Question about HP Pavilion dv6227cl Notebook
My Laptop wont power on
HELO....my laptop wont power on...it keeps trying but nada....is this a hard drive problem?? I try with battery out with ac adpter and nada...I try to start it up with the start up disc and that wont work either...any help would be greatly appreciated..
  • SSexyAzz Mar 25, 2009
    hello,
    thanks for your advice...it isnt the power adapter...nor the battery had them both tested...I do think ur right about the mother board...is there a place online where i can purchase a motherboard for my specefic laptop?
    thanks
  • HP Master
  • 13,433 Answers
Hi
Since your computer is not starting up at all its probably not a problem in the hard drive (where the files are stored) It is most likely a problem in the motherboard. Try removing the battery and ac then plug in the ac and try starting up, is the ac working? do you have a power light on the laptop that turns on when you plug in the ac adapter?\
If you don\t have a power light you need to get the ac adapter tested if the adapter is fine then most likely the issue is in the motherboard.
This seems to be a old problem and if you don\t need assistance in solving it. It would be great if you would share to the world how you fixed your problem so other users can benefit from your experience.
Thank you,
Ekse
Posted on Dec 28, 2008
LED light for AC power comes on but no fan, no power, blank screen
have you tryed just the mains with out the battery ,some laptops wont start if the battery is faulty,
or if the fan is full of dust and dirt and it can not turn, your laptop will not start.
Jul 09, 2014 | HP Compaq Presario CQ50-110US Laptop
It wont turn on all it said is loding os image
An AC power adapter and a battery work together to serve as the power supply of a notebook computer. Whenever you connect a power adapter into a laptop's power port, it supplies enough power to the battery for you to boot the operating system, run programs and perform computing tasks.
1. Turn on the laptop. If it does not power on, the battery may need to be charged. Connect the two ends of the AC adapter into the notebook's power port and a power outlet. Ensure that the power outlet into which the AC adapter is connected is active. Try plugging the power adapter into another wall outlet if the first outlet you try is not generating power.
2. See if the LED power light goes up. If it does but the laptop still does not power on, reseat the battery. Open the battery compartment at the back of the laptop and remove the battery. Wipe the gold contacts of the battery as well as the battery contacts of your laptop. Place the battery back into the slot and ensure that it is properly seated.
3. Remove all unnecessary peripherals if the laptop still does not power on; these may include external hard drives, flash drives and card readers. Turn on the laptop once again and see if it powers on successfully.
4. Use another battery or another AC adapter. If using another battery or another AC power adapter solves the problem, then the issue is with the battery or the AC adapter that you were using. Replace whichever item is malfunctioning. If this still does not remedy the issue, then the issue may be with the laptop's power port or the laptop may be malfunctioning. Seek help with a professional if this is the case.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | Sylvania G-Netbook
My laptop wont turn on and yet its fully charge. The power light keeps on blinking with orange and when i push the start button, it turns green and when i stop pushing, it turns orange again-blinking.
Hi.
This sounds like there is a problem with the battery.
Remove the AC mains power and take out the battery from the laptop. Plug AC power back in and try booting the laptop up.
If it boots up let it boot into Windows/linux and then shut the computer down as normal. Remove AC power and re-insert the battery. Plug AC back in and power it up, see if it does the same thing. If it does the same thing the battery is faulty. If it boots up with the battery in then there was a glitch.
Regards.
Jun 08, 2011 | Sony Computers & Internet
Laptop will turn on,but wont boot up
L300 boot problems
L300 series laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Feb 12, 2011 | Toshiba Satellite Pro L300 Notebook
Wont boot up, have replaced charger but still wont boot up
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre to help you out.
Dec 31, 2010 | Computers & Internet
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Feb 13, 2010 | Acer Aspire 3000 Notebook
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.Some time it boot up and run but then it won't do it nextime after it been power off. Battery for BIOS is good, Main...
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | IBM ThinkPad T30 2366 Notebook
Laptop wont turn on orange light flashing on front indicating power plug
Nov 14, 2009 | Toshiba Satellite A135-S2276 Notebook
HP Pavilion dv6227cl Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
