Question about Kenmore 22.0 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Changing the water filter in my Frigidaire
I'm trying to change the water filter in my Frigidaire side-by-side - model #FRS6LRSEW3 - and it will not budge. How can I loosen it?
Thanks.
  • snowdrops May 11, 2010
    where is the filter located
My Frigidaire PureSource water filter housing wouldn't unscrew either. Even with the supplied plastic "wrench" and later a cloth-covered pipe wrench, it wouldn't budge. Since both my icemaker and my door dispenser stopped dispensing water, and the filter housing in the fridge wouldn't budge, I suspected that the filter was full of frozen water. (Sometimes things on the top shelf of the fridge freeze, so it was obviously too cold.) I used a hair dryer on the water filter housing for a few minutes, and then the water filter unscrewed easily. Sure enough, the whole inside was a block of frozen water.
This would have been such a simple repair, HOWEVER unfortunately it turned out that I wrenched it too hard and broke the inlet valve on the housing. As soon as I thawed out the filter and reassembled, water was pouring out of the top. Took off the big cover at the top ceiling of the fridge and saw my problem.
It's only about a $25 part, but I'd advise that you be careful to only turn, without rocking back and forth, the housing when trying to unscrew. I guess I wiggled it back and forth too much and cracked it.
Posted on May 28, 2012
You need two things. the most important is a bigger tool. The filter is just too tight for loosening by hand. use a big pair of channel locks or a smal pipe wrench to turn the filter body to your left when facing it. you won't hurt it. counterclockwise to remove it, clockwise to install it back. put it back a hard hand tight and make sure it doesn't leak when you run water through it. you don't have to turn off the water, but run plenty of water through the new filter to get the air out.
the second thing is to curse it properly and sincerely while loosening the old filter. the harder you have to work to loosen it, the more specific and socially unacceptable the curse words have to be. white collar and office type workers frequently fail at this part because they aren't really cursing from the heart. you have to mean it.
Posted on Jan 07, 2009
Water dispenser on my 3 year old side by side FRIGIDAIRE PROFESSIONAL FPHS2386LFO is not working, It makes ICE but no water I can hear motor when I try to use dispenser
I appreciate your inquiry, bela_desousa!
From the information you have provided the water dispenser on your Frigidaire refrigerator is not dispensing. Have you recently changed your water filter? If you water filter has not been changed and is dirty or clogged it could lead to potential failure of your water dispenser. If the filter has been changed it could be a faulty dispenser. I would suggest consulting with a professional technician for proper diagnosis and repair. Hopefully this is helpful. -Matt
Dec 26, 2014 | Frigidaire FPHS2386LF Professional 22.6...
Water dispenser does not work
Good Afternoon Friend,
I understand that the water dispenser on your Frigidaire refrigerator does not work. First, I suggest changing your water filter, making sure that the filter is flush with the filter housing. Secondly, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try to get water out of the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. If further troubleshooting is required, please leave me the model number of your refrigerator. Typically you can find this number inside the refrigerator on the right hand wall. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
Frigidaire FRS6R5ESBS: I am having problems with
Good Afternoon Renee, thank you for your post! First, have you recently changed the water filter? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. With the new design of the water filter, incoming water pressure may be the problem. By leaving the water valve on while changing the water filter, it may not allow the filter to make a good connection.
When the filter is being put in initially, try turning off the water supply to the refrigerator, and then insert the water filter. Turn the water back on, and you should not have any issues.
Also keep in mind that a clogged water filter or a blocked supply water valve may also lead to low water flow. If so, melt the blockage using a hair dryer - but be careful to not melt any plastic parts!
We do hope this resolves your concerns. If I can be of further assistance, please feel free to reconnect.
Aug 16, 2013 | Frigidaire Refrigerators
Elextrolox side by side water leaking out filter in top of refrigerator model extre23cs78epso
have you recently changed the filter? try turning it in tighter. you may need a new filter base or a new filter if the seals are missing or something on a new one.
Aug 05, 2013 | Frigidaire FRS3R5EMB Side by Side...
How do i replace the water filter.
http://www.frigidaire.com/manuals Enter your model number
Manual link:
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241661500en.pdf
Actual precedure with pictures is on page 14 of the above link.
GENERIC Installation Instructions:
  1. Unscrew the filter cup and dump out the water
  2. Pull the old filter straight down and discard
  3. Place the new filter in the filter cup
  4. The end of the filter with the small o-ring should be up
  5. Screw the filter cup (with filter) up onto the housing
  6. The filter will self-align as the cup is tightened
  7. Reset your 'change filter' light (if your fridge has one)
Resetting your filter change indicator light:
  • Press and hold the reset button on the dispenser until the green light flashes (up to 15 seconds)
Thanks for choosing FixYa,
Kelly
May 24, 2011 | Frigidaire Side By Side Refrigerator 26...
No water to the ice maker
filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
How can I change the water filter on a frigidaire fridge
Hi, The filter is in the upper right hand corner of the fresh food section. Turn the filter cup counter clockwise to remove it. There will be a filter cartridge in the cup that you replace.
Please let me know if this has been helpfull or if I can assist you further
Thanks
Vic
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Won't make ice
Have you changed your water filter lately. On many side by sides there are built in water filters that will slowly stop making ice and giving water because the filter is in need of changing...if this is not the problem write back and I will walk you through the other possibilities...
May 18, 2009 | Electrolux Refrigerators
here is an animation that helped me!
http://assets.whirlpool.com/files/usr/animations/ANM000077.htm
Hope that helps.
Jan 03, 2009 | Refrigerators
Refrigerators Logo
385 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
