Carver C11 I have a 20 year old Carver C11 preamp. It works good except it makes a popping noise through the line output when it is on for an while. I believe it is a cap in the line output stage but cannot confirm. I have electronics experience and can do some repairs myself. Any suggestions on how to diagnosis the problem with only a Fluke 87 and no schematic.
  • Tim Hilgeford Aug 02, 2008
    Two questions: one the popping is a intermittant noise that occurs even with no input, and how do I indentify the tantalum caps, also would they show normal signs of cap damage, such as swelling or leaking.
    Master:
  • 382 Answers
Try replacing the bead tantalum caps,it should reduce the output noise...but if there are any soldering problems in the hardware and output model im sorry to say you must replace the whole unit..Thank you...
Please post back how things turned on or for further assistance..
Regards!!..
Posted on Aug 02, 2008
  • Natesan Sabesan
    Natesan Sabesan Aug 02, 2008
    well you can get the sound without input, just by connecting it to power rite??...Yeah you can identify them by swelling or improper soldering..But if your not sure then call up a service person or whose experienced in this!!..Thank you...
  • 10,594 Answers
Well, I also have some experience in old things.. Please let me know, does it have "rotary or slide switches" for selection of various inputs? if yes, kindly clean them with W-40 Contact Spray. I hope, problem will resolve there n then.
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Aug 02, 2008
    Hi again,
    one more thing like to tell, please clean/ spray its Record-Switch mounted at circuit board...it would be like....long slide switch.
    What about my suggestions?
    Shahid Electronics Aug 03, 2008
    • Any comments on my solution?
    Shahid Electronics Aug 15, 2008
    Hi again,
    Do you need further helpful info, let me know please.
My carver HR - 895 was staticy at times on FM and all the sudden shut off. Now it won't Power up at all what do I do ?
Do you have an indicator light blinking or illuminated? If so, your amp has DC Offset, meaning a damaged amplifier. The static noise you heard, may have been DC voltage on the speaker output.
If you are interested in having your Carver repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Feb 10, 2015 | Carver Audio Players & Recorders
How to hook a carver TFM 45 to a Marantz AV 8003 pre amp with Bose 901 speakers thank you very much
The output of the Marantz will go to the input of the Carver. The Bose EQ has to go into a Tape Monitor on the Marantz, or, you can connect the Marantz output to the Bose line in(not tape in). The line output of the Bose, to the Carver input.
Is there anything else I'm missing?
Jan 08, 2015 | Marantz Audio Players & Recorders
Carver TFM 35 amp what is the best way to hook it to a Marantz AV8003 pre app
No. You should use the line(or preamp output) to the Carver input. The only way you could use the tape output is if the Carver has input volume controls.
Dec 21, 2014 | Marantz Audio Players & Recorders
User manual for carver 6250 receiver
I'm looking for parts to repair Carver 6250, as I turn volume up or down the output has some distortion.
Jan 30, 2012 | Carver Audio Players & Recorders
Carver PM1400 somtime only play in one channel
Hi...
Make sure your input cables are good and that your output cables are FIRMLY connected.
Does the problem change when you rotate either volume knob?
If this helps please rate my help
Thanks
Nov 02, 2009 | Carver PM950 Amplifier
I have a carver M 1.5 amp rt. channel is out.
Carver designs in general are not easy to repair. I would recommend that you send this unit into a Carver authorized service center. The likely problem is the output transistors, but the driver circuits and predrivers are not simple designs and if there is a problem there, it could effect the outputs. Tracing this will require equipment and schematics that I don't believe are available on the net.
Dan
Sep 04, 2009 | Carver PM950 Amplifier
Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Mar 12, 2009 | Onkyo TX-SR803 Receiver
Carver C11 preamp problem
I found out through the Carver Audio forums that metal shavings inside the case are an issue with this unit. So I used an achohol based spray and cleaned the switchs and the circuit board, (there was a fair amount of shavings found). It has been running for 14 hours with no problems.
Aug 02, 2008 | Audio Players & Recorders
Turntable to reciever connections
check the continuity in your cables. you will need a multimeter or something else to check the cables. the multimeter is about $10 or so. other than that, make sure that your turntable is actually giving output and that the pre amp is both recieving and sending(same with the regular amp. and make sure that the levels are up on everything and the speakers connected properly etc. you probably know this already, but sometimes a good, friendly reminder helps. good luck!!
May 23, 2008 | Audio Players & Recorders
RCA Problem
You need an active subwoofer input in your amplifier.Which amplifier you are using? Only latest pioneer amplifiers has active sub input and sub output which can be connected to subwoofer.If you dont have active input then you will have to connect it the way you did in old player.
Feb 10, 2007 | Pioneer DEH-1800 CD Player
382 people viewed this question
 Grubhead
Grubhead
