We will be watching the tv or any other audio or video source and the receiver makes a "pop" and the audio goes out. If we are watching TV the picture stays on till I turn off the amp to reboot then I don't even get the picture. I get nothing from the DVD or VHS player either. The way I have been geting it to work again is to turn the receiver on and off or waiting and try turning on 30 min or ab hour later. I do not think it is a thermal issue because I turned it on this afternoon after it had been off for 3 or 4 hours and it didn't work. It took me about 30 minutes of fiddling in with turning it on and off to get it to work. This happened about 3 months ago and the problem didn't happen again until today. I tried contacting Denon but they said they had no idea what was wrong.
    Scholar:
  • 117 Answers
Sorry to say it, but you just need to get a new receiver. There is probably a capacitor going bad on the circuit board. It's only a matter of time before it quits completely. The only other option is to take it to a repair shop where it can be tested. Hope this helps.
Posted on Mar 19, 2011
I am trying to hook my pioneer vsx-455 up to my samsung dlp-hd tv and have no idea which pre-outs to use.any help would be greatly appreciated.or do i need to go through the cable box and if so how?
Ok. Where does the TV programming originate? Antenna, TV, or (usually) the Cable Box. I'll tell you sight unseen, no TV ever adds to the audio experience. many of us watch on monitors so that would suggest that a TV can play absolutely no part in the high-end audio experience. It's specialty is video with basic audio capacity thrown in. A Cable Box is for all purposes a digital audio and video source with separate outputs for each. Keeping with my practice I'd run the BEST VIDEO (and minimum audio in case you want to use TV speakers for that source) from each video source to the TV (it has multiple inputs, right?) and the BEST AUDIO (no video) from each source to the receiver. One video connection from the receiver to the TV for set-up/control. This requires some switching on your part to watch different sources but it eliminates troublesome and unnecessary routing and handling of the individual signals.
Nov 08, 2011 | Pioneer VSX-455 Receiver
Hi, when I plug my TV's optical out into the Nakamichi AV8's optical input, and switch to "DVD/Optical" (after hitting "Digital Input" buttno) ... no sound comes out. I have...
Maybe assign it?
If the digital TV-related audio actually originates elsewhere (Cable Box?) you could skip the TV and use the Cable Box as the audio source. Nothing is gained by flinging an audio or video signal around the room to be handled (but not improved) by any device. I have no video entering my receiver and nothing but bare bones analog audio going to my TV in case I want to just watch the news or something else lo-fi.
Jul 14, 2011 | Nakamichi AV-8 5.1 Channels Receiver
We are trying to hook up a samsung flat screen TV, a sony home theater system, direct tv box, and a panasonic DVD to the dynex component video converter box. Which cable goes where
We can't make assumptions. Did you set it up in accordance with the manuals?
Without specific details...
In general, ins go to outs; compatible connectors need no modification.
If you have an HDTV and HD Satellite I don't think you want to be tying the video quality down to S-Video.
There are two signals to consider here. Video and Audio. TV's are expert at Video and A/V Receivers are expert at Audio, so each should get first crack at the specialty for which it is designed.
HDMI or Component Video (Red, Green and Blue RCA cables) are the best and ONLY ways you'll get Hi Def to the TV. If you route EACH HIGH DEF SOURCE'S VIDEO DIRECTLY to the TV (instead of through the receiver or a switch) the TV/monitor will receive the best video digital data.
Digital Audio from as close to the real source as possible (SAT Box, maybe) to the receiver.
Standard analog audio from the SAT box to the TV for watching lo-fi content like news and weather without the Sony HTS turned on.
Mar 15, 2011 | Dynex S-Video A/V Selector Switch
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
Can I connect my Magnavox LCD TV to my JVC RX558V receiver for surround sound? I can't figure out what to connect to what?
Think about this. Your TV is NOT the source of HiFi multichannel sound, but the source IT is watching might be. THAT is the best place to get the digital audio you want for the receiver. Run digital audio cables from he Cable Box, Sa, DV. BluRa, whatever to the JVC.
I also advise against running video THROUGH the receiver, opting for direct best conenctions from the source to the TV.
You SHOULD run at least a composite video cable from the receiver to the TV so you can use it to set up receiver things.
Dec 28, 2010 | JVC RX-558V
Have a Sherwood receiver RD-6108 and want to hook it up to my LG plasma tv to have surround sound. How?
Think about this. Your TV is NOT the ultimate source of HiFi multichannel sound, but the source IT is watching might be. THAT is the best place to get the digital audio you want for the receiver. Run digital audio cables from he Cable Box, Sa, DV. BluRa, whatever to the Sherwood.
Dec 28, 2010 | Audio Players & Recorders
Cant hook it up to the tv and make sound on speakers
There are a couple of things going on here.
First concept: The physical TV is NOT a good source of audio or video. It's there to turn audio and video from other sources into something your senses can enjoy. Many TV's (monitors) don't even have speakers.
You probably want the TV-related audio to play on your Sony. Your best source is to get it where it comes from. That is NOT the TV, more likely cable or satellite. Draw the best multi-channel audio (digital, if available) from it into the compatible input on the Sony.
The cable box will also have video and analog stereo audio. Run the BEST VIDEO (HDMI or component) to the TV's video and the analog stereo RCA Audio Out to the TV's Audio In so you can watch and hear cable without the Sony if you like.
You could also run the TV's analog Audio Out RCA pair into an AUX input of the Sony, but that would limit whatever you hear to stereo and any audio limitations of the TV.
Mar 11, 2010 | Aiwa AV-D67 Receiver
How to connect my kenwood vr-606 digital audio to my tv... i tried to connect digital audio cable from my tv digital audio output to kenwood vr-606 receiver digital audio in and it's not working.. what did...
Your TV is NOT an audio source by itself. It's job is to make pretty visual stimulus for your eyes, not your ears. Everything IT hears comes from somewhere else like a DVD, BluRay, Cable Box, right?
Get the absolute best TV-related audio directly from the digital audio outputs of each source you're watching, not the TV.
Feb 19, 2010 | Kenwood VR-606 Receiver
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
Sony a/v reciever not sending video to tv.....
I don´t know if I´ve understood, but the best way to "pass" video signals to TV through receivers is using a stereo VCR, where you plug in any antenna. Then you connect VCR´s audio and video channels to the receiver. Turning on all equipment, select video1 source. You will hear sound through the system and watch video signal on TV. Hope this may help.
May 22, 2008 | Sony A/V Receiver
27 people viewed this question
 Grubhead
Grubhead
