Question about Cameras
PDF led macro ring flash FC100 instruction manual
  • 62 Answers
Most manufactures websites will have down loadable instruction manuals.
Posted on Mar 19, 2011
Can I use one nikon d5100 with one sakar mc zoom 80-200 No. 803489
If your lens has a Nikon mount then yes, you can use it on the D5100. You'll have to switch to the Manual exposure mode and you won't get any exposure help from the camera's light meter.
May 31, 2012 | Sakar "Digital Photgraphy Macro Ring Light...
How to shoot in macro
Follow the instructions in the "Shooting Close-ups (Macro)" section of the manual (page 67 in my copy). If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/2/0300003042/01/PSA3100IS_3000IS_CUG_EN.pdf
Sep 11, 2011 | Canon A3100 IS Digital Camera
I don't know how to get it to take extreme closeups
Hi there please follow the link below for user guide & use the zoom ring or macro mode( control dial) for distance & close photo taking. Thanks.
LINK --- click here.,
Apr 07, 2010 | Canon PowerShot S3 IS Digital Camera
Metz 15 MS1 Macro Ring Flash with Panasonic Lumix G1 4/3rd Camera
Set camera to manual exposure. Set Shutter below 60 Set F Stop until exposure is correct.
atdlee@netzero.com
Feb 08, 2010 | Metz 15 MS1 DIGITAL MACROFLASH TTL Ring...
The CD that came with the camera will not load onto my computer. I need an instruction manual. I did figure out how to take, delete, ect. but for some reason the flash will not turn on and I get a message...
The flash will not fire in macro mode because macro mode allows you to get close to your subject. Get out of macro mode by pressing a button with a picture of a flower on it or by it.
Jan 11, 2010 | Vivitar ViviCam 8025 Digital Camera
Nikon D40 I bought a set of macro lenses that said they were compatible for the d40 but i cannot figure out how to fit them. They are 52mm lenses - should i have bought an adaptor or something? where...
Macro lenses are mounted to your camera body in place of the lens you currently have mounted on the camera. If you bought the camera with the lens already mounted you may not have realized that the camera and lens are 2 separate objects. To remove your lens see page 8 in your user manual for instructions and an illustration. If you don't have your user manual handy, you can download a PDF file from NikonUSA Here.
If what you bought are macro rings, they go on the camera, then your regular lens mounts onto the ring. You can use one or more of the rings between the lens and camera to produce different macro settings.
If what you bought are macro filters, they screw on to the front of your lens. If you have a UV filter on your lens you need to remove that before you attach another filter.
Dec 22, 2008 | Nikon Cameras
SB-29 speedlight overflash
Go Manual.
Set F Stop to higher number.
Can also lower the ISO.
atdlee@netzero.com
Jan 16, 2008 | Nikon Macro Speedlight SB-29 TTL Ring...
Unsure of how to use the extra functionality
That is the focusing ring. I'm guessing your camera is set to focus automatically (Little switch on the side of the lens should have settings for either AF or MF, or something similar.)
If its on AF, you don't need to adjust the focus ring.
However, if you have problems with the AF (sometimes it has trouble, especially in low light) you can switch it to MF, and focus manually by changing the ring.
As a general guideline, the more you twist to towards macro, it focuses closer and closer, and infinity futher away (if you're taking a shot of the moon, you want it on infinity)
Nov 26, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Can the conventional Maxxum/Dynax flash units be used with this camera?
Yes. The following Minolta dedicated external flash units are compatible with the DiMAGE A1 for automatic flash control: Program Flash 3600HS(D), Program Flash 5600HS(D), *Program Flash 2500(D), Macro Twin Flash 2400*, Macro Ring Flash 1200*. * Program Flash 2500(D) will be available around August, 2003. *Macro Flash Controller is necessary
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
With Macro flash unit attached, and using the closest subject distance, images are extremely over-exposed.
The camera fails to control the flash output automatically due to the high intensity of Macro ring flash, causing the image to be over-exposed. Please set the camera as below to prevent a undesired result. Camera and Flash Settings - Set the sensitivity to ISO 100 using the function dial of the camera. - Set the flash metering of the camera to Pre-Flash TTL from the recording-mode menu. MACRO RING FLASH 1200 - Set the camera exposure mode to A or M mode. - Set the aperture to f/6.7. - Attach a ND filter x4 (0.6D) to the camera lens. MACRO TWIN FLASH 2400 - Attach a diffuser to the flash tube units. In case the flash tube and the subject is too close, eg. Not using the arms, set the camera exposure mode to A or M mode and the aperture to f/6.7. A subject at minimum distance may still be overexposed. Use exposure compensation to obtain the best result.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Cameras Logo
261 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
