Question about Galileo FS-85MOHDX Telescope
Im seeing my eye reflected back at me through the angled mirror.
  • 3,186 Answers
You are NOT in focus. Put the eyepiece with the largest number written on it into the focuser. Go outside during the day time and practice focusing on a distant object-- turn the focuser knob slowly until the image comes to focus.
Posted on Mar 19, 2011
I can't see a thing through the eye piece
Is this a reflective telescope? You need to make sure a couple things. Make sure the small mirror is still in place. Usually the eyepiece can be pulled gently out. Make sure no packing material is on the inside of the eye piece.
Jan 17, 2015 | Optics
My sir told that transparent glass do not reflect any ray. We see things by reflect only.e.g moon. Reflect means not only like face mirror. Then how we can see mirror.
There is no mirror in the scanner. It is supposed to be clear glass. The light comes on to scan the item in the scanner.
Don't understand your problem. If the light does not come on the printer isn't plugged in or turned on when scanning.
Dec 14, 2014 | Office Equipment & Supplies
How do i remove the mirror on the hp laserjet 1200
Not required to remove mirror to avoid abnormal sound. The mirror is a part in Laser scanner assembly to reflect the image on OPC drum in various angles depends on model. In your series 1200 having single mirrored scanner assembly mounted on top area. To remove this you need to remove right,left back & top covers.. The laser scanner protect with four screws & two connectors. Remove all take out the unit. For removing the bonnet single screw protection remove this screw, take out cover. Inside you can observe a motor with four faced reflector. While motor got the energy it will rotate, if motor lubes are dried up it will make noise, remove motor head gently,(to remove take out entire motor unit with PCB which protects three screws, you cab observe black 'U' shaped plastic lock unlock it & pull motor up, apply lube to rotor & refix it back, ref see the drawing, you want to clean the mirror? ear bud you can clean surface of the mirror gently..
But it is no so easy, bare hands you cannot handle the mirrors, If mirror disturbed its factory fitted angle its very difficulty to back its own position. Removing the motor also difficulty,motor head carrying 4D reflector, while removing any scratches, or finger prints will damage the quality of prints some times scanner error appears.. 9_5_2012_11_07_49_am.gif
Sep 04, 2012 | HP Office Equipment & Supplies
Problem with reflector telescope ta1100-102
It is NOT in focus. Practice focusing on a distant object during the day time.
May 28, 2010 | Ultimate Sound Optics
DSC-H7 camera, getting red eye or white eye spots
First, here is why they are red or white spots:
The red is the reflection of your flash on the retinas of your subjects. The white are generally animal eyes reflecting back.
You will notice this on flash shots only and mostly when you use the zoom. The zoom uses a "narrow" field of view so the light that reflects back is "direct", instrad of at an angle.
The fix: Change the ISO setting (it is set too high). It is probably near the maximum sensitivity (3200?)... set it to 400 or so and try that for a while. 800 is probably the best general setting, but try 400 first.
Try not to use the flash unless you really have to, but only if the subject is less than 12 feet away. If no people are in the picture, you may use the flash for subjects greater than 12 feet.
this should work for you...
Sep 11, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
I also bought one & have no idea how the lenses should work...
Verify that the mirrors are aligned; look through the eyepiece holder (without an eyepiece) and you should see the main mirror with your eye looking back from the center. Ensure that there are no filters on the eyepiece, and use the lowest power one to begin (longest focal length).
Sep 08, 2009 | Tasco Galaxsee 46114500 (500 x 114mm)...
HP 6380 had a ghost in it?
  1. Press the Power button, and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord into the wall outlet.
  6. Press and hold # and 6 while plugging the power cord back into the HP All-in-One.
  7. Turn on the All-in-One by pressing the Power button (c01150476.jpg ).
Aug 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
Problem with orion 6" dobsonian mount telescope
The small mirror is usually held on with double-sided foam tape. That tape us used, so the small mirror is not stressed by the metal fittings with temperature changes. Clean the residue from the holder and the mirror, and apply fresh double-sided mounting tape and carefully place the mirror so that the main mirror is viewed from the eyepiece position.
Aug 09, 2008 | Orion (05374) Telescope
HP PSC 750 Scanner Failure
The failure is probably due to a bad signal coming from the "eye" that controls the warming up. The "eye" has to catch a reflection from a small mirror which is probably dirty and reflects nothing at all ! So you always get continuously "warming up" .....
The mirrorl is somewhere very near the moving lamp.
I managed to repair my psc in cleaning that mirror. But ... be very carefull; it is not easy to open the printer and when you disconnect the command ribbon, write down how you did it !
I wish everyone patience, good luck and .... success !
Mar 03, 2008 | HP PSC 750 All-In-One InkJet Printer
Galileo FS-85MOHDX Telescope Logo
123 people viewed this question
Top Galileo Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Galileo Optic Expert? Answer questions, earn points and help others
