Question about Kenmore 95002 / 95004 Electric Kitchen Range
I have a kenmore electric range. model 665.95002102. I have replace the clock electronic control board and the touch pad.but when i plug in the range the clock works and displays the "PF" but none of the touch pads work at all. I can not get any of them to work. What could be wrong please help. Tom B
SOURCE: Electronic touch pad problems
 the f1 and f3 fault code beeps i press clear it goes off but still will not let me cook in my oven.  gas down draft stove model jds9860aap
Posted on Dec 28, 2007
reg501
  • 413 Answers
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
Posted on Jun 26, 2008
huuum
  • 750 Answers
SOURCE: electronic touch pad not working on my oven
Hello beachlady80,
Welcome
You said, It was working fine last night but when you woke up this morning the display has 3 vertical lines and none of the electronic touch pads work. The burners on top of the stove still work.
What is the model number and how old is the range ?
Try turning the breaker off for 10 minutes and then on again after this allotted time.
This may reset the system.
Let me know how it works.
Waiting for your answer.
Huuum
Please remember to leave a rating.
Hopefully it will be a solved!
Let me know
Posted on Oct 16, 2008
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
EllaWatson25
  • 725 Answers
SOURCE: electronic control touch pad not working
This is your electronic control board that needs to be repalced on this unit. GE Profile is a great brand and it is easy to repair, also.
We provide part removal/installation instructions for our customers when you purchase your parts from us.We also ship parts overnight to assure that you get your oven repaired right away.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 9 PM CST. We look forward to getting you cooking again soon.
Thanks, Ella
Posted on Nov 17, 2009
Oven wont heat up, F-1 on timer
This indicates the ERC Electronic Range Control has failed. First check the key pad. Press each button one at a time. You should feel or hear a click and feel the retraction. If any button is not working the problem is likely in the key pad. If you locate the tech sheet ( somewhere on the stove, usually in the control panel) it may have a ohm check that can be done on the key pad to rule out the key pad. Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1:
- Disconnect power to the range.
- Gain access to the back of the ERC (electronic range control, or "clock").
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC.
- Turn the power back on to the range.
- Watch for the F-1 and listen for the beep.
- If you get the F-1 and beep, replace the ERC.
- If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control(ERC). If all seems good the control is at fault. Check to see if you have power going into the control. If you do and nothing is working the control board or ERC needs to be replaced. Here is a link for checking and replacing an oven control. If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Oct 22, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Display reads EO F2 Can't find what it means>
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question
Oct 05, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
While using the oven, a code EO-F2- appeared and would no longe heat.
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 27, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Dispaly E0 F2
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!%!%
May 08, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore Kitchen Ranges
Message on the display is E0-F2- need to know what is this problem code means. This is a glass cooktop Kenmore electric range
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Aug 03, 2009 | Kenmore 95589 Electric Kitchen Range
Kenmore stove error message E0 -F2-
Feb 12, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 8114p643 showing f1.
F1 is either a bad electronic control board or a bad touch pad.
You find the solution on :kenmore oven with "F1" error
I quote:
"You have either a bad ERC (clock) or a bad touch pad.
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
    8. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
      NOTE: Some models incorporate the touch pad and the clock as one part.
If you can't find a new ERC you can send yours to stove clock repair and get it repaired!"
Dec 14, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore electric Range model 635040L0
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Sep 24, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
Kenmore 95002 / 95004 Electric Kitchen Range Logo
107 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
