics (a/v) after being hooked up using the HDMI cords. Simply power on the unit and continue holding down the power button for about 5 seconds. You should hear a beep. This should reset the video settings back to the original condition.
Dec 12, 2009 | Sony Playstation 3 (PS3) Console
No dvi pictur showin up on my plasma tv
try a lower video output resolution on your PS3
Nov 09, 2009 | Gateway GTW-P42M303 42 in. Plasma...
My PS3 only works on my Plasma tv's HDMI channel. None of my other tv's have this HDMI channel. Why doesnt my PS3 work on any other channels or my other tv's? Could anyone help out with that?
Jul 13, 2008 | Sony Playstation 3 (PS3) Console
I just brought a plasma tv and how do I hook up my cable tv and ps3 to it?
standard cable, just hook it to ant 1 or 2...your ps3 should have an hdmi connection, looks like an oversized usb cord. hook your ps3 into hdmi 1 or 2 or 3, doesn't matter. then switch your inputs on the tv accordingly.
Jul 11, 2008 | Panasonic Televison & Video
Same happened to my ps3 one week from new , took it back the the shop and got a refund.
Oct 06, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation3 HDMI Cable PS398089 Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
