Question about Oster Microwave Ovens
I have an oster ogg61001 stainless steel countertop microwave, when turned on the time is counting down but the oven is not engaging/heating...
  • Kathy Aug 03, 2013
    Oster model OGG61101 is a 1.1 cu. ft. countertop microwave. Read instructions. Tried everything. Turn table will not work. Will not cook. Can only set th timer. Any suggestions?
MicrowaveSvc
  • 9098 Answers
SOURCE: i purchased a stainless steel
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can contact them at the number in your owner's manual. If you don;t have it, I'd check with the dealer to see if they have contact info.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
SOURCE: Oster 1.1 cu. ft. Stainless Steel Combination Microwave Grill - OMW1199
After six months I just figured it out. Push the cook by weight button in and hold it until the clock function comes on. Turn left for hour and right for minute. Figured this out by holding the cancel button in and a child lock came on, I didn't know how to release it so I reversed the process by holding it in and it cleared. I tried it with the cook by weight, which has a small clock icon next to it and voilla.
Posted on Nov 03, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: ge microwave shuts down after three seconds
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Let us know what you find out.
Otherwise, this is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at
http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Sometimes they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jun 16, 2009
  • 400 Answers
SOURCE: how do u install a kenmore microwave oven over the
Installation instructions should have come with it. If not, do a Google search online to find the installation manual. Generally there is a plate that installs on the wall and the microwave hooks into it and fastens to the cabinet above. Try this website for a manual. http://www.pdfoo.com/result-kenmore-microwave-installation.html
Posted on Oct 30, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
Feb 23, 2015 | Bosch HMT75G451B Stainless Steel...
How do I stop the dashes on my kenmore microwave oven to stop blinking
some models blink so they keep time that way but if it doesn't change you haven't finished settings
Jan 02, 2015 | Kenmore 1.6 cu. ft. Countertop Microwave -...
Oster microwave starts when door is closed but no buttons pressed
This is usually caused by a door switch that has come loose or out of adjustment.
Jul 19, 2014 | Oster 0.7 Cu. Ft. Countertop Microwave -...
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Will not power on
there is a fuse inside your microwave that may have blown out. most people throw out there microwaves and normally just the fuse inside.
Jul 07, 2012 | Oster 1.4 Cu. Ft. 1000w Stainless Steel...
Oster OM1201E0VG countertop microwave
It sounds like the thermal fuse may be defective, or the fan is not running, or the magnetron is getting to hot. If there are any heat issues the thermal fuse will cut power and reset in 5 minutes.
Mar 07, 2012 | Oster OGB61101 Microwave Oven
My LG Microwave LRM2060ST turntable has stopped turning. This is a 1200 watt 2.0 cu ft countertop model.
If the oven is heting and turntable not turning, then the problem is either the turntable coupler or the turntable motor.
The faulty part must be checked and replaced.
Sep 09, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
Microwave stopped heating, evenything else works
Jan 03, 2009 | KitchenAid KCMS1555RSS Stainless Steel...
Microwave Ovens Logo
339 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
ray gallant
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
